Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
97 registered members (andyd, alphadog, 53' Stude, 2015_PSD, 240_Ed, AdditiveOCD, 11 invisible), 1,887 guests, and 25 spiders.
Topics287,853
Posts4,935,592
Members67,865
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Confess if you drive around with your CEL on #4486675
08/12/17 05:00 PM
08/12/17 05:00 PM
Ohio
L_Sludger Offline OP
Ohio
As the title states confess here if you drive around with the check engine light on
too many cars and oil combinations to list in 150 characters or less
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486679
08/12/17 05:16 PM
08/12/17 05:16 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Yes, my Xterra has to go through several cycles before going out after I tripped the antifreeze level after changing and attempting to purge the air out of system
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486680
08/12/17 05:16 PM
08/12/17 05:16 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
My mk4 GLI had the dreaded p0420 code. These cars had this code very often and sometimes it was a false positive. I had no vacuum leaks, good and operational o2 sensors, good MAF and a functioning cat. Car ran great. Drove with the light on for that code for 80k miles.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486683
08/12/17 05:18 PM
08/12/17 05:18 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
I did on my 98 Mustang. It had a P0420 code from when I put an offroad x-pipe on it. The sound and power was worth it.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486685
08/12/17 05:20 PM
08/12/17 05:20 PM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
Of course I wouldn't drive around with the CEL light on. I'd get one of those cheap little code readers, permanently mount it in the car, and clear the code as soon as it occurred. Perhaps even while driving. "Clearing codes on the fly."
Seriously, no, I generally fix any code throwing problems as soon as I can get to it.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486687
08/12/17 05:21 PM
08/12/17 05:21 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
My wifes piece of junk chevy is always throwing some code. Usually its from the ill designed evaporative emissions system.
I pretty much gave up fixing that piece of garbage.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486690
08/12/17 05:23 PM
08/12/17 05:23 PM
MN
14Accent Offline
14Accent  Offline
MN
Sure do. My Marauder throws EGR flow codes because the DPFE sensor is bad. EGR valve works fine, but the sensor is integrated and I don't feel like spending $130 on an entire valve.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486694
08/12/17 05:31 PM
08/12/17 05:31 PM
Ohio
Ohio
My cars: Most of them have the CEL on for one reason or another. Oh well happy
Re: Confess if you drive around with your CEL on [Re: TinyVoices] #4486697
08/12/17 05:34 PM
08/12/17 05:34 PM
Ohio
Ohio
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486698
08/12/17 05:38 PM
08/12/17 05:38 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
A couple of weeks ago the "service engine soon" light came on, on out 2001 Impala. I puled into Advance Auto and borrowed their code reader and there were no codes. That light went out and has not come back on and I still have no clue why it was on.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486699
08/12/17 05:41 PM
08/12/17 05:41 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I can't do it. Just can't. On the Mazda its new and if it comes on I'll address it. On the truck, every time its come on its only been for something that is debilitating so it has to get fixed. Last one was a bad MAP sensor. Mercedes pre dates CEL's.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Confess if you drive around with your CEL on [Re: JimPghPA] #4486702
08/12/17 05:45 PM
08/12/17 05:45 PM
Ohio
Ohio
could be a gas cap left loose.
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486703
08/12/17 05:45 PM
08/12/17 05:45 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
1) Faulty Air Pump
2) TPMS light
3) Brake Light
Re: Confess if you drive around with your CEL on [Re: L_Sludger] #4486710
08/12/17 05:51 PM
08/12/17 05:51 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
My dad and my gf's dad both just covered theirs up with a piece of black electrical tape haha laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Confess if you drive around with your CEL on [Re: aquariuscsm] #4486714
08/12/17 05:58 PM
08/12/17 05:58 PM
Ohio
Ohio
Nice.
The only time a check engine light got really severe for me was with a faulty coil pack on a Toyota Echo. That CEL actually blinked. The car was misfiring and dumping fuel into the cat - a worthwhile alarm for sure.
Page 1 of 5 1 2 5
