The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
33 registered members (berniedd, claluja, aleneros, Brad_C, Chesterr, 2 invisible), 634 guests, and 66 spiders.
Topics286,097
Posts4,902,480
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Because I Can Part II #4486666
08/12/17 04:43 PM
08/12/17 04:43 PM
Alabama, United States
Red91 Offline OP
Red91  Offline OP
12 quarts SJ Castrol Heavy Duty 30wt
24 quarts CF/SJ Mobil Delvac 1230 30wt
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can Part II [Re: Red91] #4486678
08/12/17 05:13 PM
08/12/17 05:13 PM
MD
AirgunSavant Offline
MD
Sorry I missed it. What is the big thrill with 30 weight oil.
Not that it is an issue.
Re: Because I Can Part II [Re: Red91] #4486684
08/12/17 05:19 PM
08/12/17 05:19 PM
MD
amcguru Offline
amcguru  Offline
MD
I'm gonna guess it's because the bomb proof 50's design doesn't care what you feed it. In a world full of highly advanced, tight tolerance smog motors, there is something refreshing about that. When you turn the key, it just goes.
'16 Mercedes C300 -M1 5w40 formula M, OE filter
'03 Ford Excursion 7.3 PSD -Schaeffer 9000 5w40, Donaldson ELF7405
Re: Because I Can Part II [Re: amcguru] #4486705
08/12/17 05:46 PM
08/12/17 05:46 PM
PimTac Offline
PimTac  Offline
There was no plastic in the 50's cars save for the bakelite steering wheel or whatever it was made from.
Cannot see signatures any longer so it doesn’t matter.
Re: Because I Can Part II [Re: Red91] #4486726
08/12/17 06:12 PM
08/12/17 06:12 PM
Illinois, USA
Triton_330 Offline
Triton_330  Offline
Illinois, USA
I see you're a fan of Del Monte fruit in a can - nice.
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Re: Because I Can Part II [Re: Red91] #4486729
08/12/17 06:15 PM
08/12/17 06:15 PM
California
Errtt Offline
Errtt  Offline
California
Free Team Hat grin
Re: Because I Can Part II [Re: Red91] #4486741
08/12/17 06:26 PM
08/12/17 06:26 PM
BC, Canada
userfriendly Offline
BC, Canada
Delvac dropped their 1330 so Red91 had to buy 1230 or 1630, which might only be available in 208 liter drums.
Castrol free hat.
Re: Because I Can Part II [Re: userfriendly] #4486768
08/12/17 07:03 PM
08/12/17 07:03 PM
Red91 Offline OP
Red91  Offline OP
How do you like the 1230? This is old stock, and at the time the CF/SJ spec was current.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can Part II [Re: AirgunSavant] #4486773
08/12/17 07:09 PM
08/12/17 07:09 PM
Red91 Offline OP
Red91  Offline OP
Less overall wear than multigrade and shear resistant.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can Part II [Re: Red91] #4486791
08/12/17 07:26 PM
08/12/17 07:26 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Sure that Delvac 1230 isn't CF-2? The PDS for the modern 1230 shows a TBN of only 5.8, that will deplete fairly quickly in a gas engine, it's intended for 2 stroke DD diesels.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Because I Can Part II [Re: Red91] #4486804
08/12/17 07:46 PM
08/12/17 07:46 PM
BC, Canada
BC, Canada
Red91; I'm down to my last 4.5 liters of 1330 from a 20L pail I opened in March. Two changes on a 13 matrix and one on a 3 5.3L GMC 1500.
Mono-grade season will be over in the great white north in 8 weeks. I can use up the last of the SAE30 with either 10w30 or 15w40 1300.
I've used Duron 30 and 40 in both my 06 & 11 Duramax, P1200 Zn1350, which is about the same as Delo 400 30 'n 40. In a gasoline engine above say 20F, your 1230 CF-2 might be the ultimate engine oil. HTHS 3.5-3.7 NOACK likely 2-4% I've used HD30 & 40 Castrol in motorcycles, VW Beetles and their 10W40 motorcycle went in my JD 22 hp tractor for a couple of years.
20w50 Castrol MC would be a way around the California oil law.
I read your UOA. What's not to like about your SAE30 program?
Edit as per the last post; TBN or now just "BN" retention, depletion rate is just as important as the BN of the fresh oil.
Re: Because I Can Part II [Re: bullwinkle] #4486874
08/12/17 09:09 PM
08/12/17 09:09 PM
Red91 Offline OP
Red91  Offline OP
The labeling indentifies the Delvac as a mixed fleet oil suitable for diesel and gasoline engines. Even with the CF-2 spec listed in addition to the CF/SJ spec, I don't believe the 1230 to be a dedicated Detroit two stroke oil,such as Delo 100.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can Part II [Re: userfriendly] #4486880
08/12/17 09:15 PM
08/12/17 09:15 PM
Red91 Offline OP
Red91  Offline OP
Below twenty degree F days are exceedingly rare down here. The Delo 400 30wt did fine early last winter (2016), as has the Kendall GT-1 30wt in the latter half of the season (2017).
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can Part II [Re: Red91] #4486916
08/12/17 10:10 PM
08/12/17 10:10 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'm not understanding the shear resistant part. 5w30 after 6,300 miles in my GDI engine and it kept in grade perfectly fine. Also, wear metals were 1/2 of the average.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Because I Can Part II [Re: Nick1994] #4486921
08/12/17 10:16 PM
08/12/17 10:16 PM
Red91 Offline OP
Red91  Offline OP
I don't care.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Page 1 of 3 1 2 3
