Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
83 registered (andyd, 2015_PSD, 93cruiser, ammolab, Astro14, 77GrandPrix, 13 invisible), 1489 Guests and 53 Spiders online.
65294 Members
67 Forums
285789 Topics
#4486662 - 08/12/17 04:37 PM Brake Pad Question
Gebo Offline
Loc: VA
Installing brake pads on my LS400. I noticed on the NEW OEM Toyota pads that there is this shaved down area on each end of each pad. Should they be installed with the shaved end up on one side of the rotor and the other side down on the rotor? I'm thinking the shaved off end of the pads should be diagonal on the rotor.
OR does it matter?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4486664 - 08/12/17 04:39 PM Re: Brake Pad Question [Re: Gebo]
bdcardinal Online   content
Loc: Santa Barbara, CA
Are you talking about a chamfer on the pads? If they were not on both sides of the pad I usually install them so the chamfer faces rotor movement, which would be different depending on if the caliper is mounted on the front or rear of the axle.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4486668 - 08/12/17 04:46 PM Re: Brake Pad Question [Re: Gebo]
Gebo Offline
Loc: VA
Yes. Chamfer is just on one end of the pad. Caliper is mounted on the rear. So I should mount the pads with the chamfer down?
Edited by Gebo (08/12/17 04:47 PM)
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4486670 - 08/12/17 04:50 PM Re: Brake Pad Question [Re: Gebo]
That is how I would do it.
#4486689 - 08/12/17 05:23 PM Re: Brake Pad Question [Re: Gebo]
slacktide_bitog Offline
Loc: USA
It seems like they should be the same, since they're usual;ly symmetrical.
Take a picture of them smile
#4486707 - 08/12/17 05:48 PM Re: Brake Pad Question [Re: Gebo]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Rotor should rotate into the chamfer.
#4486776 - 08/12/17 07:09 PM Re: Brake Pad Question [Re: Gebo]
Gebo Offline
Loc: VA
Installed..done. thanks for the advice.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4486779 - 08/12/17 07:10 PM Re: Brake Pad Question [Re: slacktide_bitog]
Gebo Offline
Loc: VA
Chamfer was just in one end of each pad.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
