Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
91 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 8 invisible), 1,352 guests, and 42 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
6L80e fluid return line #4486204
08/11/17 10:44 PM
08/11/17 10:44 PM
Northern Nevada
cb4017 Online content OP
cb4017  Online Content OP
Northern Nevada
My Jeep JK Wrangler now has a GM LS 5.3L engine and a 6L80 transmission. I'm upgrading the tranny fluid cooler and want to make sure I have things flowing the right way. Which line is the fluid return line, top or bottom at the transmission? I thought it was the top line but found some conflicting information on the interweb.
Thanks!
Cliff
USN Ret., FPD Ret.
Re: 6L80e fluid return line [Re: cb4017] #4486208
08/11/17 10:52 PM
08/11/17 10:52 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Take one off and have someone start it,and be ready to turn it off.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 6L80e fluid return line [Re: cb4017] #4486214
08/11/17 11:06 PM
08/11/17 11:06 PM
BC, Canada
userfriendly Offline
BC, Canada
Bottom line from transmission to top of rad, return line is from bottom of rad to top of transmission.
Re: 6L80e fluid return line [Re: userfriendly] #4486235
08/11/17 11:45 PM
08/11/17 11:45 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That makes good sense. It would be easier for the fluid to flow down through the radiator--rather than flow upwards.
Re: 6L80e fluid return line [Re: Merkava_4] #4486244
08/12/17 12:12 AM
08/12/17 12:12 AM
Northern Nevada
Northern Nevada
Hmm, B&M says the input should be on the bottom on their Supercoolers if the connections are on the side. Seems fill from the bottom would ensure the cooler is filled where top feed maybe not. Come to think of it I guess it would depend on the type cooler. Tube and fin wouldn't matter where on a stack plate cooler it might.
Cliff
USN Ret., FPD Ret.
Re: 6L80e fluid return line [Re: userfriendly] #4486250
08/12/17 01:05 AM
08/12/17 01:05 AM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
The cooler feed/out is the TOP cooler line, The BOTTOM line is the return/lube on a 6L80E WHERE they come out of the bellhousing.
2001 Chevy Camaro L92/4L80E
Re: 6L80e fluid return line [Re: cb4017] #4486254
08/12/17 01:37 AM
08/12/17 01:37 AM
BC, Canada
BC, Canada
Me bad, I do T350s & 400s bottom feed to cooler "in" at top of rad, bottom of rad return to top line on transmission.
Re: 6L80e fluid return line [Re: userfriendly] #4486255
08/12/17 01:47 AM
08/12/17 01:47 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Now you guys got me all kinds of confused. ???
Re: 6L80e fluid return line [Re: Merkava_4] #4486272
08/12/17 03:30 AM
08/12/17 03:30 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Usually the bottom of the radiator cooler is the inlet. You want the fluid in the cooler longer so the heat is transfered. If it flows too quickly(from top to bottom), the transfer of heat is minimized. On my Buick, the bottom line was the fluid source into the radiator cooler.Not to be confused with the coolant which has far less pressure behind it.
The "thinking" man's friend.
Re: 6L80e fluid return line [Re: cb4017] #4486282
08/12/17 04:50 AM
08/12/17 04:50 AM
BC, Canada
BC, Canada
I just R&R'd a couple of T350s 'n 400s a month ago. Before pulling them, I disconnected the top line from the radiator, put a hose on the end into a 5L oil jug and started the engines.
I got about 3 liters out that way, which otherwise would have ended up on the ground or driveway.
If in doubt, take both lines off with hoses into containers.
Re: 6L80e fluid return line [Re: cb4017] #4486293
08/12/17 05:14 AM
08/12/17 05:14 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Find the line on the transmission from this slightly outdated chart and follow it to the radiator if in doubt.
Re: 6L80e fluid return line [Re: cb4017] #4486373
08/12/17 07:37 AM
08/12/17 07:37 AM
socal
barkingspider Offline
socal
Fluid goes into the cooler on the bottom and out from the top on the GM trucks I've owned. 6.0, 5.3 and 4.8
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 6L80e fluid return line [Re: Trav] #4486435
08/12/17 08:48 AM
08/12/17 08:48 AM
Northern Nevada
Northern Nevada
I found this chart. I also found others that indicated the opposite, hence my confusion. Guess I'm going to have to pull a line and do the bucket test. If it matters my transmission is supposed to be a 2013.
Cliff
USN Ret., FPD Ret.
Re: 6L80e fluid return line [Re: cb4017] #4487857
08/13/17 08:03 PM
08/13/17 08:03 PM
Fort Worth, Texas
Fort Worth, Texas
#8, Cooler Feed (Fluid OUT to cooler) Top line at the transmission.
#9, Center Lube (Fluid RETURN from cooler) Bottom line at the transmission.
I checked a 6L80E GM service manual & a 6L80E ATSG manual, Same picture in both!
All GM/Hydramatic RWD units are this way with the exception of the TH200 & 200-4R which are backwards.
Late 4L80E's have Front & Rear cooler lines, Front is feed, Rear is return.
Re: 6L80e fluid return line [Re: cb4017] #4488798
08/14/17 09:17 PM
08/14/17 09:17 PM
Northern Nevada
Northern Nevada
Awesome! Thank You Sir.
Cliff
USN Ret., FPD Ret.
