air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
39 registered members (carlprop, csandste, clinebarger, Ag76, Bailes1992, czbrian), 749 guests, and 64 spiders.
Topics286,440
Posts4,908,215
Members67,622
Most Online2,967
Mar 10th, 2019
Question about metal in rear differential #4485715
08/11/17 01:03 PM
08/11/17 01:03 PM
Texas
smithrob9999 Offline OP
Texas
Hello all, I've been following the board for ar least 10 years and appareciate all the information. I keep all my vehicles at least 15 years so oil is very important to me. I generally use Amsoil or Mobil 1. My pickup is an 05 Silverado, 150,000 miles, 5.3, 4L60E, 8.625" 10 bolt rear end. It's been an excellent vehicle for me and I plan to keep it 500,000 miles as I believe the iron block LS engines are some of the best ever made. I live in Texas so I currently run Amsoil Signature 10w30 with either a Wix XP or Amsoil EA15K32 filter.
I know it's well overdue but I finally pulled off the cover and drained the rear differential fluid. The fluid itself was mostly black with a hint of amber. There were no large shavings but what appeared to be shiny sand on the magnet and cover. I cleaned the gasket off and cleaned everything else as good as I could. I put it back together with a Fel Pro gasket and Amsoil Severe Duty 75w90. There were no noises or anything like that from the axle, I just don't really know what's normal. The job was pretty easy so I've considered running it 10,000 miles and changing it again to ensure the cleanest oil possible. The whole job only ran a little over $40 plus my time. I can be a bit OCD about these things
Re: Question about metal in rear differential [Re: smithrob9999] #4485717
08/11/17 01:06 PM
08/11/17 01:06 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
I don't think it's uncommon to find metal paste stuck to the magnet. The time to worry is when it feels gritty when rubbed between finger and thumb.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Question about metal in rear differential [Re: smithrob9999] #4485718
08/11/17 01:07 PM
08/11/17 01:07 PM
Texas
4WD Offline
4WD  Offline
Texas
That was first change of gear oil?
Re: Question about metal in rear differential [Re: 4WD] #4485722
08/11/17 01:11 PM
08/11/17 01:11 PM
VA
Gebo Offline
Gebo  Offline
VA
That was the first change of gear oil for a self described OCD?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Question about metal in rear differential [Re: Gebo] #4485726
08/11/17 01:15 PM
08/11/17 01:15 PM
Texas
4WD Offline
4WD  Offline
Texas
That would be me - 3rd gear oil (Delvac 1) in my GMC with 68k and next fill on the shelf ...
Re: Question about metal in rear differential [Re: Gebo] #4485727
08/11/17 01:16 PM
08/11/17 01:16 PM
Texas
Texas
Yea, crazy huh. Out of sight out of mind. I should have been more clear. I'm OCD about oil changes, buying the best oil and filter, etc. I've mostly owned front wheel drive cars so it was less of a concern
Re: Question about metal in rear differential [Re: smithrob9999] #4485729
08/11/17 01:17 PM
08/11/17 01:17 PM
Texas
4WD Offline
4WD  Offline
Texas
I'd still put 30k on the new gear oil - that's good stuff right there ...
Re: Question about metal in rear differential [Re: smithrob9999] #4485730
08/11/17 01:17 PM
08/11/17 01:17 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
The first time is always nasty.
My Dodge I changed at 3000 miles and it was nasty silver looking yucky stuff. Since it's always been new looking.
Dodge requires 15,000 mile rearend oil changes with Synthetic 75w90 which is crazy but it always looks new compared to the 1st one.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Question about metal in rear differential [Re: 4WD] #4485732
08/11/17 01:19 PM
08/11/17 01:19 PM
Texas
Texas
Since is put it off for so long I'm kinda going the other way now. Making sure I've got the cleanest oil possible in there. This is the first time I've ever done it, so there was fear of the unknown. Now that I know it's pretty easy I feel much more comfortable about it.
Re: Question about metal in rear differential [Re: smithrob9999] #4485733
08/11/17 01:20 PM
08/11/17 01:20 PM
VA
Gebo Offline
Gebo  Offline
VA
Well, with this information, I wouldn't be concerned in the slightest. I get goop on my magnet at 50K miles and I always used either Amsoil or RL.
I'd go 50K and change it again with the Amsoil. You may want to ask around and see if anyone thinks it would be better to go with a higher viscosity.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Question about metal in rear differential [Re: Panzerman] #4485736
08/11/17 01:21 PM
08/11/17 01:21 PM
Texas
4WD Offline
4WD  Offline
Texas
10-4 ... to minimize my OCD claim - I'm an early changer on rear ends - almost always get the metal flake look on first dump and swap in an easy to use (drain/fill/level) aluminum cover ...
Re: Question about metal in rear differential [Re: smithrob9999] #4485742
08/11/17 01:25 PM
08/11/17 01:25 PM
Texas
4WD Offline
4WD  Offline
Texas
The biggest fear gets overlooked - some housings dump from the cover - but fill from the heavy casting.
You should always soft break that fill plug plug before you "loose the juice" ...
Re: Question about metal in rear differential [Re: Gebo] #4485745
08/11/17 01:27 PM
08/11/17 01:27 PM
Texas
Texas
Yea, I was wondering about that. Being in Texas I think maybe 75w140 would give me a better margin of protection. To be honest the Amsoil 75w90 looked fairly thin for that grade of oil
Re: Question about metal in rear differential [Re: smithrob9999] #4485751
08/11/17 01:31 PM
08/11/17 01:31 PM
VA
Gebo Offline
Gebo  Offline
VA
At least to the 75w-110
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Question about metal in rear differential [Re: smithrob9999] #4485758
08/11/17 01:35 PM
08/11/17 01:35 PM
VA
Gebo Offline
Gebo  Offline
VA
Actually, if it were me, I'd run that gear oil about 5K and swap it out for a thicker grade. That way you have cleaned all the leftover gunk out. Yeah, I know how much it cost per quart. In that big ol' truck of yours, I'd run the 75w140.
I realize that contradicts my 50K comment above but that first comment was based on rational thought. My last comment was based on my heart.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
