Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
59 registered members (alphadog, Ag76, ArrestMeRedZ, AlaskaMike, advocate, ABomb369, 5 invisible), 1,156 guests, and 32 spiders.
Topics290,696
Posts4,848,415
Members66,021
Most Online3,590
Jan 24th, 2017
1996 F150 fuel pump noise #4485657
08/11/17 11:59 AM
08/11/17 11:59 AM
TN
terry274 Offline OP
terry274  Offline OP
TN
I have a 1996 F150 shortbed with a 302 engine and automatic transmission. It has a single tank. The truck has 132000 miles and I have owned it for two years. I have replaced the inline fuel filter.
Today I heard a buzzing noise coming from the truck while it idled in my driveway. Crawling under the truck I pinpointed the noise as coming from the fuel tank. It sounds like florescent lights when they are cold and hum.
So it seems as if the fuel pump is dying. Since I don't want to be stranded on the side of the road I plan on replacing the pump soon.
My question is, do you recommend any particular brand? Any to avoid?
Do you have any tips to make the job easier? I plan on removing the tank, not the bed.
Thanks,
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 1996 F150 fuel pump noise [Re: terry274] #4485686
08/11/17 12:34 PM
08/11/17 12:34 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Please not an AIRTEX!!!!!!!! I've had good luck with Denso and OEM (from the dealership) the original pump lasted 21 years, why not buy another?
Luke
Re: 1996 F150 fuel pump noise [Re: terry274] #4485695
08/11/17 12:41 PM
08/11/17 12:41 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I just replaced both fuel pumps on my 1995. I got the spectra premium. I got a tank/pump combo for the front since the old tank had tar in it from years of bad gas. The new rear pump was defective from the box. it worked but not well. I had to redo it. Also the tank seal that came with the new pump was too big and wouldn't seal the pump to the tank. I had to buy a new seal and lock ring from the parts store for an additional $20. I gots replacement spectra and so far so good. I think removing the bed would be easier but you'll need a friend. I ended up removing my bed three times this year for the fuel pumps to get them sorted. The front tank died at maybe 10 years old and was the oem. The rear pump was an airtex that lasted about 10 years so I suppose they all last about the same but spectra costs way less than motorcraft
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 1996 F150 fuel pump noise [Re: terry274] #4485696
08/11/17 12:41 PM
08/11/17 12:41 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I do not own a Ford , but I have replaced fuel pumps on GM cars . On them I could replace just the pump or the whole assembly with the fuel level sender .
If I ever have to do it again , I will seriously consider the latter .
For yours , I would consider how hard it is going to be to drop the tank , then decide whether to buy a Ford pump or an after market pump .
Shop around the internet to try to find the best price .
One thing I can absolutely recommend it to drive it until the tank is almost empty . The tamk will weigh much less than a full tank .
I used a piece of plywood about 2' x 2' and a floor jack to help lower the tank & then raise it back up into place .
Best of luck , :-)
Wyr
God bless
Re: 1996 F150 fuel pump noise [Re: E150GT] #4485705
08/11/17 12:52 PM
08/11/17 12:52 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
I replaced the fuel sender on a Pontiac and had the same "seal too big" problem. I reused the old seal/oring part. The fuel sender I used was from Dorman.
Rockauto has Denso pump that fits my truck for $125. That's what I'm leaning towards right now.
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 1996 F150 fuel pump noise [Re: terry274] #4485804
08/11/17 02:27 PM
08/11/17 02:27 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Bosch or Denso.
Do NOT buy the "cheapest one available". They suck to replace &
always fail right in the middle of a rainstorm/snowstorm,
Far, far from home,
right after filling the tank completely full of fuel.
Re: 1996 F150 fuel pump noise [Re: terry274] #4485823
08/11/17 02:44 PM
08/11/17 02:44 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
IMO as a best practice NEVER let your fuel level in the tank drop too low! I would say at least 1/4 tank is good as The gas cools the pump. If you constantly run it empty and then put another $10 in the pump wont last as long. My last ford OEM pump quit at 190K
Re: 1996 F150 fuel pump noise [Re: Kawiguy454] #4485827
08/11/17 02:58 PM
08/11/17 02:58 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The pump is cooled by fuel running through the INSIDE of the pump, not by being submerged. And for the pump to be submerged, you would need to keep the tank above half full at all times, the actual pump is often near the top of the sending unit.
I always run my tanks to near empty and have never had a pump fail.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 1996 F150 fuel pump noise [Re: WyrTwister] #4485952
08/11/17 05:39 PM
08/11/17 05:39 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
go oem pump only! Don't drop the tank. lift the bed. it's much faster and easier.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1996 F150 fuel pump noise [Re: terry274] #4485959
08/11/17 05:48 PM
08/11/17 05:48 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
i just installed a delphi pump and housing in my 96...good quality and actually runs the high pressure a 4.9 needs. rockauto has a good selection. you wont need the sender really unless you want to replace it anyway.
that being said, many ford pumps are loud and i wouldnt replace based just on noise. check fuel pressure, and see if it rises 7 or so psi with vacuum disconnected from the regulator or snapping the throttle. if pressure is in spec, the pump is healthy.
2013 escape 2.0 awd
2008 fusion 2.3 mtx
1996 f150 4.9 2wd mtx
1999 kaw zrx 1100
many husqvarnas
Re: 1996 F150 fuel pump noise [Re: mightymousetech] #4486053
08/11/17 08:11 PM
08/11/17 08:11 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
[/quote]
Give this man a ceegar, he's right.
The "thinking" man's friend.
Re: 1996 F150 fuel pump noise [Re: terry274] #4486129
08/11/17 09:43 PM
08/11/17 09:43 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Relatively low frequency hum suggests an unbalanced pump motor. The gyration caused by an unbalanced armature will cause such a sound. Maybe not a sign of failure per se, but unbalanced anything is somewhat concerning for longevity.
Re: 1996 F150 fuel pump noise [Re: terry274] #4492178
08/18/17 06:35 PM
08/18/17 06:35 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
Ok, here is an update to the fuel pump.
I bought a Denso (made in the U.S.A) from Amazon for $108 and a Motorcraft sending unit from Rockauto for $124.
I dropped the tank rather than removing the bed because I wanted to take the tank and clean it out. I will never remove the tank that way again.
I put it all back together today, put 5 gallons of gas in to get me to the store. Got to the store and filled up. Gas went everywhere. Got back home and discovered I had not gotten the fuel filler pipe back on the tank correctly. The smaller hose was in the tank fine, but the bigger vent hose was not all the way on and the clamp caused it to gap open.
Spent a few minutes removing the bed bolts, taillights and tailgate. Raised the bed and slid a 4x4 block of wood between the frame and the bed. I could then easily reach the filler hose and get in on the tank properly. I then put the bed back in place and reinstalled the trailer hitch that I had to remove to drop the tank originally.
It's all good now, I have a full tank of gas and no leaks, the truck runs great.
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 1996 F150 fuel pump noise [Re: terry274] #4492214
08/18/17 07:05 PM
08/18/17 07:05 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Congrats ! :-)
Wyr
God bless
Wyr
God bless
