CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
70 registered members (alarmguy, Amenhotep, antik, Anthony, 2015_PSD, 4WD, 7 invisible), 838 guests, and 30 spiders.
Topics287,675
Posts4,932,065
Members67,838
Most Online2,967
Mar 10th, 2019
Consumption issues with Havoline Pro DS 10w30? #4485431
08/11/17 08:14 AM
08/11/17 08:14 AM
Indiana
rrwildlife Offline OP
Indiana
Hi all,
Has anyone experienced oil consumption issues with Havoline Pro DS 10w30? I bought some of the clearance oil from O'Reilly and used this on the last oil change in my 03 Toyota Matrix. 2800 miles on the oil and I had to add 1/2 qt. This seems strange to me, I have never had to add oil between 5000 mile oil changes since owning the car. It currently has 105,000 miles on it. The two previous oil changes were Cheveron Supreme 5w30 and I had no consumption issues. Since they are manufactured by the same company I would assume the add packs, etc would be similar. I'm not too concerned about it but found it weird. Just wondering if anyone else has witnessed the same thing. I will need to watch my oil level a little closer going forward. I have a 60 qt stash of the 5w/30 Pro DS so the plan is to switch to that and keep using it.
Thanks
Ryan
2003 Toyota Matrix - 133,000 Havoline Pro DS 5w30 Bosch Distance+
2005 Toyota RAV4 - 136,000 Chevron Supreme 5w30 Bosch Distance+
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485450
08/11/17 08:28 AM
08/11/17 08:28 AM
Maryland
timeau Offline
timeau  Offline
Maryland
Check PCV first.
2013 Toyota Camry XLE V6
2012 Honda Accord EX-L V6
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485457
08/11/17 08:35 AM
08/11/17 08:35 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I recently noticed a half quart of consumption with the 05 Matrix when switching to 10w30 Castrol Edge EP 10w30. This was over 1200 miles. The oil was dark from the start and I contacted Castrol about it. They said to change it out which I did. I may have purchased used motor oil at Walmart. I sent the jug with the left over oil and they are investigating.
In your case I would keep using the Havoline Pro DS. Sometimes it takes a few intervals of a new oil for the consumption to stop. Esp with synthetics and the extra detergents they have. Same thing has been reported with some of the other synthetics, Mobil and Pennzoil namely.
As mentionted, replace the pcv valve with an oem unit. You can order here for a good price shipped:
https://metrotoyotapartsnow.com/
Re: Consumption issues with Havoline Pro DS 10w30? [Re: timeau] #4485461
08/11/17 08:42 AM
08/11/17 08:42 AM
Indiana
Indiana
Originally Posted By: timeau
Check PCV first.
Thanks for the tip!
Re: Consumption issues with Havoline Pro DS 10w30? [Re: SatinSilver] #4485462
08/11/17 08:43 AM
08/11/17 08:43 AM
Indiana
Indiana
Thanks for the link! I'll get one ordered.
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485475
08/11/17 08:54 AM
08/11/17 08:54 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
I got like 7 jugs of the O'Reilly clearance ProDS 5W-30 Synthetic and have used some of it in various vehicles, even of higher miles, no consumption issues or any other problems to note, and just like you some of those vehicles were previously running Chevron Supreme from Costco.
2010 Ford Escape 2.5 ~95K Miles
Royal Purple 5W-30 ~ Wix 51348
1995 Chevy K1500 5.7 ~277K Miles
Delo 10W-30 ~ ACDelco PF52
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485490
08/11/17 09:03 AM
08/11/17 09:03 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Check PCV first.
People always say that but what does a bad PCV look like ? grin
Re: Consumption issues with Havoline Pro DS 10w30? [Re: Merkava_4] #4485508
08/11/17 09:17 AM
08/11/17 09:17 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Check PCV first.
PCV is a one way valve.
If you blow in it, it can only pass the air one way.
If air comes out if you blow from both end (one at a tiem), then it is bad.
You can check Youtube and they have a lot of video on how to check PCV.
  • 2017 Toyota Sienna
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485538
08/11/17 09:47 AM
08/11/17 09:47 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Some of the 10w30s have rediculous (sp) noacks.
Go to pqia and see if they tested it.
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485549
08/11/17 10:01 AM
08/11/17 10:01 AM
California
Errtt Offline
Errtt  Offline
California
I've had some oils in the same grade have more consumption. Sometimes it takes a few OCIs and the consumption settles down a bit. If not, back to the previous or something else.
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485574
08/11/17 10:17 AM
08/11/17 10:17 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I changed my oil before a long road trip which I just completed with Havoline ProDS 10w30 in a Dodge 2500 with the5.7 Hemi and used a little over a 1/2 qt. The truck never used oil between changes but that was hard running non stop. Over 1000 miles with only fuel stops and food stops. About 3000 miles total.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Consumption issues with Havoline Pro DS 10w30? [Re: Merkava_4] #4485615
08/11/17 10:59 AM
08/11/17 10:59 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Most of the time, it's because the spring gets weak or breaks.
I haven't seen a "sludged" PCV valve since the early 90's
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485702
08/11/17 12:49 PM
08/11/17 12:49 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
If only the nagging Toyota Class Action lawsuits for engine oil burning could go away with a simple PCV valve change. Perhaps the piston rings have finally enameled themselves.
There's no replacement...'scosity for natural viscosity
Re: Consumption issues with Havoline Pro DS 10w30? [Re: Merkava_4] #4485712
08/11/17 12:57 PM
08/11/17 12:57 PM
VA
Gebo Offline
Gebo  Offline
VA
Check PCV first.
I'm with you....
I just replace mine whenever I remember to...Like every couple of years on those days I get in an anal mood. Always makes me feel better for about 10 minutes.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Consumption issues with Havoline Pro DS 10w30? [Re: rrwildlife] #4485863
08/11/17 03:50 PM
08/11/17 03:50 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
As others have said, if you were using conventional oil and then switched to full synthetic (most brands), you may see some temporary consumption through one or two oil changes. Happened to me with Quaker State Ultimate 5w-30. Nothing to worry about.
2017 Honda Odyssey SE, 19K
2013 Honda Accord LX, 60K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
