Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
ariefnrst, tcoffin014, Schm1d, EagleC, Dinka
66655 Registered Users
88 registered members (2009Edge, aquariuscsm, A310, Ag76, aba4430, 13 invisible), 1,713 guests, and 36 spiders.
Topics294,970
Posts4,925,094
Members66,655
Most Online2,553
Oct 27th, 2018
SUBARU UPPER ENGINE CLEANER DISADVANTAGES? #4484320
08/10/17 05:44 AM
08/10/17 05:44 AM
Australia
Colin01 Offline OP
Colin01  Offline OP
Australia
IM DOING A MAJOR SERVICE(FOR A FRIEND) ON A 2003 HYUNDAI ELANTRA WITH 1.8L ENGINE CAR HAS APPROX 100K (KILOMETERS) REASONABLY LOOKED AFTER. No obvious issues.
I WAS THINKING OF USING SUBARU UPPER ENGINE CLEANER TO CLEAN OUT COMBUSTION CHAMBERS, MANIFOLD,THROTTLE BODY. I DON'T WANT TO CAUSE ANY FURTHER ISSUES( Eg: damaged 02 sensor or clean up too good and cause oil consumption issues)
Is this stuff safe to use? Should i use or leave it?
Also, im planning on using a oil flush (Nulon). Is this stuff really needed
Thanks
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Colin01] #4484325
08/10/17 05:48 AM
08/10/17 05:48 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I'm of the type that if it has no issues don't do anything to it.
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Colin01] #4484340
08/10/17 06:07 AM
08/10/17 06:07 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The Subaru stuff is safe and a soak will help if you have pinging due to excessive carbon buildup otherwise it makes no sense to remove the protective layer of carbon from piston tops.
If there is no sludge or build up you don't need a flush either use a high quality with a decent calcium content to clean the internals. Just use a TB spray cleaner for the throttle body and a MAF specific cleaner or electronics cleaner (do not use carb cleaner) for the MAF sensor if it has one.
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Trav] #4484351
08/10/17 06:19 AM
08/10/17 06:19 AM
wv
krismoriah72 Offline
wv
Since you said "no obvious issues" and 'for a friend'... i wouldnt risk doing anything other than what it needs. If an issue arises down the road you will most likely be blamed and be on the hook for repairs. Perhaps things are different where you are than here in the US.
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Colin01] #4484357
08/10/17 06:27 AM
08/10/17 06:27 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Unless there's a problem I wouldn't do anything, especially for a friend. If something happens after you'll be the guy that did it.
God Bless Our Troops
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Colin01] #4484398
08/10/17 07:21 AM
08/10/17 07:21 AM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
My dad ( long ago deceased) used to always say" If it's not broken, then do not fix it until it is"
Use a top tier gasoline Many many brands (Shell, mobil, Exon, Conoco, Co Op, Cenex etc, which already has all of the additives and detergents needed to keep the fuel system and it's components in good shape.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: BJD78] #4484570
08/10/17 09:58 AM
08/10/17 09:58 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I was getting a fair amount of pinging in the 05 Matrix and did what Trav recommended in another thread. Run one interval of Techron Fuel System cleaner or Gumout Regane cleaner for one interval. I went with the Regane High Mileage cleaner since Techron was out of stock. Then follow up with an interval of B12 Chemtool. About $5 and $4 respectively at Walmart. Completely solved the pinging problem. Thank you Trav!
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: SatinSilver] #4484585
08/10/17 10:13 AM
08/10/17 10:13 AM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
I read somewhere a while back that Polyether Amine is a substituted Nitrogen molecule....in other words the chemical in Techron detergent, the same type of chemistry Shell puts in it gasoline for free. I suppose dumping in a bottle of Techron after filling up with a non top teir gasoline would suffice. Not sure if one is using a top teie gas and still dumping in a bottle of Techron or fuel cleaner would do much other that lighten the wallet.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: krismoriah72] #4501093
08/29/17 08:03 AM
08/29/17 08:03 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
I agree. The Upper engine cleaner isnt really needed unless it is something serious requiring it. To be honest I would stick with cleaning out the throttle body, MAF sensor, make sure the air filter is in good shape. Even throw in a fuel system cleaner if you want but for a friend I wouldn't go nuts. I am sure even just doing what I said would give your friend a good "butt dyno" feeling.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: SUBARU UPPER ENGINE CLEANER DISADVANTAGES? [Re: Colin01] #4501207
08/29/17 10:23 AM
08/29/17 10:23 AM
New England
Virtus_Probi Offline
New England
My take is that the main application for this stuff is DI engines in which the intake valves are not washed by fuel and whatever cleaners might be present in it.
I have used Subaru Top Engine Cleaner as well as Subaru Carbon Clean using the associated cleaning tool, which screws into the bottle and plugs into a vacuum line via a cone-shaped attachment. I understand that the Australian product comes in a spray can, not sure what the reason for the different delivery method is?
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
