Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
99 registered members (97f150, addyguy, ABerns, 65convertible, 11 invisible), 2,319 guests, and 59 spiders.
Topics286,013
Posts4,900,727
Members67,545
Most Online2,967
Mar 10th, 2019
Foam Filter #4484246
08/10/17 03:14 AM
08/10/17 03:14 AM
Australia
Wreckage Offline OP
Wreckage  Offline OP
Australia
Thought I would start a new thread relating to foam filters...
As I am trying to decide between paper/cotton gauze style filter... I came across a company in Australia called Uniflow.
They make foam filters for vehicles.
I tried to do some research online... apparently foam filters filter the best and due to the cellulose nature of them they also provide air flow as good as cotton gauze.
So it is like a K&N air filter in terms of air flow/performance but filters much better (or better) than even paper filters.
Anyone know anything about these?
According to this: http://www.uniflow.com.au/contents/en-us/d358_How_Unifilter's_Work!.html
It is a no brainer...
Anyone?
Re: Foam Filter [Re: Wreckage] #4484249
08/10/17 03:32 AM
08/10/17 03:32 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I can tell you that Uni is all I use for my motorcycles, dirt bike, and scooters without any issue.
I'm pretty sure there isn't a dirt bike made with any other kind of filter.
I'd be hard pressed to believe they filter better than the best paper filters, but I would believe they have an advantage in flow and at least match them.
Re: Foam Filter [Re: Wreckage] #4484252
08/10/17 03:36 AM
08/10/17 03:36 AM
Australia
Wreckage Offline OP
Wreckage  Offline OP
Australia
I am also very interested to see what people think of this:
http://blog.perrinperformance.com/foam-filter-qa-why-they-are-the-best/
How much truth is there to this?
I been reading K&N's 'facts' page about how filters work and why they do work better than paper etc (independent lab tests and bla bla) and they got a nice diagram why foam filters are bad compare to theirs...
Those exact diagrams are on the page I just posted and explanations of why that is dribble about foam filters etc...
Anyway, if someone can scan through that link... how much truth is there to it?
If Foam is going to at least filter as good (maybe a touch worse) than paper but definitely a lot better than cotton gauze and still flow as good as a K&N... then well I would go that. I get the benefits of both without sacrificing either.
Re: Foam Filter [Re: Wreckage] #4484257
08/10/17 03:57 AM
08/10/17 03:57 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Used on every dirt bike since the begining of time. They collect more dirt than any paper filter I've seen. I used to service quad bikes, in every 3 months, and the foam filter was always a mess, covered in dirt.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Foam Filter [Re: Wreckage] #4484261
08/10/17 04:04 AM
08/10/17 04:04 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: Wreckage
I tried to do some research online... apparently foam filters filter the best and due to the cellulose nature of them they also provide air flow as good as cotton gauze....
Anyone?
Not knocking foam filters, in fact I thought of making one from an old mattress a while ago but was too busy.
However, while it MIGHT be possible to make a foam filter from cellulose, it'd be difficult and I'm fairly sure no one does.
I think they're usually polyurethane.
Re: Foam Filter [Re: Wreckage] #4484268
08/10/17 04:40 AM
08/10/17 04:40 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
You can buy filter foam in sheets, I've often made new ones when an old foam filter goes rotten and falls apart, and is not made anymore. They need more maintenance than paper or K&N, and it's a messy job.
Re: Foam Filter [Re: Wreckage] #4484271
08/10/17 04:50 AM
08/10/17 04:50 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I'd say they tend to exaggerate the performance and fuel economy impact of filter restriction, which actual measurements show is rather limited, but I suppose you have to do that if you are selling a "performance" filter.
I was thinking I'd "get the benefits of both without sacrificing either" by using both, running my DIY foam as a prefilter. That way I shouldn't be able to screw up too badly.
I have some doubts about the washability thing with a single stage filter. Seems it'd be quite easy to transfer relatively coarse damaging particles from the outside to the inside if you weren't ultra careful.
Re: Foam Filter [Re: Wreckage] #4484295
08/10/17 06:15 AM
08/10/17 06:15 AM
NY
DdDd Offline
DdDd  Offline
NY
You DO realize there was the mother of all amateur air filter studies posted right on the front page of this site yes?
Long story... both the gauze and the foam let more dirt in than a good paper. On a dirt bike this is moot anyways since the most important thing is how often you can replace with a clean filter. Which at OEM prices would get really expensive fast every few rides!
In a street vehicle not worth the time. Use a disposable filter. Especially when you consider that modern OEM filters aren't really plain paper anymore, they're doing this "fleece" thing that probably works the best. AAAAAND the air box has been optimized to squeeze every last drop of power and FE from the motor.
Warranty? It's a heck of a way to lose coverage for related issues. Everybody likes to quote the Magnuson Moss warranty act but they quote it incorrectly.
In short: vehicles have LIMITED warranty, which offers a surprising amount of legal loopholes. Also while an OEM cannot force the use of a particular BRAND they are more than welcome to deny a claim for using parts not meeting SPECIFICATION. At that point (especially with the arbitration agreement) you are essentially S.O.L.
Re: Foam Filter [Re: Wreckage] #4484300
08/10/17 06:26 AM
08/10/17 06:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Wreckage,
I have a lot to say about all filter types - but I must ask, what are the goals you are trying to achieve?
1) Cost,
2) filtration, or
3) flow?
You can ONLY pick 2 of the 3, BTW.....
Re: Foam Filter [Re: Wreckage] #4484332
08/10/17 06:55 AM
08/10/17 06:55 AM
ST Augustine, FL
exShuttlemech Offline
ST Augustine, FL
I had a Dolmar/Makita gas powered concrete saw that had an air filter that had a foam pre-filter, and a pleated paper filter. I cleaned out the foam pre-filter after every job and blew out the pleated every once in awhile. I only replaced the pleated filter once in 14 years. No problems in 14 years, lost it in the Hurricane Matthew flood.
2010 Rav4 4cyl 131K QSUD 0W20 Baldwin bypass filter
2003 4Runner 4.0L 219K 0W40 M1 Frantz bypass
2007 F150 4.2L 169K 5W30 QSUD
2016 NV2500
2017 RAV4
Re: Foam Filter [Re: Linctex] #4484401
08/10/17 08:23 AM
08/10/17 08:23 AM
Australia
Wreckage Offline OP
Wreckage  Offline OP
Australia
Originally Posted By: Linctex
Wreckage,
1) Cost,
2) filtration, or
3) flow?
Well to keep it short...
1 and 3 so that I can enjoy the car more for the life it will have.
Having said that...
Most people I know that have toyotas have over 600,000-700,000 km on their engine and the car is still good. That is 435,000 miles on paper filters.
So wanting an alternative for flow and cost (reusable), ho much of that life will I prematurely wear out (if it even will?).
If I will lose 200,000 miles off the life of engine using foam/K&n then I will stick to original. If it will only be 50,000 miles, then I prefer the flow/cost (option 1 and 3)
Re: Foam Filter [Re: Ducked] #4484440
08/10/17 09:06 AM
08/10/17 09:06 AM
USA
ArcticDriver Offline
USA
I agree they overstate.
I see no independent testing to support the claims UNI are an advantage and they are a PIA to clean compared to my quality paper filters which I simply remove and toss out. If UNI is so great then which high dollar sports car manufacturers use them in their cars?
Multiple Diesel and Gasoline vehicles
Re: Foam Filter [Re: exShuttlemech] #4484445
08/10/17 09:11 AM
08/10/17 09:11 AM
USA
USA
Well this is great news for everyone that drives a gas powered concrete saw to work. grin
But maybe diffcult to equate it in practical terms to a vehicle.
Re: Foam Filter [Re: Wreckage] #4484493
08/10/17 09:47 AM
08/10/17 09:47 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
The best filtration is provided by a Donaldson PowerCore filter, which is 99.98%. However, OEM paper filters do generally filter well. If you aren't using a restriction gauge, you are probably changing your filter far too early, driving up the cost. I'd run factory unless I was putting in a Donaldson. Change it based on the filter minder/restriction gauge.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Foam Filter [Re: ArcticDriver] #4485305
08/11/17 02:21 AM
08/11/17 02:21 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Dust is dust. Ashes are ashes.
