2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
66 registered (91camarosRS, 1foxracing, 69Torino, advocate, adamrc, AndyB, 6 invisible), 1230 Guests and 38 Spiders online.
65265 Members
67 Forums
285582 Topics
#4484211 - 08/09/17 11:41 PM Machinery Failure UOA / VOA comparison
SubieRubyRoo Offline
Loc: Winchester, Indiana
So we had a mechanism fail at work yesterday (glass container manufacturing) and when it was disassembled, there was like a black sludge in it. This mechanism is exposed to consistent 350-400*F temps, possible glass and glass batch mixture contaminants, and 24/7/365 operation. It gets 15 minute oiling thru a central lube system, and as is typical of all things German, it has a spec oil- in this case Klubersynth HM2-220. As with all things German, we pay a hefty premium for this oil compared to other alternatives, and the VOA shows there is literally nothing other than phosphorus in it! This is my first personal industrial UOA, so I don't know for sure, but the flashpoint doesn't really look that great considering the environmental temps it sees. Just thought I'd share these for grins...
#4484219 - 08/10/17 12:03 AM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
zeng Online   content
Loc: Malaysia
What's gear rpm and pitch diameters of input shaft and output shaft gears respectively ?
Plain (failed) bearing diameters ?
#4484227 - 08/10/17 12:14 AM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
None of the above. This is a steel shaft which makes a 90* rotation about every 6 seconds... moves down about 14 inches, stays 2.5-3 seconds, then back up. Bronze bushing between the shaft and housing. There is a cam-roller in the base that provides a stop at each end and the rate of height change.
#4484230 - 08/10/17 12:27 AM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
zeng Online   content
Loc: Malaysia
Huuh..... intermittent oscilating mechanisms, traveling 28 inches per 3 seconds or so.
EP220 appears inadequate, I guess.
Keep bearing clearances at below 0.3mm would help.
#4484321 - 08/10/17 06:45 AM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
Linctex Offline
Loc: Waco, TX
Is this interval adequate?
#4487196 - 08/13/17 10:26 AM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
Mainia Offline
Loc: Upper midwest
Call Summit Industrial Oil (A Kluber Company) in Texas and talk to Thomas Knight, he is the R&D chemist. Just because they spec that oil doesn't mean there are 1 to 2 tier up better oil for this application. From what I checked out on your oil it is a PAO/Ester Blend. See if there is a full Ester oil that would work. You may have to kidney loop with a 2000 Beta Donaldson filter.
Also see what a full Ester base does that a PAO/Easter cant do here. Both Summit/Kluber oil, but in a different application I had.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4487172/A_fix_for_our_Atlas_Copco_varn
#4493974 - 08/20/17 08:00 PM Re: Machinery Failure UOA / VOA comparison [Re: SubieRubyRoo]
Mainia, there is no way to filter this oil, it is an 'open loop' application. The oil goes into the mechanisms, and at some point oozes out, runs down the machine into the basement, and is collected into the skimmer pond that cleans the recirc water.
It sounds like because of the cost ($40/gal) we are going to go to a Chevron lube at $7/gal and bump up the oiling frequency and volume to 'flush' the contaminants from the system vs. using the Kluber.
