Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
89 registered members (ARCOgraphite, aquariuscsm, AdditiveOCD, 2015_PSD, 209paulc, 64bawagon, 12 invisible), 1,647 guests, and 67 spiders.
Topics286,446
Posts4,908,426
Members67,626
Most Online2,967
Mar 10th, 2019
Ford Mercon LV fluid change #4484069
08/09/17 08:26 PM
08/09/17 08:26 PM
WV
loneryder Offline OP
WV
I have a MH on a 14 Ford E350 chassis with the V-10 and automatic trans. The trans pan has a drain plug in it. It has 20k of hard use so I thought about just draining and replacing the fluid with out dropping the pan. Does anyone have an idea how much fluid will drain from the pan? Looks like I have to order the Motorcraft fluid in a case of 12 qts.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484084
08/09/17 08:40 PM
08/09/17 08:40 PM
USA
slacktide_bitog Offline
USA
The amount you drain can vary, so just get a measuring pan or something. Motorcraft is good, but there are many officially-licensed Mercon LV fluids out there that may be priced less than Motorcraft smile
Re: Ford Mercon LV fluid change [Re: loneryder] #4484092
08/09/17 08:47 PM
08/09/17 08:47 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I've done a drain and fill in my fusion and it took about 4.5qt. Total capacity of the tranny is 9qt
I would think a case would get you at least one drain and fill.
I tried some googling and didn't have any luck. My best guess is a 15qt total capacity and you'll get half of that out.
I'd call the dealer or invest in a Haynes manual or similar
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Ford Mercon LV fluid change [Re: loneryder] #4484104
08/09/17 09:02 PM
08/09/17 09:02 PM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
You can buy Motorcraft LV fluid at O'Reillys, if you have those nearby. You can also buy it from the dealer obviously and they shouldn't require you to buy a full case.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484105
08/09/17 09:04 PM
08/09/17 09:04 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Get an empty gallon milk jug or two and your measuring cup and start filling it up and marking the outside of the jug in 4-8oz. Increments. Then drain the trans and measure what comes out with your measuring jugs.
I would guess pulling the drain plug will get you between 3 and 6 qts.
Do you have a dipstick to fill it up through?
If it were mine, I'd drain and fill the pan every other oil change or so.
There are many name brand transmission fluids that carry the mercon lv spec.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484106
08/09/17 09:07 PM
08/09/17 09:07 PM
Ohio
Ohio
Amsoil lists (2) transmissions - 4R75E and 5R110W
They say
4R75E
Initial fill - 5 quarts
Total fill - 13.8 quarts
5R110W
Initial fill - 7.5
Total fill - 18.7
Typically, 1/3 to 1/2 comes out with a drain plug drain. I guess getting 12 quarts wouldn't be a bad idea.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484119
08/09/17 09:26 PM
08/09/17 09:26 PM
MN
14Accent Offline
14Accent  Offline
MN
MH with the V10 will be the 5R110. Ford never put the 4R75 behind anything over the 4.6.
6-7 quarts sounds about right for a drain and fill.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Ford Mercon LV fluid change [Re: loneryder] #4484238
08/10/17 01:18 AM
08/10/17 01:18 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
My 5R110 takes about 7 qts for a drain & fill
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Ford Mercon LV fluid change [Re: loneryder] #4484262
08/10/17 04:06 AM
08/10/17 04:06 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Don't forget to check for a torque converter drain on that thing. You might have one, which will get you a lot more fluid out.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484341
08/10/17 07:08 AM
08/10/17 07:08 AM
MD
claluja Offline
claluja  Offline
MD
When I drop the pan and replace the filter in my F250 (has a 6R140W transmission), i get about 7.5 quarts of Mercon LV out. I'd just get the case.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: Ford Mercon LV fluid change [Re: loneryder] #4484444
08/10/17 09:10 AM
08/10/17 09:10 AM
WV
WV
Thanks all. In looking around I haven't seen any LV in other brands so I'll keep looking.
Re: Ford Mercon LV fluid change [Re: slacktide_bitog] #4484452
08/10/17 09:16 AM
08/10/17 09:16 AM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
I got a bucket at Home Depot. It's 12 qts and it has quart measurement on the inside. The Explorer does not have a dip stick so I'll drain it let the ATF cool down then put back whatever the cooled amount reads. At least the fill is easy to get to. I recently got a case of Mercon LV(12 qts)from Rock Auto, it was $60 delivered and I got it in 3 days.
Whimsey
Re: Ford Mercon LV fluid change [Re: loneryder] #4484594
08/10/17 11:23 AM
08/10/17 11:23 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Castrol Transmax Synthetic has MerconLV certification and is on sale for $5.50 per qt at Advance Auto.
Re: Ford Mercon LV fluid change [Re: loneryder] #4484769
08/10/17 01:57 PM
08/10/17 01:57 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Kendall Versatrans LV is licensed for Mercon LV and is under $5 / qt. delivered if you buy a case of 12 qts. It's what I used recently in the 6R80 in my wife's Mustang. It's made by Phillips 66 who also manufacture Motorcraft Mercon LV.
http://www.kendallmotoroils.com/kendall-versatrans-lv-automatic-transmission-fluid-atf/
https://kendallmotoroil.com/product/versatrans-lv-atf
Super Tech Full Synthetic Multi Vehicle ATF is Mercon LV licensed if produced by Warren and is $5.50 / qt. when bought in gallon jugs and $6 /qt. as individual qts.
https://www.walmart.com/ip/Super-Tech-Mu...13=&veh=sem
https://www.walmart.com/ip/Super-Tech-Mu...YvyoQG1d0HD3uuo
Pennzoil Platinum MVLV ATF is licensed for Mercon LV and is on sale for $6 / qt. at Pep Boys
https://m.pepboys.com/product/details/1162211/00840
Plenty of choices out there for licensed Mercon LV ATF.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Ford Mercon LV fluid change [Re: loneryder] #4484812
08/10/17 02:23 PM
08/10/17 02:23 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
