AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
74 registered members (2003f7, Aero540T, 2010Civic, agpatel, Aichiguy, 8 invisible), 1,298 guests, and 61 spiders.
Topics286,438
Posts4,908,166
Members67,622
Most Online2,967
Mar 10th, 2019
A/C problem, '04 GM 5.3L, Rainier CXL, 2WD #4483771
08/09/17 02:34 PM
08/09/17 02:34 PM
Georgia
DeepFriar Offline OP
Georgia
I'v been lucky over the years with no A/C problems to speak of. By virtue of that I don't know much about diagnosing problems. Now suddenly I have two out of three vehicles with problems. My old '92 SE-R just appears to have had a seal failure leak (it's held up good though since the changeover to R134A back in 2000). The Rainier auto climate control is simply taking too long to cool down but goes great guns when it does. It seems sometimes to cool a little very briefly on startup (that could be a false impression) but immediately goes warm ambient for say 2-3 minutes before "going to work". It's not the usual delay that happens with hot soak. Another possibly wrong impression is that the system can seem like it has some trouble "making up its mind" if I change modes to try to get better cooling faster. I have read that there is an expensive valve of some sort that is known to fail on these but can't find any further info. Would appreciate any help you guys might provide. Thanks.
Re: A/C problem, '04 GM 5.3L, Rainier CXL, 2WD [Re: DeepFriar] #4483826
08/09/17 03:39 PM
08/09/17 03:39 PM
USA
mk378 Offline
mk378  Offline
USA
When it is not cooling, open the hood and look if the compressor is engaged. Also feel the low side line from the accumulator tank to the compressor, it should be cold.
Re: A/C problem, '04 GM 5.3L, Rainier CXL, 2WD [Re: DeepFriar] #4483868
08/09/17 04:16 PM
08/09/17 04:16 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
If the compressor is working , throw the manifold / hoses / gauges on it and report back .
Wyr
God bless
Re: A/C problem, '04 GM 5.3L, Rainier CXL, 2WD [Re: DeepFriar] #4484108
08/09/17 09:07 PM
08/09/17 09:07 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
Read the below TSB, At your vehicles age.....It would be wise to pull the radiator & thoroughly inspect the Condenser & Radiator for blockage & clean any debris build up between the two.
Bulletin No.: 04-01-38-019A
Date: June 07, 2005
TECHNICAL
Subject:
Intermittent Slow to Cool HVAC Performance Concerns in High Ambient Temperatures and/or High Humidity Conditions After Start Up, Especially at Low Engine Speeds (Install New Engine Cooling Fan Clutch)
Models:
2004-2005 Buick Rainier
2002-2005 Chevrolet TrailBlazer Models
2002-2005 GMC Envoy Models
2002-2004 Oldsmobile Bravada
2005 Saab 9-7X
Condition.
Some customers may comment on slow to cool Air Conditioning (A/C) performance or high A/C outlet temperatures after start up or that the A/C system is not cooling sufficiently, especially in high ambient temperatures. This may be an intermittent condition and the performance of the Heating, Ventilation and Air Conditioning (HVAC) system may not meet customer expectations.
Cause.
This condition may be caused by the response of the Electro-Viscous (EV) fan clutch and can be related to airflow across the condenser. This low A/C system performance can occur for longer periods of time if the vehicle is allowed to idle or is driven in low speed conditions. The response of the EV fan clutch will affect A/C system performance. As higher road speeds are attained, the increased airflow across the condenser will usually improve A/C system performance and the response of the EV fan clutch. This condition may be more evident after the vehicle has set for a period of time and can be difficult to duplicate. The condition may occur after the vehicle has set for as little as 10 minutes or as long as overnight. It is most prevalent intermittently during the first 15 minutes of operation.
Correction.
Technicians are to replace the EV fan clutch with a new design part, P/N 15293048, on vehicles built before June 2005. Vehicles built in June 2005 may already have the updated EV fan clutch and it will not need to be replaced. For 2004 model year vehicles and older, update the Powertrain Control Module (PCM) with a software calibration that was developed to improve coolant temperature gauge readings. This new calibration will cause the PCM to command small amounts of additional fan engagement to better control engine coolant temperatures. Model year 2005 vehicles already have this calibration installed. Refer to Corporate Service Bulletin Number 04-06-02-005 for more information about this calibration.
Proper diagnosis of any customer concern is essential. Refer to the Diagnostic Starting Point-Heating, Ventilation and Air Conditioning procedure in SI to begin a diagnosis of any HVAC concerns. Refer to the Diagnostic Starting Point-Engine Cooling procedure in SI to begin a diagnosis of any engine cooling or engine cooling fan concerns. If an attempt is made to diagnose an HVAC system concern, all parameters must be measured. As an example, both the low and high side refrigerant pressure readings must be measured. If only the low side pressure readings were measured, it would appear that the A/C compressor is disengaging at a higher pressure than expected. If both the low and high side pressures were being measured, it would be noted that the A/C compressor is probably disengaging due to the maximum high side pressure cut out point being reached. This occurs to protect the HVAC system from damage. The updated PCM software calibration along with the updated EV fan clutch will improve this condition due to increased air flow across the condenser. The new EV fan clutch has an increased minimum operating fan speed and an improved response time. Additional engine cooling fan noise can be expected with the updated PCM software calibrations.
The last area of customer concern is the operation of the HVAC system blower motor. For vehicles equipped with automatic control HVAC systems (RPO CJ2), the blower motor fan speed will be limited to 80% of maximum when the HVAC system is operating in the automatic mode. To obtain maximum blower motor speed, instruct the customer to manually adjust the blower motor speed to the highest setting.
2001 Chevy Camaro L92/4L80E
Re: A/C problem, '04 GM 5.3L, Rainier CXL, 2WD [Re: DeepFriar] #4484125
08/09/17 09:32 PM
08/09/17 09:32 PM
Georgia
Georgia
Thanks for the input guys. I will follow up on these. I let it idle for three hours yesterday outside the emergency room (wife, no heart attack found thank God) because I forgot to turn it off. It was cold on return, engine normal temp, no apparent problems. New water pump, two years ago, no other apparent cooling system probs at that time but will recheck. Thanks again.
