Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
72 registered members (BeerCan, bfleeman, aquariuscsm, AndyB, 4WD, 7 invisible), 1,368 guests, and 37 spiders.
Topics295,208
Posts4,929,969
Members66,711
Most Online2,553
Oct 27th, 2018
Aftermarket dipstick for 05 Sienna? #4483452
08/09/17 08:02 AM
08/09/17 08:02 AM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
I have always had a tough time getting a good reading on my Sienna dipstick. Really not sure what the issue is. Yesterday on one side, the oil was 80% up, in between the low and high marks; on the other side, it went a few inches higher than the high mark. Wiped it off and did it again, got the exact same results every time. Finally I just put it back in and gave up. Each time I try to read the oil level on my Sienna, there is something that keeps me from getting a reading that I'm confident is accurate. If the 80% level is the accurate reading, that would mean that after roughly 2500 miles, I would be low by about a third of a quart, so that is very possible.
Anyways, my question---would a different dipstick help me out here (I really have no idea if this would be the case or not)? And if so, are there any suppliers that anyone here would recommend?
2005 Toyota Sienna LE; 156,000 miles
1998 Honda Civic DX; 202,000 miles
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483491
08/09/17 08:38 AM
08/09/17 08:38 AM
Oshawa, Ontario Canada
JC1 Online content
JC1  Online Content
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483544
08/09/17 09:24 AM
08/09/17 09:24 AM
MN
TmanP Offline
TmanP  Offline
MN
I know exactly what you mean! Ours is the same way. Till the oil has darkened, it's near impossible. Even then, it's very tough. It's a terrible design, but luckily it doesn't burn oil.
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Aftermarket dipstick for 05 Sienna? [Re: JC1] #4483552
08/09/17 09:29 AM
08/09/17 09:29 AM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
I watched the video. That deals with oil that is too light to see against the dipstick. Mine is dark brown, but the problem is that on one side it went well over the full mark, and on the other side, it was short of the mark. I could see where the oil level was on each side clearly enough.
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483561
08/09/17 09:39 AM
08/09/17 09:39 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I know what you mean. Ive seen that on several cars. I think its just the bad design which wipes oil higher on the dipstick on one side for some reason.
At any rate, this is an easy problem. The side that is lower is the correct oil level. In your case, the 80% side with the oil level between full and add is the correct oil level.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483562
08/09/17 09:40 AM
08/09/17 09:40 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Always go with the lower reading as true. Problem solved.
You obviously cannot have two different oil levels on each side of the dipstick, so the higher level is most likely from the dipstick rubbing on the tube and dragging a bit of oil along, hence the higher reading.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: Aftermarket dipstick for 05 Sienna? [Re: KrisZ] #4483568
08/09/17 09:45 AM
08/09/17 09:45 AM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
Originally Posted By: KrisZ
You obviously cannot have two different oil levels on each side of the dipstick....
I bet I could if I took a hairpin curve at 90. That would probably really be something to see in my Sienna.
But it ain't gonna happen. eek
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483739
08/09/17 12:47 PM
08/09/17 12:47 PM
WA
DeafBrad Offline
DeafBrad  Offline
WA
Pretty sure the other guys are right about the side with the lowest oil reading is correct. But if it gives you peace of mind, change the oil and put the exact amount the owner's manual calls for. Then look on the dipstick to see which side reads full. Use that side from here on out to tell your dipstick level.
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483768
08/09/17 01:25 PM
08/09/17 01:25 PM
Los Angeles, California
Gokhan Offline
Gokhan  Offline
No, don't get an aftermarket dipstick. You need to use the OEM.
I have a similar problem with the dipstick for the Toyota Aisin Warner A240L automatic transmission, which is flexible and goes through a curved pipe. ATF never leaks but I need to check it after a fluid change. It's the toughest and most reliable automatic transmission that has ever been built though.
You just need to figure out which side is giving you the correct reading and you will be fine. It shouldn't be that hard to figure out what's really going on.
1985 Toyota Corolla LE, 4A-LC engine, ~ 271,000 M
Toyota (TGMO) 0W-20 SN high-moly GTL (© 2015 reformulation)
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
Re: Aftermarket dipstick for 05 Sienna? [Re: paulri] #4483775
08/09/17 01:38 PM
08/09/17 01:38 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The side with the lower level will be the correct one. It is just the stick dragging on the tube causing the false higher reading. The level can not be at the higher side, it would show at least that high on both sides if it was.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Aftermarket dipstick for 05 Sienna? [Re: mightymousetech] #4483820
08/09/17 02:33 PM
08/09/17 02:33 PM
Gokhan Offline
Gokhan  Offline
It make sense. The only way the higher side would be the correct level would be if the other side was wiped off by the tube while pulling the dipstick, but since there is nothing in the tube to wipe off the oil, this can't happen.
So, use the lower reading.
