2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
45 registered members (carlprop, burla, chiefcook, ctechbob, A_A_G, BlakeB, 3 invisible), 1,192 guests, and 29 spiders.
Topics294,668
Posts5,064,166
Members69,303
Most Online3,532
Jul 30th, 2019
Red Sport 400 UOA #4482240 08/07/17 09:14 PM
slimjim Offline OP
Well here's the UOA for my 2016 Infiniti Q50 Red Sport. The oil has 9,700 miles on it. Engine has 19,700 miles on it. It was painful to go almost 10k miles on a 0w20 in this high revver. Oil was Valvoline synpower 0w420, and OEM filter. file:///C:/Users/james/Downloads/16%20Q50-170728.pdf
2016 Infiniti Q50 Red Sport, 40K miles
2016 Mazda MX-5 Miata, 5,400 miles
2018 Honda CR-V 3,800 miles
2018 GMC Sierra 1500, 8K miles
Re: Red Sport 400 UOA [Re: slimjim] #4482241 08/07/17 09:16 PM
slimjim Offline OP
Having a hard time posting the analysis.
Re: Red Sport 400 UOA [Re: slimjim] #4482249 08/07/17 09:24 PM
slimjim Offline OP
Re: Red Sport 400 UOA [Re: slimjim] #4482250 08/07/17 09:25 PM
slimjim Offline OP
Just copy and paste in new browser.
Re: Red Sport 400 UOA [Re: slimjim] #4482256 08/07/17 09:29 PM
L
ltslimjim Offline
L
Hey Slim,
Before I recommend uploading it to an online site, is this PDF edited to remove your personal information?
You can upload your file through this site:
http://imgur.com/upload
Then, post the link here (there is a Copy button after your file uploads) for us as we can't access your personal computer hard drive; which is what that address you shared is directing towards. In other words, you posted an address located on your computer and not on the web for us to find. You have to make it available online for us to view it here.
OR conversely you could copy what I'm pasting below this line and just replace the numbers with your own, but if you only copy the data you'll need to type it like this:
(code) before the data below pasted here & turned into your own (/code) ...after the data. Please note, you have to replace ( ) with [ ] around the words code and /code. Then your own info will appear as it does below.
(code) test (/code) turns into
Code:
 test
when using [] instead of ()
Code:
OIL             MOBIL1 AFE 0w-20
MILES IN USE    21,301
MILES ON UNIT   211,910
SAMPLE TAKEN    08/24/14
Make Up Oil Added  1 qt
ALUMINUM        5
CHROMIUM        2
IRON            30
COPPER          2
LEAD            1
TIN             4
MOLYBDENUM      68
NICKEL          1
MANGANESE       1
SILVER          0
TITANIUM        0
POTASSIUM       3
BORON           32
SILICON         12
SODIUM          11
CALCIUM         1012
MAGNESIUM       738
PHOSPHORUS      567
ZINC            665
BARIUM          0
SUS VIS 210ºF   52.9
cSt @ 100ºC     8.14
FLASHPOINT ºF   390
FUEL%           <0.5
ANTIFREEZE%     0.0
WATER%          0.0
INSOLUBLES%     0.4
TBN             2.4
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Red Sport 400 UOA [Re: slimjim] #4482271 08/07/17 09:50 PM
A
AVB Offline
A
0w420 oilburner You are feeding it the good stuff. grin
Re: Red Sport 400 UOA [Re: slimjim] #4482754 08/08/17 01:39 PM
slimjim Offline OP
help
Re: Red Sport 400 UOA [Re: slimjim] #4482835 08/08/17 03:04 PM
Q
Quattro Pete Offline
Q
I sent you a PM.
✰ 2002 530i   ✰ 2015 Q5 3.0T   ✰ 2018 Charger SRT
Re: Red Sport 400 UOA [Re: slimjim] #4483016 08/08/17 07:19 PM
Q
Q
Here you go:
Re: Red Sport 400 UOA [Re: slimjim] #4483039 08/08/17 07:47 PM
7
77GrandPrix Offline
7
Are you sure that is Valvoline Synpower? If so, they have drastically changed the formula.
Re: Red Sport 400 UOA [Re: slimjim] #4483040 08/08/17 07:49 PM
slimjim Offline OP
OK, so I read the description, but have no idea hoe to read the rest. What is SUS, and CST viscosity?
Re: Red Sport 400 UOA [Re: 77GrandPrix] #4483049 08/08/17 07:55 PM
SatinSilver Offline
He previously used Pennzoil Platinum in the car from 5k-10k. So maybe that's what it is. I have a uoa on some Valvoline Synpower I can post to compare. Actually this is SynPower with Maxlife Technology. Side by side comparison.
Re: Red Sport 400 UOA [Re: slimjim] #4483071 08/08/17 08:14 PM
Q
Q
https://www.blackstone-labs.com/report-explanation.php
SUS and cSt are just different units of measuring viscosity.
Re: Red Sport 400 UOA [Re: 77GrandPrix] #4483075 08/08/17 08:17 PM
slimjim Offline OP
yes, Valvoline synpower 0w20.
Re: Red Sport 400 UOA [Re: slimjim] #4483095 08/08/17 08:39 PM
SatinSilver Offline
I wouldn't go over 10k as they suggest. The results are very good for a twin turbo V6. I'd probably back the interval down to 5k-7k/6 months depending on how it's used. Some of the ever so slight elevated wear metals could be from a newer engine with low miles.
