New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
84 registered members (BAJA_05, ABomb369, barkingspider, 2004tdigls, 9 invisible), 1,476 guests, and 42 spiders.
Topics290,704
Posts4,848,638
Members66,021
Most Online3,590
Jan 24th, 2017
Programming a new key fob for 1997 GMC Sierrra #4482941
08/08/17 05:51 PM
08/08/17 05:51 PM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
I just bought 2 new factory GM key fobs for my 1997 Sierra. I programmed them using a paperclip inserted into the port under the dash in the 4 and 8 slots. Then hold down the 2 buttons on the remote till the lock cycles. Worked perfectly but the problem is once I program one fob and then go program the 2nd fob, the 1st fob no longer works once the 2nd fob has been programmed. I tried back and forth several times with the same results. It seems the truck will only learn one fob at a time. Is there a way to get both fobs working at the same time? Many thanks!
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4482949
08/08/17 05:59 PM
08/08/17 05:59 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Was it just the plastic and rubber worn out on your old fobs?
If so just swap the insides to the new cases
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4483012
08/08/17 07:12 PM
08/08/17 07:12 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I'm curious what made you buy new? Mine don't work unless I'm near the driver side door even with new batteries.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4483136
08/08/17 09:21 PM
08/08/17 09:21 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Been wanting a few new remotes for my chevy Cobalt, but I have been told that they have to be programmed at the dealerships...
not sure if the 4 and 8 slot thing would work for mine...
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4483244
08/09/17 12:23 AM
08/09/17 12:23 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
I bought the vehicle used quite a few years ago and it only came with one almost worn out key fob. It finally stopped working even with new batteries so I bought two new ones. I programmed the first one like I said and it worked fine till I program the second one and then the first one stopped working once I reprogrammed the second one. Then the second one worked just fine but then the first fob stopped working . This went on a few times and I gave up. So it appears that only one key fob will work at a time.
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4483283
08/09/17 03:28 AM
08/09/17 03:28 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
I figured out the problem. You have to program both fobs back to back at the same time without stopping. If you remove the paper clip from the terminals at any point you have to restart. It worked perfectly and now both fobs work perfectly.
Re: Programming a new key fob for 1997 GMC Sierrra [Re: daves87rs] #4483387
08/09/17 07:36 AM
08/09/17 07:36 AM
Idaho
CorvairGeek Offline
CorvairGeek  Offline
Idaho
Primarily works with pre-serial bus and some GM serial bus vehicles. I think all are gone by GMLAN vehicles.
Jerry
Re: Programming a new key fob for 1997 GMC Sierrra [Re: Chris B.] #4483424
08/09/17 08:38 AM
08/09/17 08:38 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
You beat me to it. That is how you do it.
