1991 Toyota Previa New JDM engine Redline
by Kurtatron
16 minutes 52 seconds ago
8 yr old channeling John Bonham
by Toy4x4
41 minutes 36 seconds ago
Traveller nlgi 2
by Spitter
Today at 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
Today at 05:08 PM
Any nano reefers here?
by RichardS
Today at 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
Today at 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
Today at 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
Today at 04:31 PM
help me choose...
by chaindrive
Today at 04:07 PM
France F1 Grand Prix
by DeepFriar
Today at 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
Today at 03:16 PM
Best additive in oil to clean sludge?
by ffgb
Today at 02:19 PM
Who is a Dirt Track regular?
by thooks
Today at 01:39 PM
eco plug oil plug video is restricted
by edwardh1
Today at 01:27 PM
Political comments
by ridgerunner
Today at 01:23 PM
My Ford orange turned pink
by BeerCan
Today at 12:45 PM
Any plants/garden experts?
by maverickfhs
Today at 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
Today at 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
Today at 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
Today at 11:20 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
104 registered (93cruiser, 007, 5AcresAndAFool, andyd, 77GrandPrix, 97prizm, 11 invisible), 1461 Guests and 37 Spiders online.
65286 Members
67 Forums
285727 Topics
#4482614 - 08/08/17 11:18 AM Rotational noise in front wheel
WA1DH Offline
Loc: Rhode Island
I need some help diagnosing a noise that seems to be coming from my driver front wheel. I had an intermittent issue with my front driver side brake partially locking up. One day the brake completely locked. I continued driving to work, figuring I was going to replace the caliper/rotor/pads anyway. It was full on locked, brake smoking/burning. On the ride home it had partially unlocked (or pads burned up). I replaced caliper/rotor/pads. Now I have a slight rotational 'rubbing' or whir-whir type noise that is loudest around 25-30 MPH, gets louder when cornering to the right, and gets quieter when cornering to the left. The noise varies with wheel speed and fades into a constant hum at highway speeds. When braking I don't feel any pulsing in the pedal, but if I do a hard stop the steering wheel vibrates coming down through 25-30 MPH. I checked the suspension and there is slight play in the inner tie rod on the driver side. I'm guessing that may be the cause of the vibration during hard braking, but I can't explain the rotational noise.
The car is a 99 Ford Escort with 226,000 mi on it. I replaced the passenger wheel bearing around 160k but never the driver side. Does this sound like a wheel bearing or something else? Are there any other parts that could have been damaged by the locked up/overheating brake?
Thanks.
1995 GMC K1500 5.0 V8 146k mi
1999 Ford Escort 2.0 I4 223k mi
#4482621 - 08/08/17 11:22 AM Re: Rotational noise in front wheel [Re: WA1DH]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Brake install gone wrong ,or> Toasted wheel bearing.
Edited by ARCOgraphite (08/08/17 11:23 AM)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4482625 - 08/08/17 11:26 AM Re: Rotational noise in front wheel [Re: WA1DH]
Srt20 Online   content
Loc: Wisconsin
Thats typical wheel bearing sound.
Wrecked it from the heat from the stuck brakes.
#4482649 - 08/08/17 11:56 AM Re: Rotational noise in front wheel [Re: WA1DH]
JMJNet Offline
Loc: TX, USA
Just have to do the wiggle test with the tire on and tires not touching the ground.
Put your hands on horizontal (3 and 9 o'clock) and vertical (12 and 6 o'clock) axis and rock the tires.
If they are rocking on both positions, the wheel bearing is toast.
Check youtube on video on how to do it.
Edited by JMJNet (08/08/17 11:58 AM)
  • 2017 Toyota Sienna
#4482652 - 08/08/17 11:59 AM Re: Rotational noise in front wheel [Re: JMJNet]
Loc: Wisconsin
This does not always work.
#4482674 - 08/08/17 12:15 PM Re: Rotational noise in front wheel [Re: WA1DH]
KrisZ Offline
Loc: Toronto, Canada
Th easiest way for me is to jack up the side that is suspect, just enough for the wheel to spin freely. Start the engine and put the tranny in gear. Even at idle speed the noise will be very pronounced, since there is no load on the bearing.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4482692 - 08/08/17 12:36 PM Re: Rotational noise in front wheel [Re: KrisZ]
zorobabel Offline
Loc: Anaheim, CA
Really bad advice here...
1997 Maxima 175k, Delvac 15w40, Wix 51315
2004 Corolla 189k, VWB 5w20 + SSS 10w40, MGL4967
#4482741 - 08/08/17 01:20 PM Re: Rotational noise in front wheel [Re: zorobabel]
Lolvoguy Offline
Loc: Canada
I agree, not only in regards to safety, but often times you won't get noise unless there's weight on the bearing.
I honestly cannot comprehend the logic in purposefully "burning up" a set of pads, rotors/calipers. So many things could affect the safety of the driver and others on the road. Really silly move on the part of the OP of this thread. bop
06 Lexus IS350- Wife
88 BMW 325is- Mistress
03 Suzuki SV650S- One night stand
#4482743 - 08/08/17 01:21 PM Re: Rotational noise in front wheel [Re: WA1DH]
Loc: N.H, U.S.A.
We used to set wheel bearing with some play - that is a simple front axle with out drive. You can usually feel the brinelling in the race, but don't confuse with BRAKE rotor edge rust hitting the pads.
Experience helps here.
#4482764 - 08/08/17 01:54 PM Re: Rotational noise in front wheel [Re: Lolvoguy]
KrisZ Offline
With you sitting in the car and the wheel fully bolted on, what's your safety concern exactly?
Also, although not in all cases, the bearing will make noise, mine certainly did and it could be easily heard from the cabin. This is just but one of the suggestions, there is no universal way that is known to work on all bearing failures.
#4482839 - 08/08/17 03:12 PM Re: Rotational noise in front wheel [Re: WA1DH]
PeterPolyol Offline
Loc: toronto
+1 for a possibly toasted bearing
Also, why did your caliper lock on? I'd dealt with an issue like that recently where the caliper would 'stick'. Changed the same parts you did, thought it was solved but eventually it did it again. Turns out it was the hydraulic line itself. It passed through a tight bracket that had begun to corrode inside, exerting pressure on the line effectively shutting it off. Applying the brakes could pressurize the caliper piston, but the passive return pressure was unable to be released from the line and caliper piston, effectively holding the brake on.
Previously, I'd dealt with a line where the internal rubber layer had expanded in length more than the outer layer, causing the inside rubber layer to bunch up, acting like a check valve! I'd advise to change your hydraulic line(s), they're cheap and there even might be a Wholesaler Closeout on them for your car at rockauto.
With 226K on original bearing that was recently BBQ'd, I'd change it for sure. There is a wholesaler closeout on the bearings too!
#4482921 - 08/08/17 05:28 PM Re: Rotational noise in front wheel [Re: Srt20]
rsylvstr Offline
Loc: Oneida County, NY
That's what I would say.
2001 F150 SCrew Lariat 4X4 5.4L, 4R70W, LS 9.75" 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
#4482984 - 08/08/17 06:36 PM Re: Rotational noise in front wheel [Re: PeterPolyol]
Arob Offline
Loc: Iowa
"It passed through a tight bracket that had begun to corrode inside, exerting pressure on the line effectively shutting it off. Applying the brakes could pressurize the caliper piston, but the passive return pressure was unable to be released from the line and caliper piston, effectively holding the brake on."
This is an issue that has happened to me on several ford front calipers with the bracket and brake hose.
#4492300 - 08/18/17 08:56 PM Re: Rotational noise in front wheel [Re: WA1DH]
WA1DH Offline
Loc: Rhode Island
Update:
It was the wheel bearing. I could feel it grinding as I rotated the hub once I took it apart. All repaired and quiet once again.
On a side note I went ahead and replaced both front brake hoses (caliper to metal line) as there was some visible dry rot and cracking. I also lightly greased the pins holding the pads in the calipers and ensured that everything on both sides is moving freely.
Thanks.
