Received UOA
South Dakota
Received UOA on my 2016 Grand Caravan. Not sure how to post results. I can email them if someone knows how to post.
Electronic copy, or paper?
The preferred method is to type it up using Notepad into a txt file. Then add it using the # function. You can then easily add the next UOA for same engine easily to the txt file.
If you got it from blackstone you can use their software to post a uoa without your name on it.
Export without personal data box on their search for your uoa page. The find a photohost like flkr.
Just use the forums built in pic hosting. Free and will always be here.
Also, make sure you post it in the UOA forum.
