Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
Collector Oil Cans
by Snagglefoot. 09/18/18 10:06 AM
Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
104 registered members (53' Stude, 28oz, 2K2AcuraTL, 2013ecof150, 2010Civic, 11 invisible), 1,716 guests, and 41 spiders.
Topics290,597
Posts4,847,149
Members66,004
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Idle to cool down, isn't full throtno load better? #4481536
08/07/17 07:53 AM
08/07/17 07:53 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Wouldn't full throttle with no load be better at cooling than bringing it down to an idle?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481540
08/07/17 07:56 AM
08/07/17 07:56 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
Is this for an air-cooled engine? If so, more RPMs equal more heat. Unless this is not what you are asking?
2018 MB AMG GLC43 3.0L Coupe - Castrol 0W-40/Purflux
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 15W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481547
08/07/17 08:09 AM
08/07/17 08:09 AM
San Antonio, TX
E150GT Online content
E150GT  Online Content
San Antonio, TX
I would suspect elevated rpms like 2k would probably help without introducing too much hear. I would think driving for a bit at low load would be better since you have airflow over the radiator
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481548
08/07/17 08:11 AM
08/07/17 08:11 AM
Houston, Texas
Houston, Texas
Yes this is for small air cooled 4 stroke engines. I would think the flywheel would move more air at a high rpm vs idling. You took away the load, so I don't think it would produce much heat.
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481558
08/07/17 08:20 AM
08/07/17 08:20 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
While I agree that higher RPMs will move more air due to the flywheel spinning faster, I still do not think it is enough to overcome the amount of heat that will be generated. Even with zero load high RPMs are going to generate more heat-- right?
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481562
08/07/17 08:27 AM
08/07/17 08:27 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Easy to answer. Engine temperature goes up as RPM increases, regardless of load. A simple infrared thermometer illustrates this.
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481570
08/07/17 08:35 AM
08/07/17 08:35 AM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
My experience on low speed, steep grade mountain roads is that you turn it off or downshift and keep going. I've had better luck pulling grades at 3500rpm vs 2000rpm in regards to over heating. None of my overheating was due to vehicle issues just large loads at low speed, 10-30mph. My lumberyard forklifts will over heat on 115 days. They will over heat at idle but will cool down if held at a mid range rpm for a few minutes. I guess I'm not a fan of the idle cool down.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Idle to cool down, isn't full throtno load better? [Re: RedOakRanch] #4481578
08/07/17 08:45 AM
08/07/17 08:45 AM
Texas
4WD Offline
4WD  Offline
Texas
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481594
08/07/17 09:14 AM
08/07/17 09:14 AM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
Kohler 18 horsepower horizontal air cooled V twin. If I shut off after mowing without an idle cool down, it pops like a backfire. If it is idled for a few minutes then shut off while opening the throttle, no pop. I always let it cool at idle.
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481602
08/07/17 09:24 AM
08/07/17 09:24 AM
Indianapolis, IN
09_GXP Offline
09_GXP  Offline
Indianapolis, IN
The question is what are you trying to cool down? It's very common in development testing to run an engine at max load (max heat) followed by high idle to cool everything off quickly and give a thermal shock to the system.
If you have just been running low load then running higher rpm will probably raise the temps. But if you have been running high loads then running higher rpms will reduce temps quicker than just dropping to idle.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
Re: Idle to cool down, isn't full throtno load better? [Re: bugeye] #4481610
08/07/17 09:31 AM
08/07/17 09:31 AM
Texas
4WD Offline
4WD  Offline
Texas
I had a Kohler twin do that - then I learned to shut the blades down and drive the 100' feet to park it at a mid speed - idle a minute or two ... shut down ...
Re: Idle to cool down, isn't full throtno load better? [Re: RedOakRanch] #4481619
08/07/17 09:41 AM
08/07/17 09:41 AM
Vermont
John_VT Offline
John_VT  Offline
Vermont
It's been awhile but aren't forklifts liquid cooled. If they will overheat idling they probably have a problems
14 crosstrek 5 spd.Milesyn sxr 0-20
98 k1500 suburban 5.7L.Milesyn sb 5-30
03 Pontiac Montana. St 5-30
01 mojave,86 trx350,2-110cc atv's
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481631
08/07/17 09:55 AM
08/07/17 09:55 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Since we are talking about air cooled mowers (not mountain roads or forklifts), the fan is directly attached to the crankshaft, so if the engine is 1000 rpm, so is the fan.
On an air cooled car (VW), the fan is attached to a belt and pulley, so while the engine is at 1000 rpm, the fan is spinning much faster at 2000-3000 rpm. Thus moving a lot more air at idle than a direct drive lawn mower fan.
On an air cooled car, there should be sufficient fan spinning at idle to cool the engine. On a direct drive lawn mower, there likely isn't sufficient air movement at idle.
Idling a lawn mower engine is not the best for it. The fan and the splash oiling system is designed for 3100 rpm. Not 1000 rpm.
As to the OP's question, why do we care about cooling? Run the engine as designed, keep the cooling fins free of dirt/debris, and maintain it with new filters and an oil change every now and then and it will give you long life. Why do we need to care about its temperature? Its not likely to overheat unless we abuse it beyond its design limits.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Idle to cool down, isn't full throtno load better? [Re: bubbatime] #4481729
08/07/17 11:36 AM
08/07/17 11:36 AM
Ohio
Dave Sherman Offline
Ohio
The owner's manual for my riding mower specifically says to idle it for 15 seconds after mowing before shutting down, perhaps the OP has equipment that has a similar requirement. Yes, more air moves at high RPM, but high RPM burns more fuel and makes more heat. Idle uses the least fuel, and there is still a decent flow of air. Even at idle I can feel hot air blowing out of the cylinder shroud.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Idle to cool down, isn't full throtno load better? [Re: motor_oil_madman] #4481835
08/07/17 01:47 PM
08/07/17 01:47 PM
Arkansastan
Propflux01 Offline
Propflux01  Offline
Arkansastan
Idling before shutdown cools the engine. Less RPM equals less heat. If you shutdown from full, many times it will backfire or pop afterwards. This is because exhaust valve is hot enough (probably glowing) to burn the raw fuel. Idle down, valve cools, no pop or backfire.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Page 1 of 3 1 2 3
