Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (Aero540T, 4WD, 69Torino, AdditiveOCD, 2015_PSD, 9 invisible), 1,710 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
2013 Cadillac ESV 6.2 L recommend oil #4481187
08/06/17 07:05 PM
08/06/17 07:05 PM
USA NY
Turbo Offline OP
Turbo  Offline OP
USA NY
Need to change the oil on a 2013 Cadillac ESV 6.2 Liter motor. Just purchased the vehicle used from a Cadillac dealer. Have no clue what the past oil changes have been other than it has been serviced by the dealer since new. I have a few questions.
Does anyone know what the original fill was from GM? Conventional - Blend or Full synthetic? Would like to use what the factory put in.
Is the Acdelco pf48E filter decent? Any reason not to use Acdelco? Is there a larger filter?
If I go with full synthetic is Pennzoil Platinum still top rated? Should I use something else?
Thank you for the help.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4481193
08/06/17 07:15 PM
08/06/17 07:15 PM
Canada
addyguy Offline
addyguy  Offline
Canada
The original fill from GM would have been a bulk Mobil-sourced Dexos-1 5W-30 synthetic blend.
Stick with a Dexos-1 oil; most on the shelf are full synthetic, most brands full-syn 5W-30's are Dexos-1.
Pennzoil Platinum, Mobil 1, QS Ultimate Durability...etc... Pick your favourite of best deal.
2010 Kia Soul 2U - 2.0L I-4, auto; 138k miles.
M1 EP 10W-30; OEM Kia filter.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4481195
08/06/17 07:17 PM
08/06/17 07:17 PM
BC, Canada
userfriendly Offline
BC, Canada
You can use the 2014 and newer filter which is slightly longer than the 13 and older 5.3 & 6.2Ls.
Your 6.2 should be a 5W30 Dexos engine, the 14s and newer are 0W20.
I see nothing wrong continuing with the 5w30 GM brand or any other Dexos approved engine oil.
Next, drain and refill the transmission, diff(s) and transfer case if so equipped.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: addyguy] #4481198
08/06/17 07:19 PM
08/06/17 07:19 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
++any of these synthetic oils - but probably a Fram Ultra or Mobil 1 filter ...
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: addyguy] #4481201
08/06/17 07:20 PM
08/06/17 07:20 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
It is. Any major name brand synthetic 5W-30 will do. It might actually be Mobil 1 and not AC Delco's Mobil-sourced oil...
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: userfriendly] #4481233
08/06/17 07:50 PM
08/06/17 07:50 PM
Illinois, USA
Triton_330 Offline
Triton_330  Offline
Illinois, USA
Correct. The ACDelco PF63 can be used in place of the PF48 (or PF48E).
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4481242
08/06/17 07:55 PM
08/06/17 07:55 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I you want to be hardcore stock original, use ACDelco 5W-30.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Merkava_4] #4481294
08/06/17 08:40 PM
08/06/17 08:40 PM
Louisiana
OLEJOE Offline
OLEJOE  Offline
Louisiana
I use Fram XG 10575 Ultra on my wife's Tahoe. Also Mobil 1 5W-30 EP. It's a 2011 with the 5.3.
Jack of All Trades. Master of some.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: OLEJOE] #4481304
08/06/17 08:44 PM
08/06/17 08:44 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Same here XG10575 on 5.3L
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4481328
08/06/17 09:11 PM
08/06/17 09:11 PM
socal
barkingspider Offline
socal
Use any 5w30 you like best. PP is a good choice. AC Delco oil filters (small or large) are plenty good as well. No need to over thInk it
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4482231
08/07/17 08:03 PM
08/07/17 08:03 PM
AR
evois Offline
evois  Offline
AR
Mobil 1 5w/30 extended performance and dealer AC delco oil filter.
Re: 2013 Cadillac ESV 6.2 L recommend oil [Re: Turbo] #4482939
08/08/17 04:50 PM
08/08/17 04:50 PM
Indiana
nascarnation Offline
Indiana
It's an LS motor.
Use any Dexos spec and the OLM for change intervals and report back at 300,000 miles.
Thousands of these do that all the time in commercial service running on bulk 5W30 oils.
