Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
112 registered members (aquariuscsm, Alfred_B, ArrestMeRedZ, acme, 69Torino, allgm59, 9 invisible), 2,069 guests, and 61 spiders.
Topics286,236
Posts4,904,942
Members67,582
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
ZDDP Levels? #4481038
08/06/17 05:20 PM
08/06/17 05:20 PM
Tornado Alley
-SyN- Offline OP
-SyN-  Offline OP
Tornado Alley
How important is ZDDP levels within an oil to a Roller Lifter & Cam design?
Let's say example to the Ram 5.7L with this design.
Which has shown to develop the famous roller lifter tick.
This is starting to show up more & more even on newer Rams.
There are many who have begun running Red Line oil 5W-20 / 5W-30 which has much higher levels of Moly & ZDDP and the Ticking has disappeared & has not returned.
Other oils that have lower levels of Moly / ZDDP did nothing to quiet the ticking lifters & in most cases became worse.
With Many reports of lifter collapse & cam failure.
17 Ram 2500 6.7L CTD- > Schaeffers 5W-40
19 Edge ST 2.7L EB > Edge Euro 0W-30 w/MC Filter
17 Edge Titanium 2.0L EB > Magnatec 5W-30 w/RP Filter
Re: ZDDP Levels? [Re: -SyN-] #4481088
08/06/17 06:20 PM
08/06/17 06:20 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I wouldn't think it would need nearly as much as a flat tappet design. ZDDP is good for sliding parts, a roller lifter shouldn't be sliding
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: ZDDP Levels? [Re: -SyN-] #4481089
08/06/17 06:23 PM
08/06/17 06:23 PM
BerksCounty/Pa.
thorromig Offline
thorromig  Offline
BerksCounty/Pa.
Funny, the Hemi motors are known to run many a many miles under all sorts of duress -- you might be exaggerating some!!! shocked
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: ZDDP Levels? [Re: -SyN-] #4481090
08/06/17 06:24 PM
08/06/17 06:24 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Sounds like you've been on forums where someone is making a mountain out of a mole hill. The Hemi has proven itself worthy over millions of accumulated miles. I've personally been inside of 8, 4 of which were fleet trucks getting engine rebuilds to go back into service for a courier service. All 4 of the fleet engines had between 365,000 and 400,000 miles. All of the camshfts were reused. Zinc is of limited benefit in a roller cam engine with respect to the roller or bearings inside the roller. All 4 of those fleet trucks never got anything other than bulk conventional oil at 10k intervals.
If you want to run Red Line go ahead. It's a great oil. But it simply isn't needed for these engines.
Of note all 4 of the high mileage Hemis could've just had rings bearings and gaskets and been returned to service. But that's not what the customer wanted so they all got a full rebuild.
Luke
Re: ZDDP Levels? [Re: -SyN-] #4481099
08/06/17 06:31 PM
08/06/17 06:31 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Don't get in a tizzy over ZDDP levels.
2015 Ford F250 w/Powerstroke
Re: ZDDP Levels? [Re: FlyNavyP3] #4481125
08/06/17 06:51 PM
08/06/17 06:51 PM
sonoma
burla Offline
burla  Offline
sonoma
That would be me. I had Redline fix my lifter tick, and subsequently over 5 years we had about 20 guys also end their 5.7 lifter ticks on Redline oil. We kept track, and it is about 80% success rate. The last guy committed to trying many different oils and in the end, he gave up on Amsoil SS 5w30, PUP 5w30 and some other oils because only Redline 5w30 keeps his 5.7 quiet.
Furthermore, we had the last 6 lifter Cam failures, as in the Cam lobs wore to the nub all with Hemi's, all trace back to engines that used oils that have zero moly. The last 6 in a row! So it is all recorded over on Ram forum, maybe some guys here would consider it or tell how Redline either worked or didn't for the Hemi ticks, but the facts are the facts and it has 4 solid years worth of backing, now going on 5.
So the question should be why did this happen? The working theory is it is Molybdenum in Redline because most of the ticks disappear only after 500 miles, if it was the base oil or esters, it likely would have ended the tick sooner?
Or is this not enough evidence to convince people of Bob's that these are facts, not a big enough control group?
Re: ZDDP Levels? [Re: -SyN-] #4481140
08/06/17 07:12 PM
08/06/17 07:12 PM
Tornado Alley
-SyN- Offline OP
-SyN-  Offline OP
Tornado Alley
Donald: No Tizzy ever mentioned.
I just asked a very simple question about the importance of ZDDP levels to a roller lifter cam design.
Re: ZDDP Levels? [Re: burla] #4481151
08/06/17 07:28 PM
08/06/17 07:28 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
It may have been [also] due to the elevated HTHS values the oil is famous for...
Re: ZDDP Levels? [Re: -SyN-] #4481246
08/06/17 09:00 PM
08/06/17 09:00 PM
USA
ArcticDriver Offline
USA
But accusing you of a tizzy adds so much drama to an otherwise boring yet informative thread. grin
Atleast I found the thread helpful.
Multiple Diesel and Gasoline vehicles
Re: ZDDP Levels? [Re: FlyNavyP3] #4481281
08/06/17 09:28 PM
08/06/17 09:28 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The customer doesn't always know best.
Re: ZDDP Levels? [Re: -SyN-] #4481365
08/06/17 11:01 PM
08/06/17 11:01 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
High moly oils are always reported as being "quiet" oils.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: ZDDP Levels? [Re: -SyN-] #4481400
08/07/17 12:45 AM
08/07/17 12:45 AM
Balearic Islands , Spain
FordCapriDriver Online content
FordCapriDriver  Online Content
Oils high in moly are known for quietening engines a bit
Zddp would have no difference imo, and ZDDP is only something you have to worry about on flat tappet engines.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: ZDDP Levels? [Re: SilverFusion2010] #4481499
08/07/17 06:53 AM
08/07/17 06:53 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Not sure if I agree with this.
Re: ZDDP Levels? [Re: -SyN-] #4481504
08/07/17 06:58 AM
08/07/17 06:58 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
A case of more is better, though not every circumstance benefits from it. blush
Re: ZDDP Levels? [Re: zeng] #4481507
08/07/17 07:01 AM
08/07/17 07:01 AM
Herndon, VA
btanchors Offline
btanchors  Offline
Herndon, VA
I have heard that the reason Red Line has high Zinc and Moly is that the nature of its base oil makes it "harder" for anti-wear additives to have their proper effect. Something about esters having a tendency to "displace" zinc and other additives. I don't know if this is true or not - if it is true, I wonder if higher zinc in a non-ester based oil would function even better.
Page 1 of 5 1 2 5
