Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
31 registered members (billt460, Bailes1992, Brad_C, bbhero, 5 invisible), 520 guests, and 59 spiders.
Topics286,442
Posts4,908,265
Members67,622
Most Online2,967
Mar 10th, 2019
Judging oil condition based on appearance #4480889
08/06/17 02:32 PM
08/06/17 02:32 PM
Indiana
5AcresAndAFool Offline OP
Indiana
As we know you cannot tell all you need to know on engine oil condition based on appearance. Even if it may be darker, but that doesn't necessarily mean the oil needs to be changed, however can we assume if the oil looks clean and has a light color to it that it is likely ok?
I suppose you could have moisture in the oil from short tripping or such, but if it looks clean, cant we assume it still has service life left?
Re: Judging oil condition based on appearance [Re: 5AcresAndAFool] #4480895
08/06/17 02:40 PM
08/06/17 02:40 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Go by the OLM or recommend OCI in owners manual unless your going to do UOA.
2015 Ford F250 w/Powerstroke
Re: Judging oil condition based on appearance [Re: 5AcresAndAFool] #4480904
08/06/17 02:48 PM
08/06/17 02:48 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
So generally you do a blotter test on a white paper towel. If it does not leave a discolored ring, it is a preliminary indicator that things are OK. The only real way to tell is to do a UOA ...
But, if you know the vehicle and there are no issues, no CEL's and the coolant is staying where it needs to be, you can assume that light colored oil is OK for the foreseeable ... It may have deleted TBN and still look good. But that would usually be over a year or two and over many thousands of miles of use ...
Re: Judging oil condition based on appearance [Re: BrocLuno] #4480935
08/06/17 03:21 PM
08/06/17 03:21 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
But it will smell sour, though...
Chances are if the oil "looks good" it is actually in EXCELLENT condition.
I have seen oil that looks awful come back from the sample lab saying that it's still not bad.
Re: Judging oil condition based on appearance [Re: BrocLuno] #4480937
08/06/17 03:22 PM
08/06/17 03:22 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The blotter tests I read about online say to use card stock... I'd like to try plain printing paper
Re: Judging oil condition based on appearance [Re: 5AcresAndAFool] #4481024
08/06/17 05:05 PM
08/06/17 05:05 PM
BrocLuno Offline
BrocLuno  Offline
Any white absorbent surface that has a fairly neutral pH smile
Re: Judging oil condition based on appearance [Re: BrocLuno] #4481220
08/06/17 08:38 PM
08/06/17 08:38 PM
Massachusetts
turtlevette Offline
turtlevette  Offline
Massachusetts
Klotz oil says change when dark. Instructions right on the bottle.
USA-1
Re: Judging oil condition based on appearance [Re: 5AcresAndAFool] #4481248
08/06/17 09:04 PM
08/06/17 09:04 PM
USA
ArcticDriver Offline
USA
Now I had a F150 with 4.9 and it was LPG.
That oil always looked great grin
Multiple Diesel and Gasoline vehicles
Re: Judging oil condition based on appearance [Re: 5AcresAndAFool] #4481271
08/06/17 09:20 PM
08/06/17 09:20 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Probably the only thing you can roughly estimate from oil colour is soot loading
There's no replacement...'scosity for natural viscosity
Re: Judging oil condition based on appearance [Re: ArcticDriver] #4481339
08/06/17 10:32 PM
08/06/17 10:32 PM
Regina, Saskatchewan, Canada
Garak Online content
Garak  Online Content
Same with the taxis. It always came out clean as a whistle. wink
Plain, simple Garak.
