No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
76 registered members (Audios, Al, atikovi, 53' Stude, 10 invisible), 1,806 guests, and 39 spiders.
Topics295,114
Posts4,928,006
Members66,688
Most Online2,553
Oct 27th, 2018
F1, how many quarts? #4480538
08/06/17 07:23 AM
08/06/17 07:23 AM
MA.
Camprunner Offline OP
MA.
I have often wondered how many quarts of oil does a Formula one car hold in the sump? Anyone here know?
Re: F1, how many quarts? [Re: Camprunner] #4480544
08/06/17 07:29 AM
08/06/17 07:29 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
http://www.formula1-dictionary.net/engine.html
"The engine oil capacity is about 3 litre or so. This is because of the dry sump system."
That seems like a very small amount. My guess is that is what's flowing through the engine at any given time. That is under 4 quarts.
Re: F1, how many quarts? [Re: Camprunner] #4480548
08/06/17 07:31 AM
08/06/17 07:31 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Hmmmm... Good Q
Ok, google:
"formula 1 dry sump tank capacity"
https://www.f1technical.net/articles/8766
Dry sump lubrication in F1 engines
http://www.fsae.com/forums/showthread.ph...sump-questions.
"For reference, Nascar tanks are 24 qts. I've heard of F1 tanks as small as 1.5 qts "
https://www.google.com/search?q=formula+...0k1.D3Ky0fDVJiI
https://drysump.com/index.php/technical-info/technical-explanation-of-a-dry-sump-system
Re: F1, how many quarts? [Re: Camprunner] #4480550
08/06/17 07:33 AM
08/06/17 07:33 AM
Toronto, Canada
Tech819 Offline
Tech819  Offline
Toronto, Canada
Unsurprisingly, engine-related failures remain one of the most common causes of retirements in races. The engine oil capacity is about 3 litre or so. This is because of the dry sump system.
2017 Impreza Sport Hatch M1 0w20 OEM filter
2003 Corolla Magnatec 5w30 OEM Filter
2013 Jetta 2.5 Castrol 0w40 OEM filter
Re: F1, how many quarts? [Re: billt460] #4480664
08/06/17 09:47 AM
08/06/17 09:47 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
That is the same amount as for my 1.4CVVT smile And hyundai says it is GTG for 20.000km...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: F1, how many quarts? [Re: Tech819] #4480666
08/06/17 09:49 AM
08/06/17 09:49 AM
CA
raytseng Offline
raytseng  Offline
CA
would disagree, the article is a little dated. in the last couple years engines have bexome compatitively really reliable.
only honda is making really bad engines, lol.
every few races, tv commentators mention the modern reliabilty (usually in the context of honda unreliabilty).
I dont have stats but it seems like crashes and damage cause more retirements than engine failure now, esp. if you dont include honda
additionally the few engine related failures usually are muxh more conplex and more with complexities with electronics and electric turbo or battery, rather than an oil related full kablamos, which were more common say 10years ago.
Re: F1, how many quarts? [Re: raytseng] #4480675
08/06/17 10:07 AM
08/06/17 10:07 AM
Toronto, Canada
Tech819 Offline
Tech819  Offline
Toronto, Canada
You might be right. This is what google found for me.
Re: F1, how many quarts? [Re: Camprunner] #4480728
08/06/17 11:12 AM
08/06/17 11:12 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
3 liters of oil is nothing. My 5.7 HEMI V-8 in my Jeep Grand Cherokee takes 7-1/2 quarts. That's almost 2 gallons. And it turns 1,500 RPM in 8th gear at 60 MPH. F1 cars turn 15,000 RPM like it's nothing.
Re: F1, how many quarts? [Re: Kamele0N] #4480741
08/06/17 11:25 AM
08/06/17 11:25 AM
Frogland / Brittany / Canada
Popsy Offline
Popsy  Offline
Same thing for my Mitsu 4G15T...3L, 20000Km on a turbo engine.
I wonder what is the % of oil related engine failure in F1
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 0W40 | Colt Ralliart, 300V 0W40
Re: F1, how many quarts? [Re: Camprunner] #4481672
08/07/17 09:31 AM
08/07/17 09:31 AM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
Extra oil = Extra weight. Not at all surprised that they have minimal sumps.
Bet they're running 0W-16 oil. laugh
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 79,000 M1
2007 Tahoe 140,000 PP
Re: F1, how many quarts? [Re: Indydriver] #4486403
08/12/17 08:26 AM
08/12/17 08:26 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Nahh. GDI turbo engines require 5w30. Just check the Ford Ecoboost threads...
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
