Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
102 registered members (aquariuscsm, 928, Ag76, Alfred_B, Aero540T, Altima2, 12 invisible), 2,095 guests, and 58 spiders.
Topics286,236
Posts4,904,891
Members67,582
Most Online2,967
Mar 10th, 2019
Noticed some weird play on the wheel... #4479946
08/05/17 01:43 PM
08/05/17 01:43 PM
New York
NoNameJoe Online content OP
NoNameJoe  Online Content OP
New York
So imagine you're looking at a sedan from its passenger side where you can see both wheels, both doors and the fender.
In motion the wheels are only supposed to spin in place (or turn when steering).
While I was watchin someone park this car from the passenger side, I saw the front wheel literally move a few inches toward the front of the car (toward the wheel well liner) and then the back (toward the opposite side). This only happens when braking. The wheel remains pointed straight while this happens.
Before I remove the wheel and start randomly looking around (going to focus on the LCA first), does anyone have a good idea of what would cause this?
2015 Civic LX Coupe
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4479962
08/05/17 02:02 PM
08/05/17 02:02 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Thrust arm bushing, lower control arm bushing, or both, depending on suspension design.
"Zed's dead baby, Zed's dead."
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4479963
08/05/17 02:04 PM
08/05/17 02:04 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
A "few inches"?? Holy cow, a failure of that magnitude should be quite apparent in a visual inspection. My Accord had a CV shaft failing that moved less than 1/8" and that made both a noise and a visible movement in the hub when inspected. Focus on those components which are intended to restrain forward and aft movement of the hub.
Whatever the cause that is a serious and potentially life-threatening failure.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4479967
08/05/17 02:11 PM
08/05/17 02:11 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Bad subframe mount would do this too.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4480009
08/05/17 03:03 PM
08/05/17 03:03 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Oooh take a video. THIS I gotta see
Thick vs Thin test: 15k / 43k miles complete
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4480015
08/05/17 03:08 PM
08/05/17 03:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sounds like a rubber bushing some where in the front suspension rotted out and disappeared.
Re: Noticed some weird play on the wheel... [Re: NoNameJoe] #4480121
08/05/17 06:13 PM
08/05/17 06:13 PM
ME
eljefino Offline
eljefino  Offline
ME
My mercedes w123 does this. Its suspension is fairly weird and doesn't have lower ball joints/ control arms below spindle level. Disconcerting when I torque lug nuts on the ground and the wheel rolls slightly (not inches tho)
Re: Noticed some weird play on the wheel... [Re: eljefino] #4480351
08/05/17 11:33 PM
08/05/17 11:33 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Skip to 0:42 on this video
too many cars and oil combinations to list in 150 characters or less
