1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
125 registered members (240_Ed, 2015_PSD, 2009Edge, Altima2, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 64 spiders.
Topics286,399
Posts4,907,593
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Will you change your oil? #4479907
08/05/17 12:58 PM
08/05/17 12:58 PM
AR
evois Offline OP
evois  Offline OP
AR
Okay, I have a 2013 Range Rover Sport HSE lux which is basically a garage queen. Last year it only travelled 100 miles on the new transfused Castrol edge titanium 0/20 extended performance. A Blackstone oil analysis proved that the oil was intact as well as the TBN. This year it will only have traveled 30 miles. Can the oil last two years without changing? It's synthetic unlike Dino. Any feedbacks? Yes, only 16,000 miles.
Re: Will you change your oil? [Re: evois] #4479910
08/05/17 01:01 PM
08/05/17 01:01 PM
AR
evois Offline OP
evois  Offline OP
AR
Previous oil was the dealer's Castrol professional which contained a lot of sodium impurities hence I'm using the bottled Castrol syntec platinum 0/20 extended performance.
Re: Will you change your oil? [Re: evois] #4479913
08/05/17 01:05 PM
08/05/17 01:05 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Moisture is the problem with an oil sitting in the pan for an extended period of time without getting hot. I would use a name brand conventional instead and change it out every year.
Re: Will you change your oil? [Re: evois] #4479937
08/05/17 01:33 PM
08/05/17 01:33 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Moisture should not reach the oil. The PCV valve is closed when the engine is off. There should be no way for ambient air to reach the crank-case ... Any by-products of combustion are gone 15 minutes after reaching operating temp. If the cooling system is not leaking, where does this moisture come from ...
I have run low use/miles vehicles for 5 years on the same oil. We have a member here that has 62,000 miles on his AmsOil (with by-pass filtration). Point being that oil is a lot tougher than most think. It can sit for years doing nothing and not degrade.
Cold is the biggest problem. Cooling to sub-zero conditions at just the right rate can lead to gelation. That will not happen in a garage. I'd just let it be smile
Re: Will you change your oil? [Re: evois] #4479938
08/05/17 01:35 PM
08/05/17 01:35 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Same with brakes and clutch.
The fluid needs to be flushed every 2 year because of moisture.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Will you change your oil? [Re: evois] #4479945
08/05/17 01:42 PM
08/05/17 01:42 PM
Deep in the heart of Jersey
BigCahuna Online content
BigCahuna  Online Content
Blackstone opinion is that usage effects oil, not time.,,,
Re: Will you change your oil? [Re: Warstud] #4479971
08/05/17 02:16 PM
08/05/17 02:16 PM
UT
BHopkins Offline
BHopkins  Offline
UT
That would have shown up in the UOA from Blackstone, right?
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Will you change your oil? [Re: evois] #4479985
08/05/17 02:43 PM
08/05/17 02:43 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Someone on this site posted a UOA on big rig that had minimal short trip use on conventional oil over a 10 to 11 year period. The oil was fine.
I would keep the oil in and that would be that.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Will you change your oil? [Re: evois] #4479989
08/05/17 02:48 PM
08/05/17 02:48 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Don't conclude that sodium is an impurity. It's often part of additive package.
What happens to the vehicle over the course of the year? Battery Minder? Driven to get engine and exhaust hot? Fuel stabilizer? Intake checked for mice nests?
2015 Ford F250 w/Powerstroke
Re: Will you change your oil? [Re: evois] #4479992
08/05/17 02:50 PM
08/05/17 02:50 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Times like this make me miss Poprivit.
Do you have plans to drive it in the future?
At 100 miles a year, you could another 50 years on the same oil.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Will you change your oil? [Re: evois] #4480000
08/05/17 02:55 PM
08/05/17 02:55 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Park it hot, and don't worry about it. Change the oil when tires rot off.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Will you change your oil? [Re: evois] #4480005
08/05/17 02:59 PM
08/05/17 02:59 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Wow what a waste...that truck begs to get out more. Oil is fine; as noted above there was a trucker with over 10 years, and I have seen several other UOAs of 4-6 years - all oil in good condition. Agree with making sure it gets good and warmed up when it DOES get driven.
Although the oil is fine, if you used a paper oil filter you may want to consider changing to a synthetic media filter. Changing oil every 5 years would likely be overkill.
Thick vs Thin test: 15k / 43k miles complete
Re: Will you change your oil? [Re: evois] #4480011
08/05/17 03:07 PM
08/05/17 03:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Easily Easily Easily Easily
I have never had an oil filter go bad from sitting. Ever.
Re: Will you change your oil? [Re: evois] #4480018
08/05/17 03:10 PM
08/05/17 03:10 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
It will be fine, you should drive it a bit more though. Cars need exercise just like any other equipment. Put some stabil in the gas and run premium
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Will you change your oil? [Re: evois] #4480035
08/05/17 03:42 PM
08/05/17 03:42 PM
Upstate NY
Upstate NY
Page 1 of 3 1 2 3
