Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
75 registered (2009Edge, Artem, andyd, badtlc, AandPDan, 2K2AcuraTL, 6 invisible), 1413 Guests and 39 Spiders online.
65261 Members
67 Forums
285507 Topics
#4479904 - 08/05/17 12:52 PM Front End Parts Lexus LS400
Gebo Offline
Loc: VA
Several years ago and old mechanic asked me if I had replaced my ???? on my front end. He said these wear out and make the front end loose and most people don't know to replace them. They were not very expensive and I don't think it affected the alignment. I'm thinking they are rubber????
He's no longer around to ask and I am wondering if any of you know what he was referring to. It wasn't ball joints or tie rod ends.
It was bout 120K miles ago and when he replace them my car's front end got very tight and had much greater steering response.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4479933 - 08/05/17 01:28 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
Oro_O Offline
Loc: Seattle-ish, WA
He was probably referring to sway bar bushings, which stabilize the sway bar to the frame mounts.
I doubt he meant control arm bushings, those are harder to change and don't wear that quickly. 150k would be about the wear point for sway bar bushings on the front on many vehicles. On my SUV, I replaced them with polyurethane ones to stiffen it, on the cars I just replace with rubber to keep it less harsh.
Edited by Oro_O (08/05/17 01:29 PM)
#4479947 - 08/05/17 01:44 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
Gebo Offline
Loc: VA
That's it! Sway bar bushings. Thank you.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4480096 - 08/05/17 05:19 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
L_Sludger Offline
Loc: Ohio
too many cars and oil combinations to list in 150 characters or less
#4480160 - 08/05/17 07:25 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
Gebo Offline
Loc: VA
Number 12
I don't know what 9 is?
Edited by Gebo (08/05/17 07:26 PM)
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4480228 - 08/05/17 08:49 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
Oro_O Offline
9 and 10 are both control arms, with replaceable bushings a shown. They are a different design than the "A" arm you see for the upper (#3). 9 is for toe control. 10 is called the lateral control arm.
I made the assumption these had dual A arms and those bushings wear less. It would be worth inspecting those bushings on a car with 270k miles. There's also a bushing between 10 and the steering knuckle that is not shown, it's pressed into the knuckle and not visible.
#4480324 - 08/05/17 10:51 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
Brybo86 Offline
Loc: Chicago, IL
I think you are talking about the strut rod bushings
This is very Common google it and check clublexus/lexusownersclub
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
#4480345 - 08/05/17 11:23 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
L_Sludger Offline
Loc: Ohio
Yeah Brybo it is gonna be the strut rod, probably not the sway bar bushings. Therefore, number nine on the link I posted above.
Sucks because the sway bar bushings are a cheap and easy way out. The strut rods are not. You gotta get the whole thing from Toyota and they ain't cheap. But they do wear out with alarming regularity. I'd say they are the only true wear item on an LS400!
FYI Lexus doesn't sell the bushing separate for the strut rod. Only the whole unit. You can get aftermarket bushings but .. it's an LS400 and they spent hundreds of millions to tune the suspension bushings of that car to make it feel the way it needs to feel.
#4482780 - 08/08/17 02:10 PM Re: Front End Parts Lexus LS400 [Re: Gebo]
nthach Offline
Loc: California
Sway bar bushings - not a bad task to do on these.
Strut rod and control bushings are common things to replace on those older UCF10/20 cars - the LCAs can be a chore. I did the Daizen bushings on a 1991 LS400, it wasn't a fun task and the car wasn't Lexus quiet over the bumps once the lubricant washed off.
The strut rods do affect alignment on these cars - but if you get the control arm and strut rod bushing changed out you'll feel a world of difference but be prepared to lube the bushings with the most tenacious grease you can find every now and then.
