My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
78 registered members (alphadog, Aichiguy, agpatel, bbhero, AdditiveOCD, 9 invisible), 1,357 guests, and 59 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Because I Can #4479811
08/05/17 11:18 AM
08/05/17 11:18 AM
Alabama, United States
Red91 Offline OP
Red91  Offline OP
Since deciding on 5K OCI's, I will be using approximately one 12 quart case per year. This "old SN formula" Quaker State 30wt should fit the bill nicely once I use up my old school Kendall GT-1.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: Red91] #4479815
08/05/17 11:23 AM
08/05/17 11:23 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Hi Red,
Did you sell the Cruze? How much did you get for it? Walmart uses QS for their pit crew oil change service for $18. Good quality oil, I'd use it. thumbsup
Re: Because I Can [Re: Red91] #4479846
08/05/17 11:46 AM
08/05/17 11:46 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Fine oil for the Roadmaster that was built when SF/SG oil was out.
I forget, what is the Kendall, I remember when you got it, just not what API and such. Seems like it was green or blue oil?
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Because I Can [Re: blupupher] #4479899
08/05/17 12:45 PM
08/05/17 12:45 PM
Red91 Offline OP
Red91  Offline OP
Green oil, API SJ. I also have a couple of gallons of CD/SJ Kendall Super D-3 30wt to use in OPE or whatever. It is not dyed green.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: Red91] #4479903
08/05/17 12:51 PM
08/05/17 12:51 PM
Texas
4WD Offline
4WD  Offline
Texas
BiL said he passed over Kendall synthetic at $2/quart saying he knew nothing about it ... how many do they make?
Re: Because I Can [Re: Red91] #4479939
08/05/17 01:37 PM
08/05/17 01:37 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Go baby, go laugh
SAE 30 for the duration. Good on you for sourcing that QS 30. Should work great for many years to come smile
Re: Because I Can [Re: Red91] #4479984
08/05/17 02:42 PM
08/05/17 02:42 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Mix it 50/50
Re: Because I Can [Re: Red91] #4480020
08/05/17 03:14 PM
08/05/17 03:14 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I've been kicking around running a SAE 30 but couldn't find one that's a full syn. Not one labeled as such anyway. I think my M1 HM 10w30 is darn close to a mono 30 anyway
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Because I Can [Re: 4WD] #4480049
08/05/17 04:08 PM
08/05/17 04:08 PM
Red91 Offline OP
Red91  Offline OP
As of now? They produce non dexos synthetic, dexos synthetic, and a euro synthetic. Somewhat redundant that they produce three synthetic 5W-30 oils.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: Linctex] #4480050
08/05/17 04:08 PM
08/05/17 04:08 PM
Red91 Offline OP
Red91  Offline OP
Why?
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: BrocLuno] #4480052
08/05/17 04:10 PM
08/05/17 04:10 PM
Red91 Offline OP
Red91  Offline OP
In two years I'll get my chance to run it. I figure three cases of 30wt for personal use is not even a stash.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: Red91] #4480103
08/05/17 05:24 PM
08/05/17 05:24 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Good job Red91,
The QS SAE 30 (API SN) at 5k mile OCI sounds great to me.
Wish I could get a case of Quaker State 30wt here.......swap you some Penrite for it ?
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Because I Can [Re: Red91] #4480168
08/05/17 07:42 PM
08/05/17 07:42 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Mmmmm modern SAE30 slobber Would LOVE to try straight oils in a modern turbo DI engine. Where do you even find this stuff?
There's no replacement...'scosity for natural viscosity
Re: Because I Can [Re: PeterPolyol] #4480191
08/05/17 08:15 PM
08/05/17 08:15 PM
Red91 Offline OP
Red91  Offline OP
If you are asking specifically about QS 30wt, I've found it occasionally at Walmart in qt bottles and Menard's should stock it too. Most part stores should be able to order it for you.
If you mean modern 30wt oil in general, I've found Castrol and Pennzoil at Walmart. Farm stores should have a decent variety of 30 in various brands, and every parts store I've been in has house brand 30wt. Plenty of options out there.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Because I Can [Re: SR5] #4480194
08/05/17 08:18 PM
08/05/17 08:18 PM
Red91 Offline OP
Red91  Offline OP
I thought you had access to SN Kendall GT-1 30wt? Is it costly?
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Page 1 of 3 1 2 3
