'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
48 registered members (alcyon, Bailes1992, bcossa2001, Agnosto, Astro14, aleneros, 3 invisible), 645 guests, and 52 spiders.
Topics286,049
Posts4,901,492
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Pull to left under heavy braking #4479540
08/05/17 04:33 AM
08/05/17 04:33 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
hey all, iv had this problem for 2 or more years now where the car pulls to the left under very heavy braking. more apparent when driving on motorway at 70mph. reason iv not investigated it further is due to my driving style im always light footed on the brakes and car is usually used in town driving so the problem is never seen unless an emergency hard stop is needed. but these days im using it more for highway driving so its starting to bug me.
car passes the UK MOT fine with sufficient brake force and within the acceptable tolerance limits for balance between left and right.
the car in question is the toyota celica year 2000.
the brake calipers were second hand and came off a scrapyard toyota avensis which are larger than the original celica ones. as such these were fitted along with brand new larger brake pads and discs for the avensis too. this was done in feb 2014.
the car has passed the UK MOT 4 times (4 years in a row, MOT is in May every year) since fitting the brakes.
now my memory doesnt serve me that well but im sure its pulled under hard braking from day one but again too long ago to remember
since then i have replaced the brake hoses for HEL braided ones (in jan/feb 2016), and few months ago i replaced the slider pins and pad guides which still make no difference to the pull.
fingers are being pointed to the calipers now but they dont stay stuck and retract back.
under low braking effort it brakes in a straight line, but when you push down harder on the pedal it starts pulling to the left.
what could cause this to happen?
tyre pressure is even.
im thinking before i spend some money i should swap the pads and discs from left to right wheel to see if pull changes direction?
wondering if this is a hydraulic issue or mechanical and where i should start looking?
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: Pull to left under heavy braking [Re: slybunda] #4479550
08/05/17 05:21 AM
08/05/17 05:21 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
A mechanic friend told me this and it is my understanding with vehicles that pull one way or the other while braking(light or heavy braking) is that:
Whichever way the vehicle pulls, it is the other side brake causing this issue.
In other words, if your car is pulling "LEFT", then it's an issue with the "RIGHT" side brake components, be it the brake line(restricted) or pad sticking(slider pins) or brake caliper not functioning properly.
I'm not sure how I feel about this as it's to opposite of my thinking!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Pull to left under heavy braking [Re: slybunda] #4479554
08/05/17 05:35 AM
08/05/17 05:35 AM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
Rotors and collapsed brake hoses can cause pulling too.
I like the idea of upgrading to the larger brakes.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Pull to left under heavy braking [Re: slybunda] #4479557
08/05/17 05:50 AM
08/05/17 05:50 AM
California
Billbert Offline
Billbert  Offline
California
you also need to check the front suspension bushings for any wear. under heavy braking, a worn bushing(s) can change alignment angles and cause a pull
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: Pull to left under heavy braking [Re: dlundblad] #4479560
08/05/17 05:52 AM
08/05/17 05:52 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
How can a brake rotor cause pulling?
Re: Pull to left under heavy braking [Re: slybunda] #4479564
08/05/17 06:00 AM
08/05/17 06:00 AM
USA
mk378 Offline
mk378  Offline
USA
If the friction surface of the rotor has a ring of rust on it, the pad doesn't work on that area and braking effect is reduced.
Re: Pull to left under heavy braking [Re: slybunda] #4479578
08/05/17 06:34 AM
08/05/17 06:34 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
i just went and checked this and you are correct, the outside surface of the right hand side disc which can be seen through the wheel is fine but the inside part facing the hub has a ring of rust on it. the left side disc doesnt have any rust.
dunno how i missed this when changing the caliper sliders although i was only looking from the outside face of the disc.
the ring is 1cm thick in diameter, dunno if this can affect the brake force by much. i will wait for weather to get better then swap discs and pads from one side to the other and see if the pull goes in the other direction.
what would cause this to happen? discs and pads are about 10k miles old at most. and plenty of pad life left.
Re: Pull to left under heavy braking [Re: slybunda] #4479582
08/05/17 06:39 AM
08/05/17 06:39 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
can tyres cause this issue? just checked and the left tyre is down to 2.2mm tred across the tyre width. the right side tyre has nearly 4mm tred remaining. dunno if the brake pull has caused the left tyre to wear more than the right tyre. alignment is fine.
Re: Pull to left under heavy braking [Re: slybunda] #4479586
08/05/17 06:44 AM
08/05/17 06:44 AM
USA
mk378 Offline
mk378  Offline
USA
You have found the problem, quit fooling around. Replace that rusty rotor. And new pads.
I assume you've also checked the rear brakes?
Re: Pull to left under heavy braking [Re: Char Baby] #4479616
08/05/17 07:35 AM
08/05/17 07:35 AM
USA
mk378 Offline
mk378  Offline
USA
When you're in a curve to the left, the left side of the car is moving slower than the right one.
So when someone like the OP is going in a straight line and put on the brakes, the right brake is bad but the left brake works normally to slow down the left side of the car, the car is going to want to curve to the left.
Re: Pull to left under heavy braking [Re: mk378] #4479627
08/05/17 07:45 AM
08/05/17 07:45 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
iv just checked the rears now and they are fine. looks like i will sort out the front discs and pads
Re: Pull to left under heavy braking [Re: slybunda] #4479713
08/05/17 09:36 AM
08/05/17 09:36 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Regrease the caliper pins and make sure they are moving freely. You can try sanding off the rust ring and see if that resolves the problem. If it does not, then new pads and rotors for the axle
And make a hard stop once or twice a week, get the brakes hot. Don't go crazy, just get them hot
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Pull to left under heavy braking [Re: slybunda] #4479730
08/05/17 09:52 AM
08/05/17 09:52 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Originally Posted By: slybunda
I have replaced the brake hoses.... I replaced the slider pins and pad guides which still make no difference to the pull. Fingers are being pointed to the calipers now but they dont stay stuck and retract back.
I think your right caliper isn't engaging as fast as the left caliper. You could try exercising the caliper piston in and out to free it up.
Re: Pull to left under heavy braking [Re: Warstud] #4479740
08/05/17 10:02 AM
08/05/17 10:02 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
yes it does feel like the caliper is slower to engage.
slider pins have been replaced for brand new ones and greased up with ceratec grease
Re: Pull to left under heavy braking [Re: slybunda] #4480447
08/06/17 05:47 AM
08/06/17 05:47 AM
UK
slybunda Offline OP
slybunda  Offline OP
UK
so an update, today i swapped the discs and pads from left to right. the pull is the same. still pulls to the left. done some very heavy braking sessions today and when i got out i noticed the side it pulls to which is the left that side is hotter than the right side.
so i guess that rules out the discs and pads.
both discs had the inside part suffering from a rust ring.
photos attached
oddly the side of the discs thats visible from the wheel spokes doesnt have a rust ring but there is a discoloration of the outer edge part.
any ideas what would have caused this? pads were free moving and not stuck and the sliders are moving perfectly fine too.
Page 1 of 3 1 2 3
