The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
29 registered members (Agnosto, Bailes1992, carlprop, c502cid, chance, 4 invisible), 634 guests, and 62 spiders.
Topics286,097
Posts4,902,471
Members67,560
Most Online2,967
Mar 10th, 2019
2001 Honda Accord V6, AT, LX 4 Dr questions #4479499
08/05/17 01:21 AM
08/05/17 01:21 AM
Kansas
PurpleT Offline OP
PurpleT  Offline OP
Kansas
Earlier this week my sister in law was in accident and her car was totaled. Did some looking around and found a two owner Honda Accord that for the last 8 year or so was driven by an older gentleman 40 plus miles a day back and fourth to work. He no longer has room for the car in the garage as he purchased a hot rod of sorts to enjoy during retirement.
The car has 145K on the odometer, has been maintained at the local Honda dealership as the PO's son is an employee there, and recently had a remanufactured Honda transmission installed (139K). Overall the car appears to be in good condition with the two major exceptions being it needs tires and there is no record of the timing belt being replaced. The PO was upfront about both issues and with all of the other work that was done at the dealership I am surprised by the TB being neglected.
I have no prior experience with Honda vehicles and I have done some reading online about common issues but would like input from the BITOG community from those who have more experience with this generation of Accord.
I am trying to determine what other items should be replaced as a part of the time belt job. New OE parts will be used for the key components such as the water pump, idler pulley, tensioner roller, camshaft seals, crankshaft seals, and thermostat. I am also planning to replace the other fluids, the coolant, upper and lower radiator hoses, spark plugs, and adjust the valves. What other things should be added to the list? Are there other things I should be looking at as well?
Thanks in advance for the guidance.
Re: 2001 Honda Accord V6, AT, LX 4 Dr questions [Re: PurpleT] #4479559
08/05/17 05:51 AM
08/05/17 05:51 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
New OE timing belt(YES, OE) and all of the other related parts you have already mentioned is an excellent starting place. This can usually be purchased in a whole kit from either Aisin(not Asian) or Mitsuboshi(not Mitsubishi). Both are identical kits(in their own pkgs),IIRC. Aisin makes the water pump and Mitsuboshi makes the belts and tensioner. Amazon may have the best prices.
I believe this generation of Accord also had some Front Cross Member or Sub Frame rotting so, look for that as well, I think on the front passenger side.
https://www.youtube.com/watch?v=R01p2eupalU
Then after that it's just typical stuff!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2001 Honda Accord V6, AT, LX 4 Dr questions [Re: PurpleT] #4479617
08/05/17 07:35 AM
08/05/17 07:35 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Automatic transmission, run away from this slug don't walk.
Re: 2001 Honda Accord V6, AT, LX 4 Dr questions [Re: PurpleT] #4479648
08/05/17 08:12 AM
08/05/17 08:12 AM
Kansas
locomaster1969 Offline
Kansas
I have a 2000 Honda coupe a/t with the v6. I'm almost at 200000 miles. The transmission is the weak link on this car. Yours has a reman Honda tranny in it so it will be good for many, many miles. Ok so it needs tires and timing belt. A set of Michelin defenders will be 560.00. A garage will change the timing belt and components for 1000.00. You can buy a timing belt kit from Rock Auto for around 310.00 and do it yourself or have a friend do it. Change the transmission fluid every 30,000 with genuine Honda fluid. You will need 3 quarts per change and its really easy to do. You have some room to haggle on this car. If the car looks good then have a real discussion with the owner and settle on a price. Honda makes good stuff!!
1986 Yamaha Venture
2000 Honda Accord V-6
2004 F-150
Small engine sales and repair
Re: 2001 Honda Accord V6, AT, LX 4 Dr questions [Re: locomaster1969] #4479731
08/05/17 09:54 AM
08/05/17 09:54 AM
Trav Offline
Trav  Offline
As long as the transmission has a transferable warranty, I have had 3 of the Honda remans fail at about 20K, they are no better than the originals in fact they are worse if that's possible. If the warranty is original purchaser only I still wouldn't touch it with a 10 ft pole.
What do they put in that Honda Koolaid?
