02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
75 registered (93cruiser, Atesz792, 2015_PSD, 1998CamryCE, AP9, AZjeff, 9 invisible), 1574 Guests and 38 Spiders online.
65303 Members
67 Forums
285855 Topics
Page 1 of 2 1 2 >
#4479469 - 08/05/17 12:09 AM What ratio do you use with tcw3 ?
leroyd92 Offline
Loc: AZ
The grounds keeper at my work have been fighting a sluggish 700cc efi Polaris motor for the last year.
Its hard starting, doesn't like to pull up a hill ect.
Yesterday they added 4oz of tcw3 to 10 gallons of regular gas.
They did the normal 9 hour route.(9 hours of contstant running )
This morning they came in and for the first time the motor didnt stall. It didn't idle very well, but it idled until it warmed up.
They are going to keep me in the loop, I'm really excited to see how many gallons it takes before things start changing.
I use 1 or 2 oz per 5 gallons. I always felt this was a ( maintenance ) dosage and not really for cleaning, maybe i was wrong ?
Edited by leroyd92 (08/05/17 12:11 AM)
Supertech Junky
#4479489 - 08/05/17 01:04 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
Linctex Offline
Loc: Waco, TX
Hmmmm... curious.
I wonder if sea-foam would've done the same thing?
#4479505 - 08/05/17 01:54 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
Marco620 Offline
Loc: Deplorable Kansan,HK fan!
Nope, just use redline si1 or Gumout Regane.
2015 Civic 162k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Moog links Borla Exhaust/Vibrant Resonator/Tein Suspension
Go Nashville Predators!
#4479566 - 08/05/17 06:08 AM Re: What ratio do you use with tcw3 ? [Re: Marco620]
krismoriah72 Offline
Loc: wv
Top end is probably shot. The valve guides are not good in Polaris which causes loss of compression .. do a compression test Ive had to do 2 top ends on Polaris due to inferior design of the valve guides and airbox sealing.
#4479644 - 08/05/17 08:09 AM Re: What ratio do you use with tcw3 ? [Re: Linctex]
leroyd92 Offline
Loc: AZ
Originally Posted By: Linctex
Hmmmm... curious.
On Monday,i might have them do 10 oz of marvel mystery oil or sea foam to the tank.
Supertech Junky
#4479656 - 08/05/17 08:25 AM Re: What ratio do you use with tcw3 ? [Re: krismoriah72]
leroyd92 Offline
Loc: AZ
From what they are saying, the hard start and loss of power happened randomly when their bulk fuel tank had ( strange ) smelling winter fuel in it.
It was in flagstaff, then switched out for another unit once it started running bad.
We will see, they might use several different things. @ this point its disposable to the company.
I wouldn't mind buying it and rebuilding the motor/top end.
Supertech Junky
#4482552 - 08/08/17 10:01 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
JeepWJ19 Offline
Loc: PENNSYLVANIA
640:1 (1oz per 5 gallons)
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
#4521032 - 09/20/17 08:51 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
-SyN- Offline
Loc: Tornado Alley
^^^What Jeep said! Been using this ratio @ every possible fillip for the past 17.4 years.
Mainly using Pennzoil Marine XLF ELF.
Using my old Lucas Fuel Treatment 5.25 oz bottles.
Leroy: Just keeping doing what your doing with your ratio.
17 Ram 2500 6.7L CTD- >Rotella T6 5W-40
14 GMC Sierra 5.3L-->PP (HM) 10W-30
12 Ford Edge-X2 Limited & SE->PP (HM) 10W-30
#4521102 - 09/20/17 10:20 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
-SyN- Offline
Loc: Tornado Alley
I also have used this same ratio --->640:1 in ALL our lawn & garden equipment.
Never an issue with using E10 fuel.
#4522692 - 09/21/17 10:30 PM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
dblshock Offline
Loc: WI.
Polaris has cam wear issues bigtime..here's a Honda 500 Rubicon piston 10 years on 640:1..hope this helps
Edited by dblshock (09/21/17 10:31 PM)
16 Civic Coupe Touring
640:1 TCW-3 E091
Edge 0/40/XG7317
Firehawk Indy 500
06 4Runner SR5 135k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
#4524119 - 09/23/17 03:27 PM Re: What ratio do you use with tcw3 ? [Re: dblshock]
TheKracken Offline
Loc: Fort Worth TX
What does 640:1 equal out to in oz to gallons? Ive been using 4 oz to 10 gallons.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
#4524125 - 09/23/17 03:31 PM Re: What ratio do you use with tcw3 ? [Re: TheKracken]
BobFout Offline
Loc: Indiana
You've been using it at the 320:1 ratio.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#4524509 - 09/24/17 03:47 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
ChrisD46 Offline
Loc: GA.
Here is a great tool for figuring out the ratio : http://www.csgnetwork.com/oilfuelcalc.html
I have used 640:1 ~ 1280:1 ratio (depending on vehicle) .
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
#4526665 - 09/26/17 11:44 AM Re: What ratio do you use with tcw3 ? [Re: leroyd92]
2012AccentSE Offline
Loc: TX
What are the dangers of using TCW3 in a 4 stroke?
2008 F150 KR 5.4L 3v
Left over oil mix...
Purolator One PL24651
2010 Corolla 1.8L
Mobil 1 5w20
Toyota OEM
2014 CFMoto 650NK
Rotella T6 5w40
CFMoto OEM
#4526927 - 09/26/17 05:47 PM Re: What ratio do you use with tcw3 ? [Re: 2012AccentSE]
Surestick Offline
Loc: Cold Lake, Alberta, Canada
If you are using the 640:1 ratio there doesn't seem to be any. If you use a more two-stroke like ratio you could get carbon build up and plug fouling.
There's always the chance it does nothing and you're wasting a few cents every fill-up.
Page 1 of 2 1 2 >
