This was performed after the break initial break in (100-200 miles) with conventional oil.
Comments from Blackstone:
Wear metals read pretty high in this sample compared to averages, but a good amount of this is just lingering wear-in, and that should wash out with time. Note that chrome is pretty high, and that's not a metal we always see reading high in wear-in situations. It shows ring wear, though if it improves going forward, it should be all right. Silicon is from sealers, and it should improve too. Aluminum and iron show piston and steel wear, while copper is from brass/bronze and lead is from bearings. If the engine runs well, just check back next oil for progress.
First Oil Analysis(about 1000 miles on the engine, 800-900 miles in the oil):
Sample Date 7/27/2017
Make Up Oil 0 qts
ALUMINUM 7
CHROMIUM 9
IRON 25
COPPER 46
LEAD 12
TIN 4
MOLYBDENUM 69
NICKEL 2
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 110
SILICON 34
SODIUM 4
CALCIUM 1226
MAGNESIUM 549
PHOSPHORUS 860
ZINC 1032
BARIUM 0
Values Should Be*
SUS Viscosity @ 210°F 78.7 75-90
cSt Viscosity @ 100°C 15.19 14.3-18.2
Flashpoint in °F 430 >380
Fuel % Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.1 <0.6
Make Up Oil 0 qts
ALUMINUM 7
CHROMIUM 9
IRON 25
COPPER 46
LEAD 12
TIN 4
MOLYBDENUM 69
NICKEL 2
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 110
SILICON 34
SODIUM 4
CALCIUM 1226
MAGNESIUM 549
PHOSPHORUS 860
ZINC 1032
BARIUM 0
Values Should Be*
Water % 0.0 0.0
