Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
65 registered members (arowbat, alarmguy, AndyB, Astro_Guy, avi1777, 69Torino, 8 invisible), 822 guests, and 56 spiders.
Topics286,106
Posts4,902,681
Members67,563
Most Online2,967
Mar 10th, 2019
12 Pentastar, Magnatec 5w30 high copper #4478737
08/04/17 05:59 AM
08/04/17 05:59 AM
Australia
supercity Offline OP
Australia
2012 Journey 3.6L
6 Month 6600km
Severe service
Al 3
Ni 1
Cr <1
Fe 8
Cu 36
Pb <1
Sn 1
Ti <1
Si 17
Na 3
K 1
Mo 86
B 128
Mg 11
Ca 2326
Zn 974
Ph 806
S 4174
Water <0.1%
Fuel <0.1%
Soot 0.5%
KV40 53
KV100 9.0
VI 150
TBN 6.3
PQ <10
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478743
08/04/17 06:12 AM
08/04/17 06:12 AM
NY
demarpaint Offline
demarpaint  Offline
NY
They use a copper oil cooler, and in some instances show higher than normal copper readings for years and many thousands of miles. If this is your first UOA for the vehicle keep an eye on it and see if it slowly trends down. It's normal for a Pentastar.
God Bless Our Troops
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478747
08/04/17 06:22 AM
08/04/17 06:22 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Lead is low so the copper is not from engine bearings. If it has a oil cooler that could be the source, some are pure copper and seemingly leach forever.
Its not a bronze or brass bushing as the tin is low. I am not familiar with this engine but I cant think of any part with a high copper content other than a cooler or some sort of fittings.
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: Trav] #4478750
08/04/17 06:25 AM
08/04/17 06:25 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Remember how high my copper was on the first UOA for the Rubicon? 145, everything else was fine. They shed a lot of copper and for a long time, it comes from the oil cooler.
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478754
08/04/17 06:28 AM
08/04/17 06:28 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
The copper isn't from the bearing, I wouldn't be concerned.
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478767
08/04/17 06:43 AM
08/04/17 06:43 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Pentastar engines often give high copper.
Which Oz Magnatec 5W30 did you use ? The semi-synthetic GF-5 "Fuel Saver"' or the full synthetic A3/B4 "Stop Start" ?
That is decent zinc for an SN oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478787
08/04/17 07:04 AM
08/04/17 07:04 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Looks OK - how many total KM on the vehicle?
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478790
08/04/17 07:10 AM
08/04/17 07:10 AM
Australia
Australia
It's Fuel Saver GF-5.
Yeah the lab commented it could be from the oil cooler. I wasn't sure if it had a copper oil cooler or not.
I'm glad to see healthy TBN. It seems to have done well after 6 months, I think I could try GTX 10w30 next time.
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: bigt61] #4478792
08/04/17 07:11 AM
08/04/17 07:11 AM
Australia
Australia
85000km
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: demarpaint] #4478799
08/04/17 07:38 AM
08/04/17 07:38 AM
MD
AirgunSavant Offline
MD
Nice! You saved the day:)
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478838
08/04/17 08:37 AM
08/04/17 08:37 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Phos is over ILSAC GF5 limits No Biggie.
Did the OP run a HD oil before this run causing a carryover?
I enjoyed my last run with Magnatec 5w30 GF5 better than anything before or after.
The QSUD aint no slouch either.
Great to find decent oils these days for 20 quid a jug!
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478879
08/04/17 09:17 AM
08/04/17 09:17 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
I would not sweat the copper either. My 14 Jeep Wrangler with the Pentastar also puked high copper for quite awhile. 40 ppm was the universal average for it and mine hovered around 30-45 ppm every oil analysis.
2019 Toyota Tacoma 3.5L (MileSyn 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4478900
08/04/17 10:00 AM
08/04/17 10:00 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Its not just the Pentastar, a lot of engines show high copper these days because oil coolers are more and more common. I remember some of the first vehicles that this showed up on were late Gen-IV GM F-bodies when the LS engine first came out.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4479055
08/04/17 02:13 PM
08/04/17 02:13 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
The only other source of copper could be the piston pin bushings, but as already mentioned the corresponding alloyed metals are not showing up in same proportions as the copper.
There's no replacement...'scosity for natural viscosity
Re: 12 Pentastar, Magnatec 5w30 high copper [Re: supercity] #4479169
08/04/17 05:16 PM
08/04/17 05:16 PM
Colorado
newtoncd8 Offline
newtoncd8  Offline
Colorado
Not to alarm the OP, but perhaps my Pentastar may be an exception???
5,000 mile runs on a mix of PP/PYB.
12 Jeep GC, 04 Lexus RX330, 77 MG-B
11 Audi A4, 01 Audi A4
99 Lexus ES300, 98 Isuzu Trooper
94 & 91 Acura Integra, 88 Toyota Camry,
84 Honda Accord, 70 Pontiac LeMans,
62 Ford Galaxy 500
