I use the Napa Gold 1348 filter for my Kohler engine application, have since factory filter came off. I get them for
Likely next time though might just use the noted and readily available Super Tech 3614 next time,
The topic Fram PH8170, is a 'made for' Fram filter (in India) with metal endcaps and coil compression spring. Looks ok but not for the ~$10+ I'm seeing online.
'IME', no reason to pay more for an OPE application than the readily available automotive application. In this case the slightly longer 3614 and equivalent applications should work fine on the Briggs.
