Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
58 registered members (2strokeNorthstar, aquariuscsm, ammowaster, 69GTX, AdditiveOCD, 10 invisible), 1,193 guests, and 42 spiders.
Topics295,090
Posts4,927,596
Members66,684
Most Online2,553
Oct 27th, 2018
2006 Toyota Corolla, improved piston ring design? #4478574
08/03/17 08:08 PM
08/03/17 08:08 PM
Peterborough
ryan2022 Offline OP
ryan2022  Offline OP
Peterborough
Hi guys,
Looking at the possibility of buying a 2006 Corolla to replace the versa.
The corolla has higher mileage and has the 1.8 liter engine.
Was the piston ring design improved after 2002?
The car is clean with no rust. Runs smooth.
I'm still thinking of keeping the versa....but I'm not sure how reliable it's going to be in the long run.
Thanks.
Ryan
2011 Subaru Impreza Hatchback 5w30 kendall synthetic blend
2001 Honda Civic 5w20 Mobil 1 High mileage synthetic
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478583
08/03/17 08:16 PM
08/03/17 08:16 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Interested in this too; looking @ 2005 Vibe, manual; 120K and super clean.
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478586
08/03/17 08:20 PM
08/03/17 08:20 PM
Peterborough
ryan2022 Offline OP
ryan2022  Offline OP
Peterborough
One word of caution on the 5 speed, I've heard they can be problematic. I've also seen them with mega high mileage! I would change the fluid if you do nab it!
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478588
08/03/17 08:22 PM
08/03/17 08:22 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
It is the improved design after 2003 in all 1zzfe engines.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478592
08/03/17 08:27 PM
08/03/17 08:27 PM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
It's a good engine and a good car.
We gave our 2006 to our daughter. She's nearing 200,000 miles. No maintenance issues. No oil burning.
Talked about it in this thread: Warning Valve Train pics after using cheap oil
Ah...I've been had by photobucket...
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478623
08/03/17 08:57 PM
08/03/17 08:57 PM
PA
faramir9 Offline
faramir9  Offline
PA
Oil consumption issues from the 8th gen Corolla/Prizm were greatly reduced by the engine re-design for the 9th gen, starting in 2003. My '05 Corolla LE has burned maybe an ounce or two in just under six months and 5,000 miles. (Went from the tiniest bit past Full on the stick to precisely at Full.)
Never say never with an 11-12 year-old car, but oil consumption should not be an issue in whether or not to buy an '06 Corolla. Enjoy.
2005 Corolla LE, 1.8L
Valvoline MaxLife HM full-syn 5w-30
Continental TrueContact 195/65R15
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478651
08/03/17 09:45 PM
08/03/17 09:45 PM
Upper Midwest by the Lakes USA
SumpChump Offline
SumpChump  Offline
Toyota seems to take twice to learn each lesson. My oil thirsty 2008 Scion XB loves to drink oil, guess why?.... Oil return holes are too small in the piston and they coke up. Conveniently for Toyota if it drinks 1 quart approximately every thousand miles that's completely OK. Apparently pre-detonation due to carbon deposits in the combustion chamber is also completely acceptable and pleasurable motoring according to Toyota.
Boy I bet they regret the fact that I can drain and refill my own ATF are using the dipstick they so foolishly left in the design of the transmission. I see they took care of that for the newer cars.
Actually it's a great little car otherwise it's a 2.4 L. It even has his rear wheel sensors that are made so that salt and slush gets inside them and corrodes them. And then if you replace them it happens again about every two years. It appears that their all weather testing scenarios could use some re-design.
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478652
08/03/17 09:50 PM
08/03/17 09:50 PM
Lynchburg, VA, USA
SF0059 Offline
SF0059  Offline
Lynchburg, VA, USA
Unsure it will remain VERSA-tile?! Sorry, I couldn't resist the opportunity for a little dad humor...
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478732
08/04/17 04:47 AM
08/04/17 04:47 AM
Peterborough
ryan2022 Offline OP
ryan2022  Offline OP
Peterborough
Haha thanks sf0059. I like it!
Thanks a ton guys. So hard to buy a car these days.
You guys are lifesavers. Much appreciation as always.
Now I have to start answering a few instead of doing all the asking. Lol
Ryan
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478733
08/04/17 04:50 AM
08/04/17 04:50 AM
Peterborough
ryan2022 Offline OP
ryan2022  Offline OP
Peterborough
Ryan
Re: 2006 Toyota Corolla, improved piston ring design? [Re: ryan2022] #4478897
08/04/17 08:46 AM
08/04/17 08:46 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
The 2004 in my sig burns about 1.5qt on average over a 9000mi OCI. I do use engine braking descending mountains though.
1997 Maxima 190k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 193k, VWB 5w20 + SSS 10w40, MGL4967
