White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
21 registered members (billt460, c502cid, Char Baby, DaleRider, 3 invisible), 796 guests, and 30 spiders.
Topics296,866
Posts4,960,386
Members66,982
Most Online2,688
Jan 19th, 2019
CRC GDI Intake Valve Cleaner Spray on Hyundai #4478492
08/03/17 06:28 PM
08/03/17 06:28 PM
Texas
JustinH Offline OP
JustinH  Offline OP
Texas
Car is a 2011 Sonata with 2.4L GDI engine.
It now has 45k miles and would ping badly on 87 octane, less on 89 and none on 93 octane.
I have ran various fuel system cleaners through the gas tank with no improvement.
Car gets 3750 mile oil changes with Valvoline 5w30 synpower.
I called around a few indy shops to get a price to have the GDI cleaning done. Prices ranged from $99 to $149, and none of the shops really explained what was done, or the service.
Anyways, I bought a 13 dollar bottle of CRC GDI Intake Valve cleaner from Amazon, decided to try it out. I bought the stuff because it had decent reviews, and it had a permanently affixed straw to the bottle. I was worried about blowing a plastic straw into a running engine!
Had my wife hold the throttle around 1500-2000 RPM's while I sprayed the can of cleaner into the intake.
Car sputtered a little bit but never stalled, and there was no smoke out of the tailpipe or unusual sounds.
Reading the instructions says to shut the car off after spraying in the whole bottle for one hour, and let it heat soak.
Then restart the car, and take a spirited drive.
I followed the directions exactly and never had any smoke or unusual sounds out of the engine.
So, I'm happy to report that I have burned two full tanks of Sams Club 87 octane fuel with almost no pinging at all.
Temperature has been around 100f the whole time. I can recall one time it pinged very slightly at a low speed in the past two tanks of gas. Other than that nothing.
I am not recording timing or anything with an OBD2 scanner, but I can feel the ECU is pulling timing on the 87 octane fuel, and it runs much better on 93, but I'll stick with 87 its not a Maserati.
I'll continue to dump a bottle of Techron into the fuel tank every 3750 miles, as per Hyundai recommendations, and I'll continue with the 3750 mile oil changes (severe service).
This motor is a dirty pig, but its nice to have it well sorted and running on regular fuel. Sams Club is not top tier, but it is a brand new station and they move a lot of gas.
CRC recommends to use their product every 10k miles in a GDI application. I think I might buy it once a year.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478496
08/03/17 06:31 PM
08/03/17 06:31 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Hopefully it has a long lasting effect, and not just a few tankfuls of gas.
God Bless Our Troops
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478516
08/03/17 06:50 PM
08/03/17 06:50 PM
Michigan
Oil_Flunky Offline
Oil_Flunky  Offline
Michigan
CRC GDI works well on carbon filled, short tripped, port injected engines also.
Oil, you need it. Oil snobbery, you don't need it.
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478544
08/03/17 07:21 PM
08/03/17 07:21 PM
Maryland
walterjay Offline
walterjay  Offline
Maryland
Good to hear. I have a Hyundai with a turbo and am thinking about using it. I am not sure if it can be injected and go through the turbo. Does anyone know?
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478552
08/03/17 07:28 PM
08/03/17 07:28 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Drive it spiritedly once a week or so and it should also help.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: walterjay] #4478553
08/03/17 07:28 PM
08/03/17 07:28 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I would unclamp the hose closest to the throttle body, insert the straw, and re tighten the clamp and spray from there.
You could spray through your turbo, but I think you'd only clean the turbo impeller.
"Zed's dead baby, Zed's dead."
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478569
08/03/17 08:02 PM
08/03/17 08:02 PM
Texas
JustinH Offline OP
JustinH  Offline OP
Texas
I will re-read the documentation, but I do believe it says safe for Turbos.
'11 Scion XB
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478571
08/03/17 08:04 PM
08/03/17 08:04 PM
VA
Thax Offline
Thax  Offline
VA
Honestly this is pretty much what I do when I do a fuel induction service. I use a vac line that goes into manifold though , then clean the throttle body separately. Sounds like you have a good maintenance plan with your 2.4L, short OCI on syn is best for this and the 2.0T engine. If you are a DIY guy and dont use a dealership , I would advise to call the dealer periodically to see if your Sonata has any available updates. Hyundai/KIA regularly releases updates or "logic" improvements for various modules and systems. Some can be minor others are a huge benefit. As long as its under warranty it should not cost you a dime. Important updates are for the ECU and TCM modules which modify/improve engine performance,efficiency and transmission shift behavior.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478667
08/03/17 10:38 PM
08/03/17 10:38 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I don't have any pinging driving around town. I think it does on 87 octane in the mountains though, I still don't 100% know what pinging exactly sounds like so I can't say for sure.
I need to head out of town into the mountains with some 87 octane then turn around and fill with 91 and see if it changes.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4478690
08/04/17 12:23 AM
08/04/17 12:23 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Ford and GM both make a pour-can additive designed to de-carbon and de-gunk intakes. I haven't held a can in years, but it's probably just seafoam or Berryman's B-12.
It works best when a LOT is going in QUICKLY.
So much so, that when the end of the can is near, it's supposed to *ALL* go in at once so it kills the engine (flooded) and then let sit for 1-2 hours.
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: Nick1994] #4478842
08/04/17 07:40 AM
08/04/17 07:40 AM
Texas
JustinH Offline OP
JustinH  Offline OP
Texas
Sounds like marbles in a can.
'11 Scion XB
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: Thax] #4478845
08/04/17 07:41 AM
08/04/17 07:41 AM
Texas
JustinH Offline OP
JustinH  Offline OP
Texas
I had the car in the dealer for two recall services, and asked them both times for ECU updates and they ignored me and said it was not necessary and there were none for my car.
I do not like my Hyundai dealer chain, but they are so close to my home I just take it there for recall work.
I am not under warranty, but I do have 10 year 120k mile engine warranty per Recall.
'11 Scion XB
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: Linctex] #4479433
08/04/17 09:41 PM
08/04/17 09:41 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Yes - the old GM TOP ENGINE CLEANER (old name) was very well known to be an aggressive cleaner. It is NOT seafoam or B12. Seafoam is basically so outdated and so inferior to today's cleaner I don't know why people still use it.
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: JustinH] #4479522
08/05/17 01:46 AM
08/05/17 01:46 AM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
I use Amsoil's Power Foam since the GM or Mopar products are a smaller can. Same purpose. A good hour soak after ingesting into the intake when the engine is hot, closed hood after for heat saturation. thumbsup
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: CRC GDI Intake Valve Cleaner Spray on Hyundai [Re: GMBoy] #4481589
08/07/17 08:04 AM
08/07/17 08:04 AM
Morris County NJ
steve20 Offline
steve20  Offline
Morris County NJ
I too, was a fan of the old GM TEC- I believe it was mostly butyl cellosolve. Worked well on every car I tried it on
Steve
