Any news on what happened to this plane?
by Exhaustgases
6 minutes 20 seconds ago
E4OD fluid ?
by Exhaustgases
18 minutes 57 seconds ago
Update password ?
by meadows
Yesterday at 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
Yesterday at 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
Yesterday at 10:40 PM
revive Nicd battery
by Donald
Yesterday at 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
Yesterday at 10:07 PM
ceratec with redline 5w30?
by 08z06
Yesterday at 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
Yesterday at 09:50 PM
I hate stuck thermostats
by jakewells
Yesterday at 09:49 PM
Mag1 75w90
by SavagePatch
Yesterday at 09:32 PM
Old batteries at HD
by bbhero
Yesterday at 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
Yesterday at 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
Yesterday at 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
Yesterday at 08:13 PM
Shure stylus replacement
by aquariuscsm
Yesterday at 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
Yesterday at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Yesterday at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Yesterday at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Yesterday at 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
19 registered (bismic1, CleverUserName, AMC, Exhaustgases, dishdude, ctechbob, 2 invisible), 720 Guests and 39 Spiders online.
65258 Members
67 Forums
285504 Topics
#4478355 - 08/03/17 04:13 PM John Deere spindle
Eddie Offline
Loc: Florida, Cape Coral
Does anyone have experience with the typical life of John Deere blade spindles? If I grab each of the blades on on 42" I can get about 3/8 inch movement at the tip. I think this may be normal but, I have no experience. Mower has 135 hours on it. Ed
CX5 Touring 2.5L :-)
#4478358 - 08/03/17 04:17 PM Re: John Deere spindle [Re: Eddie]
Rand Offline
Loc: NE,Ohio
what deck?
a 261 grooming mower will be different than a stx38
2017 Jeep Cherokee Trailhawk V6
#4478363 - 08/03/17 04:21 PM Re: John Deere spindle [Re: Eddie]
oldoak2000 Offline
Loc: North TEXAS
sandy soil will eat the bearings inside like cotton candy.
IF you're lucky spindles can be dissembled and bearings replaced cheap (few bucks ea ordered on ebay).
Full spindle assemblies cost $$$$$
#4478366 - 08/03/17 04:28 PM Re: John Deere spindle [Re: Eddie]
dlundblad Offline
Loc: Indiana
Does the mower use anything between the bolt and the blade?
I had a similar issue with a Kubota G1800. The blade retainers were shot. They are bowl shaped and when the blade hits something, they give as opposed to the blade or in some situations, the entire spindle. The more things the blade hits and the more time they spend being compressed, the less tension they have.
http://www.messicks.com/part/76550-34350/retainer
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4478375 - 08/03/17 04:39 PM Re: John Deere spindle [Re: Eddie]
Linctex Offline
Loc: Waco, TX
If this is the cheapest 42" mower JD sells, I think the entire spindle with bearings is about $22-$25
#4478422 - 08/03/17 05:55 PM Re: John Deere spindle [Re: Eddie]
bioburner Offline
Loc: Minnesota
Something isn't right. As oldoak stated I would bet the bearings are not good. Pull the blade and see if you can move the spindle. Not that hard to drop the deck and take the whole spindle assembly off. The bearings should only be about $4 each. Some deck designs don't put a bearing guard on to protect the bearings above the blade and string, wire sand and gravel can rapidly erode the bearing seal. Main reason I went with a Husqvarna as they put on a good guard on as it seems I will always find the remains of the horse fence and string from the feed bales.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4478541 - 08/03/17 08:13 PM Re: John Deere spindle [Re: Eddie]
Eddie Offline
Mower is a JD L111 42" deck. Has covers on each top belt pulleys and the bottom of the spindle is covered with the blade attachment adapter. So back to my original question-typically how long should one expect JD spindles to last in normal homeowner use? Ed
#4478680 - 08/04/17 12:42 AM Re: John Deere spindle [Re: Eddie]
Linctex Offline
Loc: Waco, TX
Sorry, Ed.
There no "one" answer.
Every lawn is different.
Dry & rocky ground is far harder on mowers than mowing lush green grass.
The bearing that come with are typically pretty cheap, and it's Russian roulette. Some last 2 years, some last ten years. $4 bearings last 2-3 years, and $10 bearings last 10 years.
#4478801 - 08/04/17 07:40 AM Re: John Deere spindle [Re: Eddie]
The_Eric Offline
Loc: Iowa
No, that's not normal. For them to have that much slop, they should be making quite the racket.
Replacement spindles- also called quill or mandrels will run somewhere around $100 or a bit more.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#4478812 - 08/04/17 07:51 AM Re: John Deere spindle [Re: Eddie]
JTK Offline
Loc: Buffalo, NY
3/8" play in any direction is a crazy amount. I would say typical lifespan for a cheapo unit would be ~5yrs/200hrs, but like said, there's a ton of variable at play. Problem with them is, most decks are typically so loud during normal operation that you don't notice a noisy spindle. I'd pop the belt off and give them a spin by hand to see how they roll.
Edited by JTK (08/04/17 07:52 AM)
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4478852 - 08/04/17 08:49 AM Re: John Deere spindle [Re: The_Eric]
SHOZ Offline
Loc: Illinois
Yes if they are bad they will roar like crazy.
My JD F510 with 38" deck and dual blades I bought in 1999. The first time I greased the spindles I blew out the seals on one. Fast forward to 15 years later and the noise drove me to rebuild them. A couple bearings each and one fan for each cost $50 total. When I tore down the bad one it was obviously the bearings, but I can't say it had any slop. I never have rebuilt the other one, so it's going on 18 years at about 50 hours a year of use with no problem.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4478950 - 08/04/17 11:18 AM Re: John Deere spindle [Re: Eddie]
Win Offline
Loc: Arkansas
Mower is a JD L111 42" deck. .... So back to my original question-typically how long should one expect JD spindles to last in normal homeowner use? Ed
Sounds about right. I had to pretty much rebuild the entire deck on my 42" JD at around 175 - 180 hours.
I use mine to mow some of my commercial property, but it's not like I'm brush hogging with it. The decks just don't last. Complete replacement decks are available, but you already know ... or will know .... this.
If you don't replace the spindles now, you will be replacing the deck sooner rather than later.
09 Torrent 3.6 V6 M1 0/40
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 Fram 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
