Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
101 registered members (bbhero, ArrestMeRedZ, 2015_PSD, Anduril, Astro14, 17 invisible), 2,166 guests, and 30 spiders.
Topics287,749
Posts4,933,796
Members67,850
Most Online2,967
Mar 10th, 2019
Hobbs hour meter install on mower #4478175
08/03/17 12:34 PM
08/03/17 12:34 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
My brand new $8,000 mower only logs hours with the blades running because they wired it to the pto which I think is stupid. I installed a Honda enm hour meter that hooks to the spark plug. It works great, but
Every time we get a good rain the screen goes blank where you cant read it. You can kind of see that it's still working, but anyways can I install hobbs hour meter on this machine? I'm assuming it's just a ground connection and it gets power from the ignition? Do they draw a lot of power?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478187
08/03/17 01:05 PM
08/03/17 01:05 PM
MD
AirgunSavant Offline
MD
Sorry I can't help with the "how to" but I thought this was a bit gimmicky until I got my new mower.
Every time I mow I use it. I could do without the push button start and the security code but the panel offers a OLM
a time clock, hour meter, service light, tachometer, and diagnostics etc.
I use the tach daily as my mower has a sweet spot for smoothness and efficiency and I go right to that RPM- makes life easy.
Good Luck!
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478198
08/03/17 01:16 PM
08/03/17 01:16 PM
Houston, Texas
Houston, Texas
I'm just curious as to how complicated of an install it would be and if it would interfere with other things.
Re: Hobbs hour meter install on mower [Re: AirgunSavant] #4478209
08/03/17 01:24 PM
08/03/17 01:24 PM
Houston, Texas
Houston, Texas
I don't get why I have so many problems with these battery powered LCD meters. This is like the third one too. I used to use briggs and Stratton meters which typically lasted 7 years until I got a bad batch of those.i think the problem is they sit on the shelf too long and the battery is near dead by the time it gets sold.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478233
08/03/17 01:40 PM
08/03/17 01:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A Hobbs meter uses so little power, they'll run for WEEKS on a battery.
Tie into the ignition, that's the most common source. + and - , Very easy to hook up.
Don't EVER leave the key on, or you'll come back with 1000 hours added to it. That's why most are run through an oil pressure switch.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478234
08/03/17 01:40 PM
08/03/17 01:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Very easy to wire, and will not affect any systems.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478240
08/03/17 01:45 PM
08/03/17 01:45 PM
MD
MD
You need a store that has quick turnover. I suspect they are very old stock as you suggest!
Re: Hobbs hour meter install on mower [Re: Linctex] #4478280
08/03/17 02:26 PM
08/03/17 02:26 PM
Houston, Texas
Houston, Texas
I haven't looked at it yet, but I'm hoping it's just a spade connector hooked into the ignition. I'm looking for a way to wire it up without splicing the existing wires.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478287
08/03/17 02:36 PM
08/03/17 02:36 PM
Houston, Texas
Houston, Texas
I haven't looked at how the wires are connected, hopefully it's just a matter of bolted it on to the existing terminal.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4478390
08/03/17 04:57 PM
08/03/17 04:57 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
I recently put one on my JD 317, not a Hobbs, but a similar china made analog hour meter.
Simple 2 wire install, power wire and ground.
My Deere has switched power going to the headlight switch, so i tied into the feed wire going to the headlight switch.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4479002
08/04/17 12:36 PM
08/04/17 12:36 PM
Houston, Texas
Houston, Texas
When you say tie, do you mean you spliced into a wire on the machine? I'm trying to figure out an area to mount it without doing that.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4479649
08/05/17 08:13 AM
08/05/17 08:13 AM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Yes I cut the wire and spliced into it.
I don't see any way you're going to do it without splicing unless you have some kind of unused accessory wire somewhere.
cut the wire, use some good heat shrink butt connectors or solder and heat shrink tubing.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4479884
08/05/17 12:20 PM
08/05/17 12:20 PM
Houston, Texas
Houston, Texas
Ok I can do that no problem. I have an entire container of heat shrink butt connectors. I'll just squeeze the wire for the hour meter into it and hang the meter somewsomewhere protected from the elements.
I have an analog style meter on my boat and it's 25 years old. Fixing to turn over 1000 hours.
Re: Hobbs hour meter install on mower [Re: cronk] #4480771
08/06/17 12:50 PM
08/06/17 12:50 PM
Houston, Texas
Houston, Texas
What do you think caused the hour meter screen to go black and come back randomly? Even though it goes blank, it still seems to log time. I thought it was the rain, but it got rained on yesterday and worked the whole day.
Re: Hobbs hour meter install on mower [Re: motor_oil_madman] #4481780
08/07/17 12:37 PM
08/07/17 12:37 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Sometimes I have seen the digital ones go blank or all black if left out in direct sunlight on a hot day.
I prefer the analog ones for longevity and reliability.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
