Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
90 registered members (2009Edge, ABomb369, aquariuscsm, AndyB, 4WD, 8 invisible), 1,421 guests, and 34 spiders.
Topics295,209
Posts4,929,980
Members66,711
Most Online2,553
Oct 27th, 2018
OEM for SEALS such as Pinion or ..who else?? #4478124
08/03/17 10:08 AM
08/03/17 10:08 AM
Upper Midwest by the Lakes USA
SumpChump Offline OP
2005 Ram 1500 4WD with corporate 9.25 rear end needs rear pinion seal. Go OEM or is there better?
Also, is it a pound foolish to not replace Ujoints while under there? (they are fine now)
Re: OEM for SEALS such as Pinion or ..who else?? [Re: SumpChump] #4478155
08/03/17 10:54 AM
08/03/17 10:54 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Driveshafts are easy enough to remove when the time comes if necessary. I wouldn't bother, personally.
Re: OEM for SEALS such as Pinion or ..who else?? [Re: SumpChump] #4478159
08/03/17 11:00 AM
08/03/17 11:00 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
I have probably done 15+ pinion seal replacements and found using a quality brand like Timken, SKF or National does the job the same as OEM counter part. Many times the OEM counter part will just be a reboxed one from the previously mentioned brands.
As to U-Joint replacement, if factory "sealed for life" ones are installed, I would replace while there since half the job is already done for removing the driveshaft for the pinion seal. I would also entertain the replacing the rear transmission seal also and be done with everything.
2018 RAM 2500 Cummins 6.7L (Delvac 1300 15W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: OEM for SEALS such as Pinion or ..who else?? [Re: SumpChump] #4478162
08/03/17 11:05 AM
08/03/17 11:05 AM
Chicago, IL
gomes512 Offline
gomes512  Offline
Chicago, IL
I've used SKF seals and they seem to seal and hold up well. Wouldn't bother with the driveshaft ujionts as posted above.
Re: OEM for SEALS such as Pinion or ..who else?? [Re: SumpChump] #4478435
08/03/17 05:11 PM
08/03/17 05:11 PM
Canada
nobb Offline
nobb  Offline
Canada
As long as you are using a brand name like SKF, Timken, National, it should be ok. There is alot of science behind seals, but any reputable company is more than capable of designing these properly.
The only risk is on rare occasions, the OEMs update their part design to make improvements but the aftermarket manufacturers lag behind and are still supplying an older design. The rear axle seals on 3rd gen 4Runners is one specific example of this.
