Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
120 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 12 invisible), 1,547 guests, and 34 spiders.
Topics296,753
Posts4,958,245
Members66,964
Most Online2,577
Jan 14th, 2019
greasing a new trailer axle? #4477841
08/02/17 09:17 PM
08/02/17 09:17 PM
Houston, Texas
motor_oil_madman Online content OP
motor_oil_madman  Online Content OP
Houston, Texas
I read an article made by dexter axle that says you should grease a new axle after 50 miles then like every 12,000 after that. It didn't really mention many details, but it was from 2002 I think. Should the axle be greased after a short period like it says?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477859
08/02/17 09:41 PM
08/02/17 09:41 PM
Houston, Texas
Houston, Texas
Doesn't really make any sense does it? 12,000 miles seems kind of long doesn't it?
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477863
08/02/17 09:43 PM
08/02/17 09:43 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I did mine that day i got it home in 2004.
ALL 8 bearings were WOEFULLY "dry" - like 3 drops of grease each.
I do mine every 2 years, which is about 10,000 miles of use.
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477866
08/02/17 09:50 PM
08/02/17 09:50 PM
Houston, Texas
Houston, Texas
I've heard on these ez lube axles they just put grease on both the inner and outer bearings and in order to use the ez lube feature you have to pump grease in until it fills the entire hub. I know on my old trailer it took an entire tube to get it where the grease started coming out like they demonstrate. The problem with that is it kind of oozes past that rubber cap and gets on the rim.
Re: greasing a new trailer axle? [Re: Linctex] #4477867
08/02/17 09:50 PM
08/02/17 09:50 PM
Houston, Texas
Houston, Texas
How many pumps did you put in per side? I was just going to put in like 5 or 6 pumps per side and call it good, I think greasing it until it comes out causes too many problems.
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477888
08/02/17 10:54 PM
08/02/17 10:54 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
At work we put in 2 or 3 pumps a year. Were having problems with grease getting pushed into the brake drum and glazing the shoes. Don't know if your particular axle has brakes, but thats an issue we had.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477889
08/02/17 10:55 PM
08/02/17 10:55 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
No,man. You can't blindly just pump grease into the hub. You will blow the rear seal. Look online for the proper way to grease your bearings. Test after each trip by grabbing each hub. A hub that is hotter than the roadway has a problem. Always check the inside of the wheel for grease that has spidered onto the hub....this means you have blown the rear seal. Hope this helps.
Re: greasing a new trailer axle? [Re: FZ1] #4477968
08/03/17 06:05 AM
08/03/17 06:05 AM
Indianapolis, IN
09_GXP Offline
09_GXP  Offline
Indianapolis, IN
He was talking for the Dexter EZ-Lube axles. Those are designed to be greased until the grease comes out the front. The catch is you have to make sure to spin the wheel while greasing to ensure that the rear seal doesn't blow. For that design if you only put in a set amount of pumps you will not be greasing the outer bearing at all.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477979
08/03/17 06:27 AM
08/03/17 06:27 AM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
I have the EZ lube on my trailer and never use them. Some fool at the trailer plant or dealer power gun greased my trailer before we got it and blew the seals out in it, took me a long time and a lot of work to clean the mess up.
Dexter says to repack the bearings yearly but I think that's more for a CYA since the brakes are inspected at the same time the bearings are serviced. I do mine every couple of years. These are the same bearings that were used on cars for years, nobody repacked their front wheel bearings every year, most manuals said to do it when changing brake pads which was often 50k miles and many years.
The biggest thing that I have found over the years is checking the bearing preload after the first 100 miles or so. I have found a couple that needed to be snugged up a little after break in, that also gave me a chance to make sure the bearings were packed with enough grease.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477990
08/03/17 06:52 AM
08/03/17 06:52 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Yes most new trailers need some grease. When using lever type gun one should be able to feel when the hub gets full with a change of resistance. Maybe its a trained feeling having grown up on the farm with everything needing grease. Still have 9 trailers. Got to get rid of some:(. I usually jack the axle up and rock the wheel to check for play and spin the wheel and start to give the hub a few pumps till I feel some resistance. Pretty much at least annually before making a longer haul. Never had on the road failure in 40 years. About the closest failure was after a 2k mile trip with 500 in cold rain got home and the next day was moving the trailer to unload I heard a squeak and the hub had sucked up some water and probably would not have made it more than a couple miles. Trailer was 10 years old at the time and the inner seal was bad. New seal and bearing set $14 and did the other side as well. Its going to TX this fall with my folks pulling it, 1600 miles one way.
Very important IMO to check the play after install of new bearings as they may not have been seated all the way. I like bearing buddy grease system
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4477993
08/03/17 06:59 AM
08/03/17 06:59 AM
The Motor City
Kestas Online content
Kestas  Online Content
The Motor City
I can't understand why they specify greasing after 50 miles. There should be no break-in debris as found with differentials, transfer cases, etc. Bearings shipped by the manufacturer are clean.
Are you sure it isn't just to check for axial play?
Re: greasing a new trailer axle? [Re: Kestas] #4478018
08/03/17 07:28 AM
08/03/17 07:28 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
I have found that most trailers are shipped with the bearings packed(usually poorly) but not the hub being filled.
I also found that sometimes the bearings were not properly seated and way to much play after a short distance
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: greasing a new trailer axle? [Re: 09_GXP] #4478132
08/03/17 10:21 AM
08/03/17 10:21 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't use ANY kind of "bearing buddies" or anything with a grease zerk,
I always pack my wheel bearings by hand.
It's the only way I can GUARANTEE no failures.
Re: greasing a new trailer axle? [Re: motor_oil_madman] #4478172
08/03/17 11:32 AM
08/03/17 11:32 AM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
My 2001 Trailswest 5 horse gets 3-4 pumps of grease per year. I would wipe up the excess that works its way out. When I recently redid the backing plates (Dexter 7k pound, 12x2") I cleaned out all the old grease, repacked the bearings and then pumped in a pile of grease in. There is a large void I found between the bearings that would require a lot of grease to fill. Before the next big trip I will throw in a pile more grease as I rotate the wheel.
Other than a bit of grease that weeped past the seal over the years, they have never blown out.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: greasing a new trailer axle? [Re: Linctex] #4478182
08/03/17 11:57 AM
08/03/17 11:57 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I have seen smaller trailers with zerk fittings and it seems that they only manage to get ONE bearing. Only way to be sure that both are getting grease is to take apart and repack by hand.
