AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
73 registered (4WD, BoiseRob, Bryanccfshr, brages, 01rangerxl, BeerCan, 7 invisible), 1153 Guests and 32 Spiders online.
65294 Members
67 Forums
285753 Topics
#4477813 - 08/02/17 09:33 PM Fuel evap canister on 01 Nissan Sentra.
Mark72 Offline
Loc: Illinois
So I been noticing raw fuel over from back side of car where fuel cap is located. I found that the evap canister is in same location behind back quarter panel. Can a bad gas cap cause pressure build up making the canister release fuel vapor? It is the original gas cap. This I know for sure.
Edited by Mark72 (08/02/17 09:34 PM)
#4477932 - 08/03/17 04:03 AM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
Silverado12 Offline
Loc: Central Virginia
I think the cap is supposed to keep the system sealed. It vents through the purge valve and vent valve.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
16 Challenger R/T Shaker 5.7 manual B5 blue
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
#4478026 - 08/03/17 08:36 AM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
MichiganMadMan Offline
Loc: SE Michigan
I agree with Silverado12, your gas cap is fine and there is something wrong with the purge or vent valve (or both).
Got any codes? 2001 should have fairly standard EVAP diagnostics. The conditions required for the EVAP diagnostic to run can sometimes be tricky depending on your driving cycle, so if you have a scan tool see if there are any pending codes, not just active ones.
Do you notice the raw fuel smell all the time, or only when you are or just recently fueled up?
2015 Chevrolet Impala
2008 Subaru Impreza STI
2004 Suzuki Hayabusa
1987 Honda VFR700F2
2011 Jonsered 2188 Chainsaw-The Judge.
#4478176 - 08/03/17 12:40 PM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
Mark72 Offline
Loc: Illinois
I only ever notice the smell of raw fuel occasionally after I park the car in my garage. I smell it by where the fuel door is under the wheel well. I that the evap mechanism is right there in the same area and someone told me that if the gas cap is old…which it is from 2001, that it may not be venting properly causing the evaporator to burp out the fumes. Is that a possibility? Also, I only notice this occassionaly, and its when it is hot outside.
Edited by Mark72 (08/03/17 12:42 PM)
#4478204 - 08/03/17 01:20 PM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
Eddie Offline
Loc: Florida, Cape Coral
The vapor canister is part of a closed system and should not vent to the atmosphere. The gas vapors in the canister are supposed to vent into the engines intake system when driving. The problem you describe is frequently caused by people over filling the fuel tank by continual trying to top-off the gasoline tank rather than shutting off at the first or second click. I suspect your canister needs to be replaced and the vent valve checked. Ed
CX5 Touring 2.5L :-)
#4478250 - 08/03/17 01:55 PM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
Mark72 Offline
Loc: Illinois
I'm not doubting what you say is true. you guys know a lot more about cars than I do. but strangely, this evap canister that is shaped like a big plastic box has a round drain tube or vent of some nature coming out of it and angling down toward the ground. So it has to be there to release something right?
#4478268 - 08/03/17 02:10 PM Re: Fuel evap canister on 01 Nissan Sentra. [Re: Mark72]
Mark72 Offline
Loc: Illinois
I found a diagram of it. click on this link. to the left of the diagram you see a tube angling downward. The view is as if you were laying on the ground looking up at it.
https://goo.gl/images/3L2FHz
