Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
100 registered members (A310, ABomb369, 928, 53' Stude, Ablebody, 10 invisible), 1,672 guests, and 38 spiders.
Topics290,785
Posts4,850,249
Members66,036
Most Online3,590
Jan 24th, 2017
Can't Get Blade Loose on 48" JD Deck #4477340
08/02/17 11:29 AM
08/02/17 11:29 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm wanting to sharpen the blades on my 48" JD Deck. Problem is I can't get one of the blades off. The guy last year said he couldn't get the one blade off. Just had a throttle cable repaired in a shop and they offered to sharpen the blades but they couldn't get it off with an impact wrench (so he said).
What do I do?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477343
08/02/17 11:34 AM
08/02/17 11:34 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Worse case scenario, remove the pully on top and drop the spindle out.
May require a new spindle if that doesn't allow blade removal.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477349
08/02/17 11:45 AM
08/02/17 11:45 AM
Pittsburgh,PA U.S.A.
JimPghPA Online content
JimPghPA  Online Content
If the threads extend beyond the nut, take a close look at the threads and look to see that they are not reverse thread.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477355
08/02/17 11:52 AM
08/02/17 11:52 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Heat - welding torch, or MAPP Gas torch. Heat the bolt head to to hot. The heat in head will go down the shank some. Use big impact wrench and back it off. If that does not work, 1/8" cut-off disc in grinder and cut the blade off in two pieces so you can then remove the spindle assembly out through the deck and take to machine shop to get the bolt out.
Decent used spindles are $50 on eBay. So if the bolt is permanent, you can drop another in place and a new blade and you're good to go. If the shop can get the bolt out, new blade and good to go.
In any case, they use a compression washer to hold the blade under the bolt head. So use liberal amount of Never-Sieze in those bolts so they can be removed in the future ...
Worst case you must use cut-off wheel to take the bolt head off so you can get blade remnants and compression washer off spindle so it can be removed. Then heat the remaining bolt shaft stub hot and use pipe wrench to grab the stub and back it out ... If you have to go this way, I'd soak the bolt stub spindle end in a shallow can with diesel for a few days before I tried heating and backing out ...
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477385
08/02/17 12:28 PM
08/02/17 12:28 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Just went through this on my Husqvarna. I dropped the deck and took the spindle down from top. Had issue with bolt inside spindle and the entire spindle with housing with new bearings was $28. No brainer with 2 new bearings. Would have had to order just the spindle at $19 plus shipping
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477402
08/02/17 12:42 PM
08/02/17 12:42 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
THANKS GUYS!
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477422
08/02/17 01:01 PM
08/02/17 01:01 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Bigger impact.
2015 Ford F250 w/Powerstroke
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477538
08/02/17 03:38 PM
08/02/17 03:38 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Is the bolt just not turning or is the blade spinning inside the shaft?
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477549
08/02/17 03:56 PM
08/02/17 03:56 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
As stated: I more powerful impact. My JD caused me grief when I tried to remove the blades. I tied my 3/8 impact but, ended up borrowing a 1/2 Chi pneumatic and it zipped right off. Ed
CX5 Touring 2.5L :-)
Re: Can't Get Blade Loose on 48" JD Deck [Re: Donald] #4477604
08/02/17 05:09 PM
08/02/17 05:09 PM
USA
mk378 Online content
mk378  Online Content
USA
Originally Posted By: Donald
Bigger impact.
Yes if the bolt really won't come out it would break. There is no such thing as over-loosening.
Blade bolts seem to always be right hand thread but if you see an "L" in the center of the bolt head that means it is left-handed and you need to turn it the other way.
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477635
08/02/17 05:50 PM
08/02/17 05:50 PM
FL
9050lx Offline
9050lx  Offline
FL
1/2 inch impact with impact sockets only, regular sockets seem to absorb too much of the impact.
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477698
08/02/17 07:29 PM
08/02/17 07:29 PM
Alabama
maintenanceMan Offline
Alabama
penetrating fluid plus heat is often good. The heat makes it wick up in there.
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477704
08/02/17 07:34 PM
08/02/17 07:34 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Wonder if you can spray kroil from the top to get the threads lubricated
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477710
08/02/17 07:37 PM
08/02/17 07:37 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It is a bolt head or a nut?
Re: Can't Get Blade Loose on 48" JD Deck [Re: Gebo] #4477716
08/02/17 07:43 PM
08/02/17 07:43 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Originally Posted By: Gebo
THANKS GUYS!
Did you get it off?
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
