Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
63 registered members (53' Stude, 2013ecof150, aquariuscsm, 65convertible, advocate, Anthony, 6 invisible), 1,105 guests, and 34 spiders.
Topics290,971
Posts4,853,562
Members66,063
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
MMO improved performance, what does it indicate? #4477310
08/02/17 10:43 AM
08/02/17 10:43 AM
Southern NY
MoneyJohn Offline OP
Southern NY
I started doing my own car work this summer, basic stuff like changing fluids etc, nothing fancy. In the past, I would just leave the car to the mechanic for an oil change. Never really bothered much which oil he puts, how much etc. After reading a BITOG, I started becoming more curious what goes in the car.
I changed oil with SuperTech High mileage 5W-30 in my 2006 Sentra. The car has been really sluggish, would take the time to speed up etc. Would struggle go up the hill. I also changed the spark plugs. Planning to do 3-month oil changes for a year to clean up the engine. I will drain the oil this weekend. Last week, I added 10oz of MMO to almost 3 qt of engine oil and went out for a 100 mile trip.
On the way back, I noticed the engine performance improvement. There was a 'pep' if I can put it like that. Next day, I took it on the hill to see how it performs on the uphill slope. It did fairly well. During regular in-town driving, I feel the car being more responsive. Yesterday, I asked DW to take it to work and she also noticed similarly.
I wonder what does it indicate and how this should be approached further? Any pointers welcome. I don't want to go get a can of Kreen but would like to know if that should be the next step.
Thanks in advance.
2015 Subaru Forester 2.5i Premium w/ EyeSight
2006 Nissan Sentra 1.8S Special Edition
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477317
08/02/17 10:54 AM
08/02/17 10:54 AM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
MMO might have thinned out your oil a bit, ive noticed running thinner oil in my minivan made the throttle response improve. About to change oil on my truck to thin and see if it has the same response.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477318
08/02/17 10:54 AM
08/02/17 10:54 AM
NC
Vladiator Offline
Vladiator  Offline
NC
No need to get Kreen. MMO does the same thing, just many people say that it does so a bit "slower" than Kreen. That is a good thing. Stick with MMO. Use 5-10oz in the oil 100 miles before the oil change (every OCI), and use 1oz/1gal ratio for the fuel to give that a good cleaning too. Hopefully you will see even better results in power, responsiveness, and fuel economy, like many of us on BITOG have experienced.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477319
08/02/17 10:55 AM
08/02/17 10:55 AM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
Well if you didn't change the plugs then I would say the MMO did something but since you did the plugs then that is where you got the improved performance from.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477321
08/02/17 10:57 AM
08/02/17 10:57 AM
BerksCounty/Pa.
thorromig Offline
thorromig  Offline
BerksCounty/Pa.
Im sure the spark plug change made a slight difference. Run back to back tanks of a quality fuel system cleaner & see it that helps at all also??? Good luck!!!
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: MMO improved performance, what does it indicate? [Re: Rat407] #4477322
08/02/17 11:00 AM
08/02/17 11:00 AM
NC
Vladiator Offline
Vladiator  Offline
NC
If I read the original post correctly - then the change in performance did not take place until AFTER MMO was added.
Seems like OP changed the plugs, drove around for a while qith little to no change, and then added MMO last week. Once MMO started doing it's magic - good results took place. If the spark plugs were the ones to blame for success - the results would be noticed immediately after a spark plug replacement, before the addition of MMO.
2009 Scion xB-120k
2013 VW Tiguan-120k
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477323
08/02/17 11:01 AM
08/02/17 11:01 AM
Southern NY
Southern NY
I am ruling out spark plugs because the oil change and the spark plug change was performed within 2 weeks of each other. The car is running for 2+ months on new spark plugs and I didn't notice this 'pep'. This change is less than 10 days old. Hence, my hunch is more in MMO.
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477324
08/02/17 11:05 AM
08/02/17 11:05 AM
NC
Vladiator Offline
Vladiator  Offline
NC
approved approved approved
2009 Scion xB-120k
2013 VW Tiguan-120k
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477334
08/02/17 11:21 AM
08/02/17 11:21 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I find most 5w30 dexos 1 too viscous for NA engines, Ive been subbing 1/2 > 1 qt 5w20 to thin the sump a bit. This will affect HTHS and KV. Most of these engine have been fairly YOUNG, so that would be a factor to consider.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477335
08/02/17 11:24 AM
08/02/17 11:24 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
OP is just subjective. Doubt it helps.
2015 Ford F250 w/Powerstroke
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477364
08/02/17 12:07 PM
08/02/17 12:07 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
KREEN is much more effective than MMO, but pretty agressive ... BG109 (EPR) is somewhere in the middle. I suspect you had stuck rings. I'd run full can of BG109 in two consecutive 3,000 oil changes and see what happens. Suspect you'll get a bit more GO laugh
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477382
08/02/17 12:22 PM
08/02/17 12:22 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
You definitely need to get the KREEN maybe 2 or 3 bottles of it, since MMO did not make any difference. Yeah the MMO always fixes cars but only with 2 or 3 KREEN treatments immediately afterwards. We don't know how any of this works, that's a bona fide Mystery, we just know that it does ernt thert's gerd enerf fer me. It must be the Chlorocarbons. Bleach has chlorine in it so you know it's cleaning out the engine and removing stains and outperforming regular oils on "the bandit". hide
Re: MMO improved performance, what does it indicate? [Re: ARCOgraphite] #4477397
08/02/17 12:38 PM
08/02/17 12:38 PM
Southern NY
Southern NY
Can you pls elaborate? I got lost in translation (of the short forms). Thanks in advance.
I am hesitant of using Kreen because everyone suggests that its aggressive. If its really the crud that is loosening, I don't want to do it quick. I would prefer slow but steady.
With BG109, can I add it to the oil that has MMO or should keep this one for the next one?
I liked Vlad's idea because if MMO is cleaning, let it do the job for 3-4 short OCIs and then plan anything else. It may also give some idea what is actually going on (if cleaning the crud so the oil will be coffee brown etc.).
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477418
08/02/17 12:56 PM
08/02/17 12:56 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Then why are you asking about using it, especially after your "problem" seems to have been miraculously solved by MMO?????? What am I supposed to conclude from this thread, that MMO works and it's competitor KREEN might be too harsh and aggressive?
Re: MMO improved performance, what does it indicate? [Re: MoneyJohn] #4477481
08/02/17 02:08 PM
08/02/17 02:08 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
This is a good plan. It is also easy to implement and the MMO easier to get than the Kreen. I like Kano products, nothing against them (AeroKroil is awesome), but it just doesn't seem necessary to go to the added expense here and hassle in this case. The ring theory is also a very likely scenario (freed some modestly stuck ones as BrocLuno said).
If you do add it to fuel, you can do a large loading dose initially as Vlad mentioend. BUt also you can use it 3~4 ozs/10gallons every tank. In both our daily drivers, this results in improved performance and a small mpg boost, even when using top tier 92 octane.
Coincidentally, I'm doing another piston soak on my Acura SLX with stuck OC rings today. One of the soaks is going to be with MMO + acetone.
Page 1 of 3 1 2 3
