So, I've had some front-end noise develop on my '07 Honda Fit Sport. Reading about the symptoms I believe it could be strut mount or the end links being the culprit.
I took some pictures of the end links with the wheels turned and noticed what appears to be a damaged boot:
http://imgur.com/a/jPzE3
Sounds like a rubbing/popping noise when turning the wheel; more so towards the left and this picture is of the passenger side front.
It is almost as if the spring is catching due to failing strut mounts?
Noisier when going from D/R and such as backing out of a parking space or driveway; low speeds or stop 'n go.
