Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 6 invisible), 776 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
Best epoxy/glue for wood, abs, plastic #4476829
08/01/17 06:55 PM
08/01/17 06:55 PM
Tennessee
OilSwag Offline OP
OilSwag  Offline OP
Tennessee
I'm going to do a mold in my upper dash for a 8 inch tablet. The factory nav has been removed and the new housing mold trim is going to be abs plastic attached to factory console and 1-2 small strips of wood for bracing. These are the materials for the mold. To attach everything together pre fiberglass or filler what type of epoxy would you guys use, that's strong and long term.
With how the mold/trim for the tablet will be I probably won't even need to fiberglass it to be honest. Just filler where it attaches, not sure yet. So picture you made a housing for a tablet with a sun shield on it to fit on top of your center console and you want to attach it than fill in the seams. That's my plan. Filler at most would be 1/8 inch
03 Infiniti G35 209K, Castrol Edge 5W30 topped with Edge HM, Fram Ultra Filter, Berryman/MMO fuel maintenance in 93 E0, all synthetic fluids
Re: Best epoxy/glue for wood, abs, plastic [Re: OilSwag] #4476837
08/01/17 07:02 PM
08/01/17 07:02 PM
central Texas
sr4440 Offline
sr4440  Offline
central Texas
Re: Best epoxy/glue for wood, abs, plastic [Re: OilSwag] #4476927
08/01/17 08:31 PM
08/01/17 08:31 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
I'd bet polyurethane glue would work.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Best epoxy/glue for wood, abs, plastic [Re: OilSwag] #4477381
08/02/17 12:22 PM
08/02/17 12:22 PM
California
nthach Offline
nthach  Offline
California
ABS plastic is one of the more difficult plastics to bond to besides polyethylene or polyolefin. I had limited success using Devcon's plastics bonder, which is a structural urethane, an auto body supply shop can point you in the direction of 3M Scotch-Weld or Fusor's plastics adhesive.
If you're using epoxy for the the whole job, why not look into West System's epoxy thickened with their 406 colloidal silica? That way, you can use the same resin for glassing and bonding.
