When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
107 registered members (2015_PSD, 2009Edge, 2whlgeezer, Anduril, andyd, 12 invisible), 2,077 guests, and 58 spiders.
Topics286,160
Posts4,903,317
Members67,569
Most Online2,967
Mar 10th, 2019
Homemade Oil Extractor #4476775
08/01/17 06:23 PM
08/01/17 06:23 PM
Champlain/Hudson Valley
Kira Offline OP
Kira  Offline OP
I rigged an oil extractor from an old chemistry lab vacuum pump, a 5 gallon pail with a gasketed lid and suitable lengths of hose. One hose connected the pump's suction port to the pail and the other was a length of 1/4" hose which reached down the dipstick tube.
It ran slowly and when I closed the throttling orifice to increase the suction, the sides of the pail collapsed so I know the system was quite free of air leakage.
15 torturous minutes of extraction yielded barely a pint (16 oz.) of oil. I was stumped.
The oil I had collected resembled semi-dissolved jam. 'Twas all shifty and wavy, not like plain, familiar oil sloshing in the bottom of a pail.
I had a heart attack.
Pulling the drain plug saw the oil drain normally.
The pail I had used for my extractor was clean. It had been 1/4 full of floor cleaner but rinsed out perfectly.
I must try this extractor again as I need it for another car. This was an experimental run.
Perhaps the 1/16" inner diameter is simply not big enough for effective oil suction.
Maybe a thinner walled 1/4" tube would work better.
I'm still wondering about the appearance of the "drawn pint" because it was from a dealership's oil change.
They used a Volvo filter alright but heaven only knows what kind of oil. Some kind of "motor honey" quieting agent came to mind.
Re: Homemade Oil Extractor [Re: Kira] #4476776
08/01/17 06:25 PM
08/01/17 06:25 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Pics of the extractor???? wink
God Bless Our Troops
Re: Homemade Oil Extractor [Re: Kira] #4476823
08/01/17 06:52 PM
08/01/17 06:52 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
I have a vacuum extractor that was designed for boats. It's a metal 2 gallon can, with one hose. There's a pump that attaches to one of the holes in the can. After about 20-30 pumps, you release the squeeze clip on the hose that stuck down the dipstick, and the oil gets sucked out. Your setup should work the same way as long as the hose doesn't touch or get stuck to the bottom of the oil pan.,,
Re: Homemade Oil Extractor [Re: Kira] #4476852
08/01/17 07:27 PM
08/01/17 07:27 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
My extractor uses a hard wall type of tubing so the tubing wall doesn't collapse under vacuum. also makes a big difference if the oil is slightly warm vs cold. Also if it is too hot of oil the larger tube connecting the hard tube will collapse and you get next to nothing then.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Homemade Oil Extractor [Re: Kira] #4476893
08/01/17 08:01 PM
08/01/17 08:01 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
The oil tube for suction on my medical evacuator is 3/16s and warm oil is rapidly sucked out of sumps on small engines, brake reservoirs and the like.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Homemade Oil Extractor [Re: Kira] #4476942
08/01/17 08:48 PM
08/01/17 08:48 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
1/16th inch for the extractor tube is waaayyyy to small.
Re: Homemade Oil Extractor [Re: Kira] #4476950
08/01/17 09:01 PM
08/01/17 09:01 PM
WI.
dblshock Offline
dblshock  Offline
WI.
get the oil hot..My Honda oil tube wont accept a 1/4" suction tube so I went to the hardware store and found a 5/32" brass pipe that I then elongated to fit, it works but needs hot oil.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Homemade Oil Extractor [Re: Kira] #4477074
08/02/17 12:55 AM
08/02/17 12:55 AM
CA
raytseng Offline
raytseng  Offline
CA
if you can clean up. try your device on water first. if it can't even suck up water then you've got an issue.
all extrwctors use a ridgid container. if your pail is collapsing i dont think its adequate for this job
Re: Homemade Oil Extractor [Re: demarpaint] #4477112
08/02/17 05:56 AM
08/02/17 05:56 AM
Kira Offline OP
Kira  Offline OP
I'd like to but no website accepts pictures from my computer
Re: Homemade Oil Extractor [Re: Kira] #4477266
08/02/17 09:48 AM
08/02/17 09:48 AM
TN
terry274 Offline
terry274  Offline
TN
You can upload the picture to bitog, no need for an external site. Use the icon with the "up" arrow. (upload inline image)
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
