Steering rack clunk - cannot solve
Rochester, MI, US, World
Our Fusion has this clunk that comes from the steering rack. The noise almost sounds like a gearbox with play. I can only replicate it when the car is still, and I shimmy the wheel back and forth quickly. I'm not sure why I ever did this in the first place, but it's been like this for awhile. Today I finally got around to taking some things apart, and checked for bad parts. Both inner and both outer tie rods are good - no play, no broken boots or bellows, no clunks. I disconnected them on the outer end to test, so the parts were unloaded. Even when the tie rods are hanging free, the noise is still present. I checked the steering shaft/joints, and those too are good.
What I did see, where the shaft stub comes through the floor, is that it will wiggle back and forth the tiniest bit if you try and move it. Is this normal? I really have no experience with power steering racks, and how much play they should have. Rack mounts are in good shape also, FWIW. This is also a fully electric rack. Car drives and steers fine, with seemingly no play or noise under normal driving.
There should be some preload on the rack and pinion but its hard to measure that in the car. I'm thinking either the pinion bearing/bushing has some play in it or the steering shaft has some slop at the splines/coupling or at a joint.
It could be the rack itself. I went through the ROs where we replaced racks on your year Fusion but all the descriptions were for either complete loss of power assist, or a light on and towed in.
Is there a way to adjust preload on this unit?
I know that Escorts are not the same as Fusions but I had very similar issues, worse actually, when the steering rack bushings needed replacing. They were basically rubber inserts that fit inside the metal brackets that secured the steering rack to the body/frame.
For years Chevy trucks had an Intermediate Steering Shaft clunk which, among other things, caused me to switch to Ford Pickups. It is aggravating as all get out. Could this be it? When my first one was replaced under warranty on my 2005 Silverado the service writer informed me that they had over 300 in stock and replaced them like popcorn. I haven't driven a Chevy since: I wonder, did they ever get that fixed?
Originally Posted By: Trav
Lots of GM cars had that problem all the way back into the 90's, I don't think they ever got it squared away 100%.
I think you're referring to the intermediate steering shaft clunk. My dads 02 Suburban has it, even my 07 Malibu has it.
That vintage had recirc ball, right? Now both of my GM's are rack & pinion - one electric and one hydraulic - no noise ...
Yup. The spline sticks and slips making annoying clunk. Lubing works for a while, but it seeems to always come back.
Double vanos said..
To which I replied..
Is there a question as to what I was referring to?
