Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
46 registered members (Bailes1992, alarmguy, benhen77, BadMonkey, 97K15004WD, 69Torino, 7 invisible), 981 guests, and 35 spiders.
Topics294,965
Posts4,924,985
Members66,654
Most Online2,553
Oct 27th, 2018
KTM Rimula #4476425
08/01/17 10:25 AM
08/01/17 10:25 AM
Slovenia
tdm850 Offline OP
tdm850  Offline OP
Slovenia
Hello!
Here in Europe we don't have Shell Rotella oils, we have Rimula instead. I have 2 KTM fourstroke Motorcycles, and I wonder if I can use the Shell Rimula 6 LM oil in them. It is not rated JASO MA, and it is not rated for gasoline purpose.
I did use it regulary in all my KTM 2 strokes all the time with no problems, so I can state that it meets the JASO MA standard, because the clutch had absolutely no problem working in that oil. But I'm a little worried how it will perform in lubricating the piston and head on a four stroke.
I have access to a bunch of Shell Rimuala oils for trucks for almost free and the 6 LM being the top as it is full synt 10W-40. I need a lot of oil changes on those two KTM's, so I really need your opinion on this matter.
Thanks.
Re: KTM Rimula [Re: tdm850] #4476456
08/01/17 11:10 AM
08/01/17 11:10 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
As long as the viscosity of this oil is within the range of the oil specs for the KTM's I don't see a problem.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: KTM Rimula [Re: tdm850] #4476467
08/01/17 11:16 AM
08/01/17 11:16 AM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
Welcome to the Bitog! Thank you for the Rimula info on the motorcycle service.
In Europe commercial oils aren't rated for petrol engines, but common sense goes long way.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: KTM Rimula [Re: tdm850] #4476519
08/01/17 12:14 PM
08/01/17 12:14 PM
Slovenia
tdm850 Offline OP
tdm850  Offline OP
Slovenia
Thanks for quick replyes!
The viscosity is not in range. The viscosity for the 2 stroke by KTM manual is 15W-50, but I had no problem running the Rimula 6 LM with the viscosity 10W-40 in the 2 stroke.
For the 4 stroke the viscosity by KTM manual is 10W-50. Now, I know the Rimula viscosity is not right at 10W-40, but so many people run the same motorcycle with the Rotella 15W-40 and Rotella 5W-40 withought any problems. So....
Re: KTM Rimula [Re: tdm850] #4476603
08/01/17 01:40 PM
08/01/17 01:40 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
"Rimula" LOL
Sorry that's all I got
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: KTM Rimula [Re: tdm850] #4476606
08/01/17 01:45 PM
08/01/17 01:45 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Aloha smile
So you are using 4t oil in 2strokes confused Or you wanted to say that 2strokes have a separate gearbox sump?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: KTM Rimula [Re: tdm850] #4476611
08/01/17 01:50 PM
08/01/17 01:50 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
And instead of RM I would rather be using M version since M is full SAPS one (more Zinc and Phosphorous for your gearbox)
Re: KTM Rimula [Re: Kamele0N] #4476620
08/01/17 01:57 PM
08/01/17 01:57 PM
Slovenia
tdm850 Offline OP
tdm850  Offline OP
Slovenia
KTM 2 strokes have oil for gearbox/clutch. There I use Rimula. For the MIX I use specific oil for 2 stroke premix.
Re: KTM Rimula [Re: Kamele0N] #4476624
08/01/17 02:00 PM
08/01/17 02:00 PM
Slovenia
tdm850 Offline OP
tdm850  Offline OP
Slovenia
I am using R6 LM. Did you mean that is better to use R6 M?
Re: KTM Rimula [Re: tdm850] #4476672
08/01/17 02:55 PM
08/01/17 02:55 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Yes...M is full SAPS ACEA CI-4
RM is for aftertreatment systems (DPF... SCR)...and therefore has less ZDDP aditives
Re: KTM Rimula [Re: tdm850] #4476683
08/01/17 03:02 PM
08/01/17 03:02 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Re: KTM Rimula [Re: tdm850] #4476705
08/01/17 03:28 PM
08/01/17 03:28 PM
Slovenia
tdm850 Offline OP
tdm850  Offline OP
Slovenia
Thank you so much for this information!
I did some research and I have became worried about the viscosity not being right. I have the KTM 350 EXC and it have a delicate head design.
Maybe I should use the oil with prescribed viscosity 10W-50 and forget about the Rimula 10W-40.
What is your opinion about this?
Re: KTM Rimula [Re: tdm850] #4477925
08/03/17 02:34 AM
08/03/17 02:34 AM
UK
weasley Offline
weasley  Offline
UK
I concur. Why make a point of deliberately using the 'wrong' oil specification AND viscosity? Why not just go with the recommendation?
Also, on the SAPS thing mentioned above, HD oils are different to car oils when it comes to what is defined as "low SAPS". Even the R6 LM has a sulphated ash at 0.9% and a TBN around 10, which is plenty.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: KTM Rimula [Re: tdm850] #4477989
08/03/17 06:47 AM
08/03/17 06:47 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
What his gearbox cares off is ZDDP content...not TBN and sa level...
Re: KTM Rimula [Re: Kamele0N] #4478705
08/04/17 02:37 AM
08/04/17 02:37 AM
UK
weasley Offline
weasley  Offline
UK
A decent motorcycle oil will have a good dose of ZDDP plus the benefits of a shear stable polymer and performance-appropriate detergents. I've just looked up the data of a common MCO: ~1,000 ppm P, 1.2% ash. And this comes in the right viscosity with appropriate API and JASO performance.
Like I said, why expend so much time and effort to get an oil so far from the recommended type?
2018 Volvo XC60 D4
2011 KTM 990 SMT
