My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned - I let someone else change my oil
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
99 registered members (Anduril, 97K15004WD, 93cruiser, andyd, 97f150, 15 invisible), 1,947 guests, and 43 spiders.
Topics295,131
Posts4,928,249
Members66,691
Most Online2,553
Oct 27th, 2018
Roofing Question #4476406
08/01/17 09:56 AM
08/01/17 09:56 AM
pennsylvania
GGorman04 Offline OP
pennsylvania
I have a leak in one area of my roof. A co-worker recommended FlexSeal tape.
They also have the spray on in a can.
Has anyone tried this or can give some advice on other options?
Thanks in advance
Re: Roofing Question [Re: GGorman04] #4476418
08/01/17 10:19 AM
08/01/17 10:19 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Oh come on. Mickey Mouse.
What kind of roof construction? and is the leak near a Gable end or dormer or Punch through?
I just spent 10's of thousands of dollars over the past decade to fix a BAD roof leak ( on my log cabin) only for ME to find ( not "expert" carpenters) a poorly sealed chimney liner at the cap.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Roofing Question [Re: GGorman04] #4476426
08/01/17 10:25 AM
08/01/17 10:25 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
The stuff works very well for EDPM roofs on a lot of campers. I have resurfaced and repaired three camper roofs since February. I suspect you have a asphalt shingle roof though.
Most asphalt roofs with leaks are in my experience are from around vents and chimneys.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Roofing Question [Re: GGorman04] #4476428
08/01/17 10:28 AM
08/01/17 10:28 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Depends on where the leaks are?
Most of the time, all it needs is the roof caulk which is usually used under the flashing and to cover the exposed nails.
So you have to determine the source of the leaks.
In reality, somebody have to go up there on the roof and see what can be done.
I suggest to find a roofing professional if you are not comfortable going up on the roof.
The hospital bill of an accident will be more than the price you pay the pro to fix it.
  • 2017 Toyota Sienna
Re: Roofing Question [Re: GGorman04] #4476437
08/01/17 10:41 AM
08/01/17 10:41 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
One of my buddies use the Flex seal to temporarily patch his roof until he could get it fixed properly. Said it worked pretty well.
Think twice, speak once.
Re: Roofing Question [Re: GGorman04] #4476446
08/01/17 10:53 AM
08/01/17 10:53 AM
NY
demarpaint Offline
demarpaint  Offline
NY
For a quick fix it works, most of the time.........
God Bless Our Troops
Re: Roofing Question [Re: bioburner] #4476465
08/01/17 11:15 AM
08/01/17 11:15 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
With which product?
Re: Roofing Question [Re: GGorman04] #4476487
08/01/17 11:33 AM
08/01/17 11:33 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Another area to consider is ridge vents. I recently troubleshot an odd leak in my sister-in-law's $700K, couple year old mansion. Nightmare roof. Tons of peaks, valleys, etc. It's coming in through a ridge vent. During certain driving wind and rain, it blows right in. I found where the previous owner (and builder) tried to band-aid this area of ridge vent by filling it with spray foam! SIL/BIL can afford to have it fixed right at some point.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Roofing Question [Re: GGorman04] #4476529
08/01/17 12:29 PM
08/01/17 12:29 PM
Columbus, Ohio
John_K Online confused
John_K  Online Confused
Columbus, Ohio
Thanks in advance
I used the spray for something that was somewhat protected from the weather. Wore off in 3 months. Carp in my book.
2009 Mercury Grand Marquis, 8 cyl auto, 83xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 96xxx miles, Maxlife/OEM Filter
Current oil stash: 519 qts.
Re: Roofing Question [Re: GGorman04] #4476556
08/01/17 12:50 PM
08/01/17 12:50 PM
pennsylvania
pennsylvania
Thanks guys.
It is a rubber roof on my commercial building.
Would rather not get up on the roof myself
Re: Roofing Question [Re: GGorman04] #4476564
08/01/17 12:59 PM
08/01/17 12:59 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Flex tape or any of the dozens of rubber roof repair kits using mesh/liquid sealant. Even with the Flex Tape I would still put a sealant around that as well.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Roofing Question [Re: GGorman04] #4476601
08/01/17 01:39 PM
08/01/17 01:39 PM
Hamburg Michigan
Elevguy Offline
Elevguy  Offline
Hamburg Michigan
There's a product called gayco elasticmetric https://gaco.com/product-details/gacoelastomeric/ made for flat rubber roofs
Re: Roofing Question [Re: GGorman04] #4476648
08/01/17 02:27 PM
08/01/17 02:27 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
I was a hot tar roofer for 1.5 years and my dad for 30+. We always used a bucket of roof mastic and a roll of fiberglass fabric to seal the flashing's. The mastic is a tarry fibrous goop you apply with a small trowel. You can mash it over strips of the fabric to give it some strength covering over small voids. You can get it at home depot and it will last years if you do it right. That stuff in a can is TV-Junk.
Re: Roofing Question [Re: Linctex] #4476740
08/01/17 04:32 PM
08/01/17 04:32 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
With which product?
Cofair Products UBW425 Ultra bond, from Amazon but available from some home improvement stores, overpriced from camper supply.
The roof coating I used to recoat three roofs, Dehco 16-46128-4,rubber roof coating and came from 4Wheel online via Amazon $50/G
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Roofing Question [Re: GGorman04] #4477254
08/02/17 08:36 AM
08/02/17 08:36 AM
pennsylvania
pennsylvania
Thanks guys for the help! It would make sense to buy a product made for a flat rubber roof.
