I have seen others post their reviews here after renting a vehicle, so I would like to contribute one of my own.
I spent some time in Las Vegas last week and lucked out when Alamo let me have a almost brand new 2017 Toyota Corolla SE for the week.
The SE trim is a sporty version, so it has the fancy wheels, paddle shifters, and some light tech package upgrades. Backup camera is standard along with many safety features that I wasn't expecting to find in a rental car.
Physically, it's a Corolla. Not much has changed since these became appliance cars back in the 90s, but I think that's the entire point of this car. It's simple, straight forward, and adequate in every aspect.
The powertrain is an inline-4, FWD, paired with a CVT.
Pros:
Cons:
My mixed city/interstate driving resulted in just shy of 30mpg, which is exactly on par with mfr estimates. I suspect that MPG will improve slightly once the engine has been fully broken in, as seems common with Toyotas.
Seating seemed ample enough for 4 adults, but I think the weight would put a lot of strain on the engine/trans.
Pictures:
Pros:
- HVAC controls (for fan speed, zone selection) are up/down toggle type switches. While not as intuitive as rotary dials, it's easy to use this type and it looks a lot cleaner while saving space.
- Ride quality is quite good for such a small and light car. I suspect that models with less-sporty wheels will ride even better due to more sidewall area.
- The dashboard, while plastic, is molded in a very stylish way that I wouldn't expect in an economy car. The faux stitching is a nice touch, even though it's just molded into the plastic.
- The AC in this car will freeze you if you aren't careful. I wasn't expecting such strong cooling in an economy car, but it seems that Toyota finally figured out how to compete with the domestic makers on HVAC capability.
- The seats are surprisingly supportive with pronounced side bolsters. The combo of pleather and cloth with accent piping looks quite nice.
- I didn't do anything under the hood, but the engine bay looks simple and easy to work in.
Cons:
- Some interior dash/trim pieces are glossy piano black. Even the most careful owner will be unable to avoid making scratches, and smudges are easily visible.
- Entune system buttons are capacitive touch. Big no no to me because you have to look away from the road to press the button properly. I even had an odd occurrence where my radar detector power cord was able to 'touch' the buttons.
- CVT programming is odd at times. Under seemingly random circumstances, the engine will seem to want to rev very high and hold the revs there.
- I could only find a single 12V power port.
- The infotainment LCD display is almost too 'vertical', resulting in an odd viewing angle of the backup camera video (washed out effect that is common on any LCD).
Pictures:
