Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
76 registered (4WD, 2012AccentSE, bdcardinal, asiancivicmaniac, Al, 4 invisible), 1557 Guests and 39 Spiders online.
65294 Members
67 Forums
285764 Topics
Page 1 of 3 1 2 3 >
#4475967 - 07/31/17 08:21 PM Sludge removers...... worth the effort?
kafka45 Offline
Loc: Lincoln, NE
Ok.. I've recently obtained a 1989 Dodge Dakota (V6).. 108000 miles. So it obviously has been sitting around a LOT.
I did all the usual.. changed plugs.. wires..etc. Now I changed the oil with Mobil 1 and was wondering, for the next change should I use
a sludge removal additive like EPR engine performance restoration, or something similar to "clean" out the engine? Its running ok for now, so
leave it be or try to "improve" things. If it can't hurt I'll try it... if it could make trouble... not worth it.
by all means suggest a product that might improve engine interior if there IS such a thing.
thanks...
Timing is EVERYTHING.
#4475974 - 07/31/17 08:28 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
Nick1994 Offline
Loc: Phoenix, AZ
Does it look sludged under the oil fill cap?
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4475975 - 07/31/17 08:28 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
TheKracken Offline
Loc: Fort Worth TX
I would run a few short oci intervals and then use a good flush like liquid molly or ravenols new flush...or amsoil
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
#4475978 - 07/31/17 08:29 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
danez_yoda Offline
Loc: texas
You want to remove sludge if there is any slowly. Big gobs of sludge getting removed will plug passages and your filter.
I would say run a high detergent oil for a while and call it good.
#4475987 - 07/31/17 08:39 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
SilverFusion2010 Offline
Loc: Crawfordville FL
Best thing you can do is a few short oci with lots of highway miles. Hot oil cleans better.
You can use a flush if you want to, but it runs the risk of a big chunk plugging something and creating oil starvation. Even with just a short oci you may get a few chunks out the first change or two. It just depends
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4475990 - 07/31/17 08:41 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
Vladiator Offline
Loc: NC
Get a quart of Marvel Mystery oil. Put 3/4 of the bottle in oil, and 1/4 of the bottle in gas and top off the gas tank. MMO will clean up the fuel system to improve performance, and will clean everything that the oil touches inside the engine.
Case on point - 2006 Pontiac Vibe AWD had severe oil consumption (1qt per 100 miles) and higher fuel consumption. After I used MMO in fuel and oil the car "woke up" a little. Oil consumption reduced from 1qt/100mi to 1qt/4000 miles. Fuel consumption went from 23mpg average to 27-28mpg average. MMO works. Good luck!!!
That car was a severe sludger btw. Pic below. But after MMO no "chunks" ever blocked the oil flow or anything. Performance improved drastically though.
Thicker oils give protection for severe operations such as driving in mountains, pulling a boat, dusty conditions, short trips, high rpm, overloading, overheating and overcooling. Thin oils give MPG.
#4475995 - 07/31/17 08:45 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
PimTac Online   content
Loc: Soviet State of Washington
Verify that it's sludged first then run short intervals of a good cleaning conventional oil. No need to spend extra money for synthetic at this point. Chevron Supreme or Pennzoil yellow bottle will do the trick. Get it out on the highway and run it.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4475998 - 07/31/17 08:46 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
FermeLaPorte Offline
Loc: Texas (south)
popcorn
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
#4476010 - 07/31/17 08:58 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
Dyusik Offline
Loc: US-WA
I always use HDEO for cleanup. Drain tar couple of oci and it's done. And the peace of mind with extra film thickness to keep the dislodged crud from causing issues.
That's just me.
95 Cherokee 190K DELO 10W30,XG8
07 IS250 97K FB ?w??,FULL
04 YZF-R1 19K DELO 15w40,XG7317
99 HD XL1200S 18K VR1 20w50,1515
14 RX450h 30k PP 0w20,NAPAG
#4476044 - 07/31/17 09:35 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
L_Sludger Offline
Loc: Ohio
thanks...
Leave
It
ALONE
too many cars and oil combinations to list in 150 characters or less
#4476088 - 07/31/17 10:38 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
OneEyeJack Offline
Loc: S California
Auto-RX. Follow instructions, be patient and the process will be safe with good results.
#4476097 - 07/31/17 10:46 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
oil_film_movies Offline
Loc: MN
Get some seal conditioners in there. These are very old seals. Liqui Moly Motor Oil Saver or STP High Mileage. Then use a High Mileage oil next time, like Valvoline MaxLife 5w30
#4476119 - 07/31/17 11:19 PM Re: Sludge removers...... worth the effort? [Re: kafka45]
askani79705 Offline
Loc: midland tx
If it ain't broke. Sounds like you've already made a good choice. I wouldn't use a additive, just regular OCIs with a good oil.
2017 Ford F150 NAPA syn 5w30 Fram 11955.
2000 Chevy 2500 Silverado PYB 5w30 AC Delco Filter
#4476120 - 07/31/17 11:19 PM Re: Sludge removers...... worth the effort? [Re: L_Sludger]
CrAlt Offline
Loc: CT
I vote leave it alone.
A little sludge never hurt nothing.
A clogged filter or pickup will hurt something.
Just run short OCI's with a higher detergent oil like others suggested. IF there is any sludge that will clean it out slowly and safely.
'16 Wrangler JK PYB 5w20 / MO 349
'77 Corvette JG HR2 10w30 / AC PF454
'83 Trans-Am JG HR2 10w30 / AC PF454
'91 Dodge D150 QSGB 10w40 / AC PF13
#4476131 - 07/31/17 11:55 PM Re: Sludge removers...... worth the effort? [Re: Vladiator]
Triton_330 Offline
Loc: Illinois, USA
This...
Or, you could get this: https://www.amazon.com/Mystery-50735-Classic-Ultimate-Treatment/dp/B072Q5Y4LP/
Pour the 16 oz. classic MMO into your oil, and pour the 12 oz. fuel treatment into your gas tank. (Also, I'd recommend a Wix filter).
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Page 1 of 3 1 2 3 >
