Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
98 registered members (Al, 28oz, 97prizm, 1WildPig, 5azzmonkey, 10 invisible), 2,171 guests, and 45 spiders.
Topics295,224
Posts4,930,468
Members66,716
Most Online2,553
Oct 27th, 2018
A/C Manifold Gauge Pressures #4475943
07/31/17 07:01 PM
07/31/17 07:01 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
2000 Buick LeSabre
At Time of Gauge Reading:
Ambient Temperature 72 F - 51% Humidity
Factory Service Manual Specifications:
Ambient Temperature 70 F Below 40% Humidity
Low Side (32-38 psi) High Side (160-190 psi)
Ambient Temperature 70 F Above 40% Humidity
Low Side (34-40 psi) High Side (175-205 psi)
Measured Gauge Readings:
Low Side (36 psi) High Side (160 psi)
Am I still low on charge ? ???
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476016
07/31/17 08:03 PM
07/31/17 08:03 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Looks a little low, With your temp & humidity, I would like to see 185-210 on the high side.
I'm sure the A/C Nazi's will be by shortly to tell me I'm wrong & you need to vacuum it down & weigh the proper amount of freon back in the system.....Technically they're correct, If I had a leaky POS Harrison HT6 compressor......I would just keep it charged with a little oil.
2001 Chevy Camaro L92/4L80E
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476023
07/31/17 08:16 PM
07/31/17 08:16 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Did you have a big fan blowing over the condenser?
Id say a little bit low, but at this point vent temperatures tell the story. You could add an incremental amount to the system, very small amounts at a time, and watch if the vent temperatures keep dropping. If they don't, or worse, if they start to go up, you've gone too far.
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476058
07/31/17 08:55 PM
07/31/17 08:55 PM
New Jersey
Rock_Hudstone Offline
New Jersey
What are the vent temps?
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476062
07/31/17 08:58 PM
07/31/17 08:58 PM
Clovis, CA
Clovis, CA
JHZR2
Both cooling fans turn at high speed whenever the A/C is on, so I think maybe the answer is yes.
Vent temperatures at the time of pressure reading were (41.2 F - 42.0 F)
Actual ambient temperature at the time of pressure reading was (72.2 F)
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476070
07/31/17 09:07 PM
07/31/17 09:07 PM
New Jersey
New Jersey
Vent temperatures at the time of pressure reading was (41.2 F - 42.0 F)
Those are very good vent temps and should go even lower when the vehicle is at speed. Pressures look okay as well, a tad low on the high side but they are many variables that can affect that.
I wouldn't add more refrigerant unless the A/C feels like its not cooling well on the next hot day.
Re: A/C Manifold Gauge Pressures [Re: Rock_Hudstone] #4476111
07/31/17 10:08 PM
07/31/17 10:08 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
+1
41-42 is good at idle. What's the temp while driving down the road for a few minutes?
Did you fix the left side vents being warmer than the right side vents?
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: A/C Manifold Gauge Pressures [Re: Nick1994] #4476147
08/01/17 12:11 AM
08/01/17 12:11 AM
Clovis, CA
Clovis, CA
Yes! What led me to the refrigerant direction was that I tested all the mode door operations and the left side vents shut completely off when switching from front vents to front defrost to blow air up onto the front windshield. And then all the temperature changes worked good too. I was all prepared to change a blend door actuator if need be.
Hey Nick, what kind of vent temperatures do you get when it's over a 100 F outside ?
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476522
08/01/17 12:19 PM
08/01/17 12:19 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
When I did AC I always tried for around 1500-2000 RPM, AC set to "recirculate", as well as a large fan blowing at the front of the car over the condenser.
In a perfect world, at 70F ambient, I would expect vent temps around 35F. Generally OEMs spec somewhere around 40F under ambient as allowable. Honestly on any full size American vehicle, at least 50F below ambient is expected (down to about 35F outlet temp).
Re: A/C Manifold Gauge Pressures [Re: punisher] #4476645
08/01/17 02:22 PM
08/01/17 02:22 PM
New Jersey
New Jersey
This a 17 year old vehicle.
I'm jumping in late here but assuming most, if not all of the cooling system is OE vent temps around 40F at idle is not bad in my humble opinion.
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4476651
08/01/17 02:31 PM
08/01/17 02:31 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'll have to put my thermometer back in the car. Usually 38-40, I drive a lot of highway so it gets lots of flow over the condenser. Electric fans don't pull enough air over it.
Re: A/C Manifold Gauge Pressures [Re: Nick1994] #4477927
08/03/17 02:45 AM
08/03/17 02:45 AM
Clovis, CA
Clovis, CA
38-40 is quite excellent for 100 F at idle.
It was 107 F in the garage today and the lowest vent temp I could get is 58 F.
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4800716
06/29/18 02:24 PM
06/29/18 02:24 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I have a Harbor Freight AC manifold gauge and used it for my 2008 Hyundai Accent. Today I tried to hook it up to my 2010 Hyundai Genesis Coupe. I could get the high side to snap on but not he low side. Are there two different sized low side nipples?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: A/C Manifold Gauge Pressures [Re: Merkava_4] #4800738
06/29/18 03:10 PM
06/29/18 03:10 PM
USA
mk378 Online content
mk378  Online Content
USA
All 134a car couplers are the same two sizes, 13mm low side and 16mm high. Many people have had trouble with the Harbor Freight set not coupling properly.
Re: A/C Manifold Gauge Pressures [Re: SHOZ] #4800740
06/29/18 03:12 PM
06/29/18 03:12 PM
Northeast
sxg6 Offline
sxg6  Offline
Northeast
When you look under the hood for the Genesis, does it say r134a? Or does it maybe have r1234YF?
